NVIDIA Kepler/Maxwell/Pascal VESA Bios Bug (workaround found)
Reply 100 of 116, by RayeR
Yes, it is possible to trap only specific VBE subfunctions and emulate them some way. But one need to know GPU in detailed to reimplement it or if there'se no HW equivalent functionality in GPU it would needed to be SW emulated - very slow. Then it's better to tell the application that function is not supported to don't use it if possible (this is how simply Falcosoft did it).
Reply 101 of 116, by ruthan
About using Linux source code, Intel and AMD moved to fully open source drivers long time about.
There were some changes in the last 2 years.
I read that previous trash Nouvea driver for Geforce 9xx and 10xx is now good overall performance in 3D which is still great, average FPS are good, but is stuttering, its 10 month old report, but nowest, which i found:
https://www.reddit.com/r/linux_gaming/comment … ver_perfomance/
Im usually looking for Phoronix tests, found only old test:
https://www.phoronix.com/review/nouveau-kepler-2021/2 - Kepler test, finally patches to get not boot, but 3D clocks when its needed - performance is like 30% to 80% ~60% on average what is quite too. Im not sure what real clock has card in Windows 9x, if 3D clocks are activated, or it runs in boot slimmer mode.
i have found is from the 2019, where performance is abysmal: https://www.phoronix.com/review/nvidia-nouveau-2019/2
I searched more and only found out that Nouvea project leader resigned in 2024 due classic Linux toxic environmental issues.
same for new Vulkan implementation: https://www.phoronix.com/review/nvk-vulkan-performance/2
Also Nvidia released their own open source drivers for Linux, its better than be better, kernel part is open source and user space part its using there closed source firmware blob, some overview is here:
https://arstechnica.com/gadgets/2024/07/nvidi … kernel-modules/
https://developer.nvidia.com/blog/nvidia-tran … kernel-modules/
Well its not simple like other devices drivers, because if on wrong gpu these drivers have like million lines of code and they are a lot of per game basis adjustment..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 102 of 116, by LSS10999
ruthan wrote on 2025-05-12, 17:37:
About using Linux source code, Intel and AMD moved to fully open source drivers long time about. […]
I heard about the new, open nVidia kernel drivers before. It's not useful for older cards.
I think at least Turing is required for those drivers, and the VGA BIOS on Turing has become too broken to be of any good use. Games like Titus the Fox would simply give a garbled text-mode screen (can exit with ESC however), suggesting a failure in some crucial VGA BIOS calls.
Nouveau's usefulness is limited. From my experience on newer cards (e.g. Fermi), resolutions with higher refresh rates (e.g. 120Hz) can only be attained with the proprietary driver. It may be useful for some older, pre-CUDA video cards, however.
Reply 103 of 116, by ruthan
It seems that olders card supported by Nvidia Open drivers is Geforce 1650 source https://github.com/NVIDIA/open-gpu-kernel-modules, but could argue that its very similar to 10xx cards, which are not far from 9xx. You dont need drivers for exact card to reuse a lot of source code to help you with development.
Nouveau driver are not great, but are still much better than start from the scratch and they seems to have much smaller code base, to start.
I hope that sooner or later will someone to 9x driver for modern cards, i could happen this year, or it could take 10 years we will see.
Reply 104 of 116, by RayeR
I think that even 2D drivers are too complex (compated to oss/alsa linux sound drivers) and it would take so many mandays to port it to win9x. Scitech did own drivers in the past but it didn't bring them profit for that effort so stopped it...
Reply 105 of 116, by ruthan
In theory there is maybe one other way how to it - use Nvidia HW driver only for putpixels in 2D GDIplus and settings videomodes and use PCem/86Box code doing all graphics magic in software by CPU, but it would still need putpixel with decent speed, there is even some proof of concent how to use multicore cpus from Rloew, so it could run on not used cpu cores.
Or maybe use Swiftshader for the same, but it would still need a lot of work.
Reply 106 of 116, by Marco Pistella
I own a Nvidia GT740 affected by this bug and I can confirm the issue on that card. Tracing the INT 10h execution through the BIOS in real mode reveals that function 4F07h is imply absent from the ROM — the function does not exist at all, likely cut due to the limited ROM space available for VGA legacy emulation on modern Nvidia GPUs. This is probably also one of the reasons why support for this function was dropped in the first place.
