First post, by Alegend45
I've been wondering about this since I was wanting to try to emulate a hyper-fast Voodoo 1 in PCem, but I want it to be at a speed that actually existed back in the day.
Reply 1 of 11, by bjt
Someone will be along to disprove me shortly, but I believe they're all clocked the same by default. Same with the Voodoo2.
Reply 2 of 11, by Tetrium
There could've always been a factory overclocked model of some sorts. I did do a bit of quick reading and apparently all V2s came with 100MHz clocked memory anyway (though usually clocked at 90MHz).
My retro rigs (old topic)
Report spammers here!
Reply 3 of 11, by Putas
Never seen anything else than 50 MHz for Voodoo1. But I recall some vendor using 95 MHz on Voodoo2.
Reply 4 of 11, by Alegend45
Well, is it even possible to overclock a Voodoo 1? If so, how high can you go?
Reply 5 of 11, by Tetrium
Dunno. Iirc the Diamond Rendition 2100s could be overclocked by powerstrip? They are about the same era so perhaps the V1 could be overclocked using that program (I wouldn't recommend overclocking a V1 though, seems kinda pointless, but that's just me)
Reply 6 of 11, by colpoz
It's possibile to overclock a Voodoo1 by adding the command "SET SST_GRXCLK=xx" in Autoexec.bat. xx is the frequency in MHz.
Diamond Monster 3D driver has an option to automatically set it to 57 Mhz!
RetroPc I: Asus P3V4X - PentiumIII 1000MHz - 256MB Ram - Geforce3 Ti 200 - SLI VoodooII 12MB - Aureal Vortex2 - HDD 80GB - Win98 SE
RetroPc II: Asus P5A - K6-2 333MHz - 64MB Ram - Geforce2 MX - Voodoo 4MB - Soundblaster AWE64 - HDD 13GB - Win95
Reply 7 of 11, by Putas
Usually not more than 10%, early 3dfx hardware was pushed to the max.
Reply 8 of 11, by Imperious
I've ran mine on 58mhz without problems. I wouldn't dare push it further without a heatsink attached though.
Reply 9 of 11, by rasz_pl
60MHz was reachable according to http://www.tomshardware.com/reviews/real-thing,45-2.html
The two 3Dfx Voodoo cards were both clocked to 60 MHz, which is just fine in case of the Canopus Pure3D with its 35 ns EDO RAM but beyond good or bad for the Diamond Monster 3D unless you cool it. I did this only for comparing the drivers of these two cards to each other, the Monster shouldn't run higher than 57 MHz and hence in real world it's slower than shown here.
Reply 10 of 11, by Postman5
Hey!
It looks like the factory frequency settings of the Voodoo1 are set by the strap resistors. Is there any program that can determine what frequency the Voodoo1 operates at, as set by the manufacturer?
