First post, by luRaichu
Just got these no-name 90’s computer speakers, was wondering what can be done about the hum they make. It’s only really noticeable with silent audio signal.
It sounds like there’s interference from mains power as it’s a 60Hz tone. The simple power supply consists of a 120V -> 12V transformer followed by some diodes to rectify the 12V AC and create 5 and 12 volt DC rails.
Capacitors should be replaced as they’re old and from off brands.
Reply 1 of 13, by Tiido
Better capacitors may help but the possible bigger issue is the proximity to the power transformer.
If you use the speakers in this opened state and the humming is gone with the board out like that but getting worse with the board nearing the transformer you have a difficult situation without a good fix...
Reply 2 of 13, by Yoghoo
Had the same issue a couple of weeks ago. My issue was the 3.5mm cable I used that was too thin and picked up interference from power cables.
But there can be other issues as well. For example a ground loop. There are some (US specific?) power line filters that can mitigate this. Also try to connect the computer and speakers to the same power outlet.
There are also 3.5mm (car) audio filters which could help (for example: https://www.amazon.nl/dp/B06XQYN77L?ref=ppx_y … _fed_asin_title).
Reply 3 of 13, by Jo22
Hi, those four diodes might be a bridge rectifier.
If they're aged/worn, they might cause some slight humming passing through.
It's just an idea, though. It can be something else as well.
Reply 4 of 13, by luRaichu
I recapped the board and replaced diodes. It actually wasn't the diodes causing the hum since I tested after replacing them and got no improvement.
What did help was the recap. Now the hum is lower, but still there. I guess I'll have to live with it - after all it's never going to be audible over the sound of an AT power supply fan!!
The hum doesn't change with proximity to the transformer. I guess if it did you could hack a barrel jack onto the speaker and use a 12v wall wart power supply instead.
Reply 5 of 13, by AlexZ
I fixed 50hz hum on my Logitech S200 speakers according to http://www.jpf.de/jpf/logitech_s200_humming/page_01.htm , by moving and rotating the transformer. The hum is so quiet now you would have to come really close to hear it.
One reason why I avoid 2.0 speakers is very little space to move the transformer. There is a lot more space in subwoofer.
I have 2.1 Genius speakers that also have quite audible hum and a broken amplifier (it degraded over 15 years) resulting in very poor and low quality amplification and left/right unbalanced volume. I will probably get an oscilloscope with spectrum analyzer function for that as it will be easier to fix the hum.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 6 of 13, by Jo22
Hi, asked my dad for advice.
He thinks that the humming can be reduced by applying a little bit of nail finish (old aceton solvable type that dryes up) to the transformer's metal sheets.
At the side of the transformer, where often the metal frame is located that holds it together.
He says the vibrations between the loose metal sheets are the culprit.
Reply 7 of 13, by Nexxen
Jo22 wrote on 2025-04-20, 13:08:
Hi, asked my dad for advice. He thinks that the humming can be reduced by applying a little bit of nail finish (old aceton solva […]
This is the reason why I saw "varnished" copper threads?
Interesting.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 8 of 13, by Tiido
Transformer laminations being loose can produce physical noise that won't be heard from the speaker cones themselves. You can listen if the transformer actually humms or even buzzes, which can also happen if a 220V transformer is ran at 230 or even 240V because the core experiences higher magnetizing currents. On better things there's often an extra winding for 240V and it is best to make use of it in order to reduce physical noise the transformer makes, but the cost is slightly lower output voltages which often plays in your favor as it means the linear regulators also get less hot.
Reply 9 of 13, by bertrammatrix
Double the capacitor value, or scab on a small coil/inductor after the first capacitor followed by another capacitor. That should significantly help with PS hum. Or ditch the transformer entirely and use a more modern external electronic PS "brick" to supply it.
After that I'd switch to better shielded input wire.
I wouldn't blame transformer laminations unless it is the transformer itself producing audible hum
Reply 10 of 13, by Tiido
Yeah, it is usually not the transformer itself that makes the noise. Extra capacitance can definitely help a lot, and a good modern brick will fix the issue for sure.
Reply 11 of 13, by luRaichu
I had these speakers up on the desk until about a month ago when I'd noticed a cockroach crawling inside one of them...
Entire nest had to be cleared out. They were basking themselves on the warm transformer despite the speakers being turned off (but plugged in).
Today I reassembled the infested speaker, but now its sound is distorted. Right speaker is fine.
The transistors inside get very hot.
Reply 12 of 13, by aspiringnobody
A little late to the party, but since I'm here -- I'd imagine it would be possible to remove that transformer and replace the entire power delivery with an external DC power supply of appropriate voltage. You might even be able to mod in USB C with one of those little break-out boards everyone is using now. If you're not sure how/where to inject DC power you can post a better view of the PCB and we can try to help you make a schematic.
Reply 13 of 13, by shevalier
luRaichu wrote on 2025-10-10, 21:26:
This is a traditional sign that the transformer primary winding is underwound and its slightly saturated.
You can try to include a 5-10 ohm series resistor in the primary winding.
The heating of the transistors is most likely caused by the amplifier oscillation due to its primitive and unsuccessful circuit design.
And very poor PCB layout.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
