Yamaha YMF7x4 Guide
Reply 340 of 358, by Tiido
1) YMF71x uses two DMAs and two IRQs, referred to as A and B, which can then be assigned to any of the available physical DMA or IRQ channels.
2) The software loads AUTOEXEC in memory to modify it there instead of scanning through the file and trying to insert and shift stuff that way. It has a 32KB byte limit because of that. A file this big will be full of bunch of stuff and since the program will only try to update the first entry found, it is highly unlikely it is the right entry in a file this big with many confs in it, so you're definitely better off with manual update to the settings suggested by software.
3) That seems most strange...
4) YMF71x has no kind of SB16 compatibility, if you want 16bit sound you have to use WSS instead.
Reply 341 of 358, by digger
Tiido wrote on 2025-01-12, 03:28:
Do you know if the YMF71x chip has register-level compatibility with the Analog Devices AD1848 chip?
I'm asking this, since some DOS games that claim to support WSS only seem to do so on the AD1848. This apparently includes Impulse Tracker, as well as DOS games that use DIGPAK drivers.
See the following links for more info on this issue:
- This comment by @CarlosTex on GitHub
- This Vogons thread that he referred to in that GitHub comment, about 640K!enough patching Impulse Tracker to support more WSS hardware implementations
Reply 342 of 358, by Tiido
It is register compatible with CS4231 which in turn is compatible with AD1848, in Mode1 which is the compatibility mode.
CS4231 extends original AD1848 with more inputs and few other things, that are available in Mode2 which enables the extensions via 16 more registers over the existing 16. Mode2 is selected in software that is aware of it, and it shouldn't break compatibility with any stuff expecting only the first 16 registers.
Reply 343 of 358, by digger
Tiido wrote on 2025-01-13, 15:31:
I learned something new. Thanks for clarifying. Is the same true for the OPL3-SAx chipset? And do you know why neither CS4231 nor OPL3-SAx work with Impulse Tracker and DIGPAK drivers out of the box, without apparently needing some patching? Maybe because the detection routes rely on certain specific timings and/or other undocumented behavior that is unique to the AD1848?
Reply 344 of 358, by Tiido
YMF71x is the OPL3-SAx series. The PCI YMF724/744/754 chips that this thread is about, are not having any sort of WSS compatibility 🤣.
I have no idea why there would be any incompatibility, perhaps they check the ID register and reject any values they don't recognize...
EDIT: But there's one part that is not part of the Codec chip itself but additional stuff below the codec addresses that show the WSS card conf, where current IRQ and DMA confs can be read. This part varies from card to card and it can be that the software in question explicitly relies on that info rather than any manual conf and environment variables.
Reply 345 of 358, by ruthan
Thx for quick replay.
Im still confused, its not actually straight forward.. Are these IRQ some internal card MB assignments? or they are meant for emulated SB card IRQ - so make sense to set 5 and 7 IRQ and DMA 1 or 5, if not it make sense to set some different values to keep IRQ 5/7 free.. Or A is for emulated IRQ and B is for real machine actual IRQ card assigment?
Im used to this situation, utilities usually write code at the start of autoexec.bat and config.sys, so i can late easy integrate the code and copy it at the right place. Second scenarios is search for some specific line and adjust it or put it before / after.. this works too, but its a bit more messy especially if they not print detail what where was changed.
Other and more clean solution would be just print needed code in some *.txt or other filename like autoexec.YMH or Config.YMH and tell user to copy it at the right places. Important are exact commands, not integration of it to existing conf files..
Board out of test bench, later i got idea that problem could be video card too, Warcraft 2 with quite picky with Vesa 2.0 cards, but problem is usually black screen, not ASM DOS/4 extender crash report.
Its strange, because with all these SB emulation card, they is usually mention that SB PRO 2 not SB 16 is emulated, but for lots of games SB16 check is passing and sound is working. They are even games which are running only with SB 16 option, but not SB Pro(2).
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 346 of 358, by Tiido
YMF71x chipset has several components : SB, WSS, OPL3 and MPU401, all of which can produce IRQs. The card can use up to two physical IRQs to signal these sources, so each of the 4 internal components can be connected to either A or B interrupt, which in turn can connect to a physical IRQ on the ISA bus. There's no emulation, only routing of signal from point A to point B. Same with DMA channels, which have 3 sources : SB, WSS playback and WSS recording.
In case of SETYMF, the exact command is just SETYMF.EXE /INITONLY with the current EXE location as path in front of it. If you want anything extra you consult the readme file and supply any of the additional command line switches.
Many SB16 games silently fall back to SBpro if they find DSP 3.x instead of DSP 4.x, such as Duke Nukem 3D. The card absolutely cannot do any of the SB16 commands nor has any means to do high DMA channels.
Reply 347 of 358, by ruthan
Ok thx and what are recommended settings pro IRQs, when you have option to make all IRQ free?
I mean, set SB, OPLS and MPU-404 to A- IRQ 5 /7.. and WSS to B any other free IRQ, or some is prefered (i have tried to google WSS default IRQ it seems 7 too)? If not wrong original SB cards are using just 1 IRQ for all. What would happen when you try to set all 4 devices to one IRQ?
Reply 348 of 358, by Tiido
Most games expect IRQ 5 for SB but older ones do want it on 7. True WSS doesn't support IRQ 5 at all and starts at 7. Games that really care about MPU401 want IRQ9 but majority of games don't need the IRQ functionality. Original Adlib had unpopulated IRQ selection header, and as a result no game can use IRQ capability of OPL2/3 chip, but I have exposed it still on the card software for whoevec might like to play with it but otherwise it should be kept off to prevent possible incompatibilities.
