Reply 40 of 45, by GunKneeNeon
leileilol wrote on 2023-12-04, 02:42:
Post-running results != displaying framerate
I got the info from this video.
The method posted by @noshutdown doesn't work for me. There is no white dot whatsoever, just some black grids.
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
Reply 41 of 45, by noshutdown
GunKneeNeon wrote on 2023-12-04, 03:20:
i said run: doom -devparm
then start a game and move around
Reply 43 of 45, by noshutdown
GunKneeNeon wrote on 2023-12-05, 04:49:
Yes, I did exactly that, but no white dot only the black grids there.
in devparm mode, you can also press f1(used to be help screen) to capture a screenshot in pcx format.
if you look more closely at the buttom left, you should be able to find out that there is only 1 white dot with all other dots being black because doom is running at optimum speed(35fps). if you are running on a 386 or low end 486 machine and the game is slowed down, more black dots would turn white.
Reply 44 of 45, by Calvero
GunKneeNeon wrote on 2023-12-04, 02:37:
For Doom I Timedemo: Start Doom with: […]
Start Doom with:
doom.exe -nosound -timedemo demo1
Replace demo1 with demo2 or demo3 for different timedemos.
It will give you a gametic number and a realtic number.
FPS = gametics / realtics * 35
Or use doomfps
Reply 45 of 45, by RayeR
Is there some timedemo alternative in Blood to run the engine at max possible speed to get max FPS?
On my core i7 in 1600 x 1200 when use T RATE I got average FPS about 50 during game play...
