First post, by mdanh2002
I would like to introduce Super 8086 Box, my home-built PC XT emulator for Windows which was developed based on 8086 Tiny Plus source code by Jaybert Software (https://jaybertsoftware.weebly.com/8086-tiny-plus.html)
My build of Super 8086 Box has support for Adlib sound card, Disney Sound Source / Covox Speech Thing, NE2000 networking and joysticks. The integrated debugger has also been improved, with a better interface showing register and flag values, patching port/memory addresses, as well as options for viewing/dumping raw memory and disassembly. A CPU emulation bug with the REP INSW instruction (which caused issues with various NE2000 drivers) has also been fixed. An experimental full screen mode has also been implemented. This version uses Win32 API for graphics/sound playback only - support for SDL has been removed.
A write-up on the project which explains the changes that I have made can be found here: https://www.toughdev.com/content/2023/08/supe … ne2000-support/ . The same article also provides links to download the executable for Super 8086 Box as well as Visual Studio 2015 source code. Super 8086 Box can be started by running Super8086Tiny.exe from the archive. A bootable floppy disk drive as well as a 256MB hard disk image with various DOS programs is also included.
Attached some photos of Dr Hardware showing the emulated sound devices, Microsoft Network Client correctly mounting a Samba folder shared by my router, and of the improved integrated debugger.
Building software & hardware: https://www.toughdev.com/
