First post, by keenmaster486
The only way to increase the system memory on many 8 or 16 bit XT/AT systems is to use expansion cards.
Just talking about conventional memory here.
Does the memory on these cards appear identical to the memory on the motherboard from the CPU's perspective? Is there a difference in access time - extra wait states for example?
I'm asking this because I'm looking into "PC Sprint" solutions for overclocking a 5150 or 5160, and I'm wondering whether using an expansion card for RAM will be a hindrance to achivieving higher clocks.
World's foremost 486 enjoyer.
Reply 1 of 5, by wierd_w
IIRC, on XTs and 286s, the ISA bus runs at the system bus speed anyway.
The issue is more with waitstates on talking on the expansion bus, than with the clock rate. That's my understanding, anyway.
Other possible issues with cache operation, i'd think.
Reply 2 of 5, by maxtherabbit
On true IBM PC/XT the expansion card RAM performs identically to the motherboard memory. On the true AT, the same is also true provided you are using a 16-bit expansion card.
For turbo XT clones and AT clones it totally depends on the motherboard.
Reply 3 of 5, by jakethompson1
The RAM ISA card can also impose its own additional wait states too though, right? But presumably there are DIP switches or jumpers to avoid that.
Reply 4 of 5, by maxtherabbit
Yes absolutely, though I've yet to see one which would impose them by default on a stock speed IBM
Reply 5 of 5, by keenmaster486
I’m going to have to check my cards and see about the wait states.
In my 5150 I have an AST SixPakPlus, but I’m planning on putting a Monotech MicroRAM in a 5160.