My proposed solution is a real-mode TSR that intercepts INT 10h function 4F07h and reimplements the missing functionality. The main technical challenges are:
1) On these GPUs, CRTC registers above index 19h are not accessible with a single key — they require a 32-bit unlock sequence via port 3CAh. Using this unlock causes the VGA emulation subsystem to enter an inconsistent state, which adds complexity to the implementation.
2) The first 16 bits of the display start address follow the standard VGA registers, but the upper bits require direct MMIO access via BAR0 in the card's PCI address space. This requires Unreal Mode for 32-bit addressing. The procedure, implemented via the GS register:
- Save the current GDT for GS
- Load a minimal Unreal Mode GDT for GS
- Locate BAR0 in PCI config space
- Write the display start address via MMIO registers
- Restore the original GDT for GS
3) The TSR will also disable PM/32 support via function 4F0Ah to force any caller to fall back to 4F07h.
4) BL=00h (Set Display Start), BL=01h (Get Display Start) and BL=80h (Set Display Start during retrace) will all be handled. On these cards 3DAh bit 3 works correctly, so retrace synchronization via BL=80h should be feasible.
I have identified the unlock key and the BAR0 access procedure on my GT740, but full technical feasibility is not yet confirmed across the Kepler/Maxwell/Pascal families
— this is precisely why I am looking for betatester with affected cards before committing to the full implementation.
This is not a trivial undertaking and I am not making any promises. If the implementation proves feasible, source code will be published on this forum.
Is anyone available with a Kepler, Maxwell or Pascal card willing to test?
Reply 107 of 116, by Falcosoft
Marco Pistella wrote on 2026-05-02, 12:12:
Hi, […]
I still have 2 Maxwell cards in active use: GTX 960 and GTX 970 so beta testing is not a problem.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 108 of 116, by Marco Pistella
Falcosoft wrote on 2026-05-02, 13:01:
Hi, […]
I will get back to you when I have something concrete to test.
Thank you for the availability.
Reply 110 of 116, by EduBat
I have a GTX650, BIOS version 80.07.35.00.60, from 2012, which is affected by the bug. Will be happy to test.
Reply 111 of 116, by RayeR
Still have GTX 970 and 670 and some 730 or 745 for testing.
Reply 112 of 116, by Marco Pistella
Preliminary test for a possible VESA 4F07h implementation
on Nvidia Kepler/Maxwell/Pascal
As a first step toward a TSR that implements the missing
4F07h function on affected Nvidia cards, I have written
a small test program that checks whether the standard VGA
CRTC registers 0Ch/0Dh are functional and produce an
actual hardware scroll.
Test sequence:
1) Opens video mode 640×480×8 via function 4F02h/101h
(error if the mode cannot be opened)
2) Reads the horizontal scanline via function 4F06h/BL=01h
(error if not supported)
3) Draws two white pixels in the top-left and top-right
corners of the screen
4) Waits for a keypress
5) On keypress, writes a 1-pixel vertical offset to CRTC
registers 0Ch and 0Dh
6) Verifies that the registers actually accepted the new
values (error if not)
7) Betatester verification: the two white pixels MUST
disappear from the screen. If they do not, the VGA
registers are present but the display hardware is not
reading them — which means the CRTC approach is not
viable for that card.
😎 Whether the pixels disappear or not, please report
the PCI_ID of the card and the legacy BIOS ROM version
if available.
Note on step 7: a card can accept the register values
(step 6 passes) while the display hardware ignores them
completely. This is the critical distinction. If the dots
do not disappear, the VGA registers are present but
disconnected from the actual display controller, and the
entire TSR approach via CRTC 0Ch/0Dh is not viable for
that card. The viable fallback in that case would be
direct MMIO access via BAR0 — a more complex path that
will be explored if necessary.