There's generally no problem making all of them use same IRQ, with the execption of MPU401 software that wants to use the IRQ, in which case there will be problems. Single IRQ operation is what whe windows driver does too.
Reply 349 of 358, by richardoswald
First Post! I have a YMF724 Labway "A301-G50" and successfully have sound blaster emulation working using DSDMA on my G41 chipset board. I get sound in Jill of The Jungle and Wolfenstein 3D and it's awesome! But how do you mix in other audio inputs supported by the card? Right now I'm trying to get PC Speaker sound into the sound card, using Space Quest to test. There were no pins so I had to solder them in on the card. I tried using the SBMixer supplied w/ SB16 but I'm guessing I can't use that since it looks like DSDMA is emulating a SB pro? Eventually I'm going to need to also mix-in cd-sound but one thing at a time I guess. I hope it's possible to mix-in these audio inputs while using DSDMA at the same time.
AUTOEXEC.BAT:
C:\DOS\SMARTDRV.EXE /X
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
copy C:\dos\drivers\ymf724\DOS4GW.EXE \
chcp 437
C:\dos\drivers\ymf724\SETUPDS.EXE /S
del \DOS4GW.EXE
C:\DOS\DRIVERS\YMF724\DSDMA.EXE
SET BLASTER=A220 I5 D1 T4
MSCDEX /D:MSCD001 /V
CONFIG.SYS:
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
DOS=HIGH
FILES=30
DEVICE=C:\CDPRO\VIDE-CDD.SYS /D:MSCD001
Reply 351 of 358, by richardoswald
cyclone3d wrote on 2025-05-13, 05:30:
Run SetupDS and it will launch the configuration / mixer GUI.
Or you can edit the DS.ini file directly.
Thanks for the reply! I enabled PCBEEP in SETUPDS but I can only set zero or negative values, similar to Master volume (I also edited the DS.INI to say 50 but it set's it to a negative value again in SETUPDS).
DS.INI:
LEGEN=1
SBIO=0
SBIRQ=0
SBDMA=1
MPUIO=0
MPUIRQ=0
JOYIO=0
INTAIRQ=11
IRQMODE=1
DMAMODE=3
FIRSTTRY=0
SLAVEBASE=0
SLAVEADDR=0
LEGMAS=77
VOICE=77
FM=77
MASTER=0
MONO=8000
PCBEEP=0
PHONE=8008
MIC=8008
LINE=8808
CD=8808
VIDEO=8808
AUX=8808
PCM=808
SBFILE=YMH8.WAV
NAFILE=YMH16.WAV
FMFILE=YMH.MID
PIRQRC=0
LOADTSR=1
IRQSHARE=0
Reply 353 of 358, by shevalier
Perhaps this information will be useful to someone.
Cards on such a printed circuit board have a bug in the layout.
If there is no plug, the right output channel is shorted to ground.
The TEA2025 amplifier has no short circuit protection, so it starts going crazy with time remain.
It continues to play sounds, but reacts to all interference in the power supply.
It may seem like a "retro sound". 😀
And this only happens in one channel, the other channel - sound clean.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 354 of 358, by shevalier
shevalier wrote on 2025-05-31, 11:32:
Perhaps this information will be useful to someone. […]
yeah, the replacement completely fixed the problem.
However, the right channel switching contact in socket must be disconnected from ground.
Reply 355 of 358, by unix_junkie
Cross-linking for posterity: DOS drivers re-linked with DOS/32A (known to work better in the Real Mode, and not only in V86 Mode).
Reply 356 of 358, by lazalius
vorob wrote on 2023-08-17, 08:50:
Crackling may be caused by too high maximum volume. Sometimes it's because driver allows to set the volume too high, when it was taken from another card. With VxD drivers you may fix it in registry: HKEY_LOCAL_MACHINE\Software\YAMAHA\Driver\YMF724\VolumeMax, or by YMF7x4Utilities.
What exactly should I change here? Thx.
The attachment 105ADF37-AADB-49E2-8354-E1890ABE10D0.jpeg is no longer available
Sorry for the necro bump but this information may be useful for other people with this card. Changing the first byte in the blob at HKEY_LOCAL_MACHINE\Software\YAMAHA\Driver\YMF724\VolumeMax to 80 completely solved the crackling issue for me.
Reply 357 of 358, by marxveix
What about other VXD drivers for YMF, like 4.06.1026, is it good or bad vs 1031 / 1040?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 358 of 358, by gmaverick2k
I'm only getting cd music on right speaker (tested with shadow warrior and redneck rampage), normal sound is working through both. Changed the cd audio cable still same issue. Running the YMF 744B-V on a VT8235 (KS41G). Does anyone know how to get cd music through both speakers? I run a batch file at startup in real dos mode to run setupds /s and have changed ds.ini to have CDVolume = 15 15 as per googles advice but not working.
I dont have a clue what brand/model card this is
edit: Just checked cd audio in windows 98 with age of empires 2, cd audio works fine with both speakers. The issue seems to be in real dos mode only with music playing in right speaker only
found it: https://theretroweb.com/expansioncards/s/pine … hnology-pt-2629
https://theretroweb.com/expansioncard/documen … 33406260135.pdf
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
