Reply 1200 of 1263, by sqpat
I have a question about the sound buffer size in FastDOOM. I see a 16x buffer (NumberOfBuffers) instead of a standard double buffer used. I'm wondering what led to that decision? I've looked into the SB mixing code and its not clear to me that it has any kind of advantage. Is it maybe non-soundblaster related or am I missing something?
Reply 1201 of 1263, by ViTi95
That value is the default for the Apogee Sound System. I'm not exactly sure why they use 16 buffers for sound mixing. Maybe it's set that high for sound cards that require multiple samples to be prepared in advance before being sent to the device. For example, the Disney Sound Source could receive up to 14 sound packets.
https://www.youtube.com/@viti95
Reply 1202 of 1263, by vsharun
Hi, any chance to set target aspect ratio for resolution ? And 1600x1200 please ?
Love to play doom with ESS1868/wp32 (LPC2ISA project) on i5-4690k @4.5GHz, some 300-ish fps 1280x1024.
Reply 1203 of 1263, by ViTi95
Yes, adding 1600x1200 resolution is possible, but proper aspect ratio support is not currently planned.
Reply 1204 of 1263, by 7F20
ViTi95 wrote on 2025-05-09, 06:49:
Because 320x200 is 1.6 and 1600x1200 is 1.33 I supposed. It integer scales, but only if you use 5:6.
Reply 1205 of 1263, by zyzzle
But wouldn't that mean that the only "true" upscaled ratio, then is 640x400 (1.6:1) or 1280x800, since it maintains the 1.6:1 ratio? Others such as 800x600 (4:3), 1024x768 (4:3), 1280x1024 (1.25:1) are also not in the 1.6:1 "native" aspect ratio. Or, am I missing something and you do integer scaling AR correction on those other supported VESA resolutions?
Do you account for pixel aspect ratio or screen aspect ratio? It's a confusing issue, since all of the above resolutions could be actually displayed in a 4:3 AR on a regular CRT screen.
Reply 1206 of 1263, by vsharun
zyzzle wrote on 2025-05-10, 03:45:
My question was about "fit" resolution to the panel aspect ratio. While 320:200 is 16:10, other hires SVGA modes are 4:3 = vertically compressed on 16:10 screen, more on 16:9. And my thought was: if we have one 16:10 mode and lot of 4:3 then we have some geometry correction in place and under-the-hood tunable may be wired outside.
Reply 1207 of 1263, by 7F20
Doug Johnson did the VESA modes, not viti95. My assumption would be that Johnson would have had to make each resolution available to the native renderer of the Doom engine, and the engine took care of PAR. So I think that probably would be an outside request to Johnson to make a new VESA resolution available, not to viti95.
Look back around January of 2024 when the VESA resolutions got added. I asked a bunch of questions about it then.
Reply 1208 of 1263, by ViTi95
I can add new VESA modes, in fact I already did this for the 1280x800 resolution executable. The main issue is that I don't have any native 1600x1200 display, so I'd need to test it using emulators.
EDIT: Already working on it 🤭
The attachment dos4gw_001.png is no longer available
Reply 1209 of 1263, by mockingbird
ViTi95 wrote on 2020-06-23, 23:06:
<snip>
The main differences between the original Doom and FastDoom are these (as of version 0.4):
How difficult would it be to add CMOV support (and possibly MMX+SSE) to Fastdoom?
Hear me out please: Yes, I know this is supposed to be for old machines - but lately you have released new executables... I find the FDM768R particularly attractive -- 1024x768 looks very crisp on a native LCD whereas lower res modes are blurry. The trouble is, even with write combining enabled, you need an extremely fast processor to get a consistently good FPS -- either an extremely fast P4 or K7/K8.
Conversely, Quake in software rendering mode easily reaches near 100FPS with a decent setup (in my case, Tualatin 1.4Ghz) because Quake uses more modern CPU instructions...
I often find myself wanting to play Doom when I have pure DOS mode but find this limitation prohibitive.
Perhaps it's time for some new executables?
Thanks
(Decommissioned:)
Reply 1210 of 1263, by leileilol
Quake wasn't using 'more modern' instructions. Also how quake renders is extremely different from how Doom does it - all the lighting is applied to a surfacecache, and that blob of surfacecache is where all the optimized spans work from. If you want to see that in action for Doom, there's Vavoom.
Also I believe leveraging the FPU was already explored with no resulting gain.
Debian's fucked
Reply 1211 of 1263, by mockingbird
leileilol wrote on 2025-05-13, 00:59:
What about compiling with CMOV? Surely that's going to vastly improve integer performance on newer CPUs, no (forgive my ignorance please)?
(Decommissioned:)
Reply 1212 of 1263, by 7F20
I remember watching a youtube video about this awhile ago. IIRC, Doom is coded using fixed point math operations, so it can't be made to speed up with an FPU. Quake was specifically created to take advantage of the Pentium's fully pipelined FPU, and the code is optimized for that kind of math.
AFAIK, it's not as simple as tossing things into a different compiler, it would be a fundamental change to the underlying code.
There is a really great video that explains the difference between Fixed Point and FP in coding: https://youtu.be/i1phJl-0v54?si=32dhy5utfwQSL45V
Reply 1213 of 1263, by ViTi95
I have some ideas to improve the performance of hires VESA modes. First of all, I plan to add again non-unrolled drawing functions for columns and spans (selectable). I'm quite sure the unrolled code becomes too large at higher resolutions, which likely causes a performance hit on CPUs with small L1/L2 caches. As for newer instructions, I believe MMX could offer a good speedup. Not just because of its SIMD capabilities, but also thanks to the additional registers it provides.
EDIT / Slightly OffTopic: Development has slowed down a bit lately, as I'm currently focused on other side projects, this time unrelated to retro hardware or programming. In fact, I'm now doing endurance racing in a '97 Civic 😄
The attachment 54487944082_3dffe4a79c_5k.jpg is no longer available
Reply 1214 of 1263, by mockingbird
ViTi95 wrote on 2025-05-13, 16:04:
<snip>
I eagerly await this 😀
(Decommissioned:)
Reply 1215 of 1263, by digger
Quite a change of pace, in more ways than one. 😅
Have fun, and stay safe!
Reply 1216 of 1263, by 7F20
That's amazing. I am working on a 91 Civic with a friend currently; hope to make it rally worthy.
Reply 1217 of 1263, by analog_programmer
Any chance we'll ever see a FastDoom version/port with 286 support trough something like DOS|286 (TNT DOS) Extender or DOS/16M?
I know about Doom8088 and RealDoom ports, but they still seem so immature.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 1218 of 1263, by rasteri
analog_programmer wrote on 2025-05-14, 08:22:
Fastdoom is written is for 32bit processors, it doesn't really make sense to have 16-bit binaries compile from the same codebase. It would just be a total mess.
Reply 1219 of 1263, by analog_programmer
rasteri wrote on 2025-05-14, 09:01:
I thought it's mainly written in C, not 32-bit specific assembly.
