Reply 1400 of 1910, by Linoleum
- Member
Sly_Botts wrote on 2025-04-30, 17:31:I do have a question if someone can help. If I want to use an mt-32 with the picogus, do I need to set it to MPU-401 mode? Is it possible for it to emulate the Gus while also using the midi out? Or is it just one or the other?
Yup, GUS mode with MPU-401 support is possible! The compatibility table says MPU401 is in every mode: https://github.com/polpo/picogus/wiki/Configu … ng-your-PicoGUS
I believe "pgusinit /?? | more" should guide you in your setup...
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
