Reply 740 of 1179, by nd22
All tests between the 2 processors with the same clock speed but with different FSB are finished!
While it was obvious that a FSB 333 processor is better than a 266 one the question is: how much better? Is it worthwhile to spend some money to upgrade from a Athlon XP 2000 to a Sempron 2400?
The answer is YES! The Sempron is 6.72% faster than the Athlon XP. While both are based on the Thoroughbred core having a 333 MHz FSB makes a difference that can be felt, especially in games!
Also taking into account that Sempron is considered a low end part and Athlon XP is considered a high end part on socket 462 the prices for Semprons are actually lower!
Of course there are Athlon XP with a 333 MHz FSB that are better than any Sempron but if you got a 266 MHz processor than it is worth to change it to a Sempron.
