First post, by Ragh
In the past I've had a problem getting my AWE 64 to output sound when used in conjunction with a MPU card. That issue was solved by changing the SB's 330 port to 300. (See AWE 64 no sound with mpu-401 isa card in DOS).
Now, I've purchased an IBM PC 330 433sx (486sx 33 processor, 3x isa slots, etc.), similar to this one: http://mastodonpc.tripod.com/personal/6571-l3b.html to which I have transplanted the aforementioned ISA cards. I am having similar issues where the AWE doesn't want to output any sound and MIDI via the MPU card works as expected. I have tried to setup the sound blaster card to the same settings as in my previous PC, but to no avail.
The CTCU utility reports that there is a conflict when selecting DMA 1 (DMA 1 conflicts with System Device settings). I can select wither DMA 0 or 3. I can't possibly find out which device is using DMA 1. I can't find anything in the BIOS config and I've been fiddling with motherboard jumpers by looking at a schematic label attached to the inside of the computer case. The only jumper setting mentioned in that schematic is "DMA CH1 ECP", but it doesn't do anything to free DMA 1 afaik.
Any one here with an IBM PC 330 or similar having successfully setup this?
Reply 1 of 15, by PeterLI
Reply 2 of 15, by Ragh
I have disabled both LPT and COM ports, so this shouldn't be an issue?
Reply 3 of 15, by PeterLI
Reply 4 of 15, by Ragh
Yes, the same problem happens if I either disable the LPT altogether or set it to "Standard mode" instead of "Extended mode".
I am using a MPU 401 ISA MIF IPC clone card (the one selling cheap on eBay: http://www.ebay.com/itm/MPU-401-INTELLIGENT-I … =item3ceabb3ee5).
Perhaps another thing to note is that I still can't get any sound (in games) out of my SB card, no matter what IRQ/DMA settings I choose.
Reply 5 of 15, by Ragh
The attachment IMG_0010.jpg is no longer available
I've attached the schematic label found on the machine in case it helps. Does anyone know where can I find the manual for this PC?
Reply 6 of 15, by PeterLI
Reply 7 of 15, by Ragh
Thanks for the manual, even though this is for later pentium models.
Yes, I have a MPU-401 connected to the card.
Reply 8 of 15, by paulisthebest3uk
I know this is quite an old thread but did you ever sort this out? I have the same system and on mine, DMA channel 1 is also unavailable. I really need DMA 1 freed up so I can play on old games with full sound support such as Dyna Blaster...
Reply 9 of 15, by Ragh
Only seeing your post now, paulisthebest3uk and I haven't figured out the issue. I have since installed the AWE in another machine. I am waiting for a SB16 to arrive and will test the configuration with it once it arrives. Will report here.
Reply 10 of 15, by Ragh
Resurrecting an old thread, reporting finds from memory. Got a SB16 installed, the creative diagnose utility reports everything is ok, sound samples work fine. No game has any sound though.
Reply 11 of 15, by InbetweenDays
Thanks for the update. I've just been having the same issue. Win95 reports that the floppy drive controller is using DMA 1, not 2 as it should (and the setting cannot be changed). Device manager reports DMA 2 as being "in use by unknown device".
I wondered if it might be a Win95 issue, but CTCU running under DOS 6.22 also reported DMA 1 as being in use.
Interestingly though, the IBM diagnostics disk correctly reported DMA 1 as being free and DMA 2 being in use by the floppy controller.
(Diags disk: lkgt35a.exe found here)
Reserving DMA 1 in the BIOS doesn't help. I also tried updating the BIOS with no success (lejt67a.exe, same location)
So in the end I went back to a non PnP soundcard... jumpered with the usual settings (220/5/1/5). Everything works in DOS and Win95, even though device manager does report a conflict when you view the resource settings.
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
Reply 12 of 15, by paulisthebest3uk
Oh this thread is active again? Thats cool, yep it does seem DMA1 is handling the floppy controller, why that is i have no idea, at first i thought it was a bad motherboard in my machine, but as other people are having the same issue. The AWE32 ive been trying to use just doesnt work propelery which is annoying as its a really nice 486 machine
Reply 13 of 15, by evasive
We have the PC 330 6571 board listed here:
https://www.ultimateretro.net/en/motherboards/2944
If any of you could provide us with a clearer picture or at least chipset info that would be nice.
Reply 14 of 15, by paulisthebest3uk
Very old thread but even now I'm trying to work on this. I tried since writing my last post ages ago a non plug and play card and it was successful to a degree. You can sort of force CTCU to hold your DMA1 setting as long as you don't run ctcm and you put ctpnp.cfg as read only.
I know what people are thinking wow it's been a while but I am determined haha
Reply 15 of 15, by paulisthebest3uk
CTCU /s with ctpnp.cfg as read only will run at DMA 1 and 220h IRQ 5 with full support. I'm still under the impression DMA1 is being used by surepath bios or the motherboard for floppy drive somehow
I have learned using non PNP cards work a lot better such as the soundblaster value 16
