First post, by jude1977
HI, all
I've got a question in regards to using a 5.25 floppy disk drive with a windows 98 pc
the issue I'm have is that every blank floppy disk I use wont format when I try to format it.
It try's to start formatting when I use the write command but it always says cant format ,disk is damaged
it happens with every disk I use.
I've got a second older 386 pc with windows 3.1 and try formatting all the disks on that machine and they format fine
I'm just wondering would it be because I'm using a windows 98 pc that is causing the problem that the disks wont format
has any won had the same problem with using floppy disks with windows 98 pcs.