My result:
Card: Nvidia GeForce GT740
PCI_ID: PCI\VEN_10DE&DEV_0FC8&SUBSYS_0FC810DE&REV_A1
Legacy BIOS: 80.07.DF.00.03
Func 4F02h: OK
Func 4F06h: OK
CRTC registers 0Ch/0Dh: accepted and verified
Hardware vertical scroll of 1 pixel: working
The GT740 passes all steps including the visual
verification. Looking forward to results on GTX 960,
GTX 970, and any other Kepler/Maxwell/Pascal card
available.
Source code:
	.386
CODE SEGMENT PARA PUBLIC USE16 'CODE'
ASSUME CS:CODE,DS:CODE,ES:CODE,SS:CODE
ORG 100h
start_code:
mov ds: word ptr [fail_msg_pointer],OFFSET fail_message_01
mov ax,4F02h
mov bx,101h
int 10h
cmp ax,4Fh
jne exit_fail
mov ds: word ptr [fail_msg_pointer],OFFSET fail_message_02
mov ax,4F06h
mov bx,1h
int 10h
cmp ax,4Fh
jne exit_fail
dec bx
push 0A000h
pop es
mov es: byte ptr [0h],0Fh
mov es: byte ptr [bx],0Fh
xor ah,ah
int 16h
mov ds: word ptr [fail_msg_pointer],OFFSET fail_message_03
mov dx,3D4h
mov al,0Dh
out dx,al
inc dx
mov al,bl
out dx,al
dec dx
mov al,0Ch
out dx,al
inc dx
mov al,bh
out dx,al
dec dx
mov al,0Dh
out dx,al
inc dx
in al,dx
cmp al,bl
jne exit_fail
dec dx
mov al,0Ch
out dx,al
inc dx
in al,dx
cmp al,bh
jne exit_test
xor ah,ah
int 16h
exit_test:
mov ax,3h
int 10h
mov ax,4C00h
int 21h
exit_fail:
Show last 17 lines
	mov	ah,9h
mov dx,ds: word ptr [fail_msg_pointer]
int 21h
jmp exit_test
fail_message_01:
DB 'Fail 4F02h',0Dh,0Ah,'$'
fail_message_02:
DB 'Fail 4F06h',0Dh,0Ah,'$'
fail_message_03:
DB 'Fail set/get VGA regs',0Dh,0Ah,'$'
fail_msg_pointer:
DW ?
CODE ENDS
END start_code
Reply 113 of 116, by Falcosoft
Marco Pistella wrote on Today, 08:29:
Preliminary test for a possible VESA 4F07h implementation on Nvidia Kepler/Maxwell/Pascal […]
Test sequence:
if available.
Geforce GTX 970 - BIOS version: 84.04.84.00.29
PCI\VEN_10DE&DEV_13C2&SUBSYS_31611462&REV_A1
1. After running the test 2 pixels appear in the top left/right corners of the screen.
2. After a key press both pixels disappear.
3. After another key press the program quits nicely.
So it seems the test was successful on this card!
@Edit:
Geforce GTX 960 - BIOS version: 84.06.0D.00.6E
So it seems the test was successful also on this card!
Website, Youtube
Reply 114 of 116, by Marco Pistella
Falcosoft wrote on 57 minutes ago:
Geforce GTX 970 - BIOS version: 84 ...[CUT]
Thank you — this is exactly the result I was hoping for.
GTX 970 (Maxwell 2.0), BIOS 84.04.84.00.291: CRTC
registers 0Ch/0Dh confirmed functional, hardware scroll
working.
Combined with the GT740 result, this confirms that the
CRTC approach is viable on at least two different Nvidia
cards across different generations. The TSR implementation
via registers 0Ch/0Dh is now the primary path to pursue.
Could you also run the test on the GTX 960 when you have
a chance? Having both Maxwell cards confirmed would be
very useful before starting the full implementation.
Reply 115 of 116, by Falcosoft
Marco Pistella wrote on 50 minutes ago:
Thank you — this is exactly the result I was hoping for. […]
working.
Meanwhile I edited my previous post but here is the result:
PCI\VEN_10DE&DEV_1401&SUBSYS_36901458&REV_A1
Website, Youtube
Reply 116 of 116, by BolenB
Gigabyte Geforce GTX 1070 Ti - BIOS version: 86.04.85.00.A0
PCI\VEN_10DE&DEV_1B82&SUBSYS_37941458&REV_A1
