First post, by kotel
- Oldbie
While back I got an 3com etherlink II assy #2227 with AUI and BNC. Since I already had an cheap realtek 8029 based card at hand, I've decided to make an RJ45-BNC conversion box using XP and test the 3com etherlink II card under 98se.
Since I'm doing this on a budget (the whole cable costs more than the setup is worth), I've decided to use my oscilloscope cable with 1x BNC on one side and two aligator clips on the other. All ends were terminated using 47ohm resistors (maybe it's time to use trimmers set to 50ohms?). I will try to replace it with an standard TV antenna cable and add the resistors for termination.
On XP I've set the correct IP address (192.168.0.1) and subnet (255.255.255.0) on the BNC card. For RJ45 card I'm using the onboard realtek card.
Now, the problem is with the 3com card. I have no idea what's wrong with it, but the DOS diag utilities can't find it on any IRQ. Even after reserving IRQ 5 for ISA in BIOS and turning off all extra devices (sound, FDC etc.) in BIOS I still can't get it to dected properly.
I have tried Damn Small Linux with
sudo modprobe 3c503 io=0x300 irq=5
(yes, the card IO is set to 300) and setting the correct IP address (192.168.0.2) and subnet (255.255.255.0) using
sudo ifconfig eth0 192.168.0.2 netmask 255.255.255.0 up
, I can't get any connection to or from the XP box to the client (DSL linux and 98se/DOS). I have confirmed that the driver is loaded under DSL and I can see eth0 in ifconfig.
I do not know whether the 3com is faulty or not. The RTL8029 is working, at least the RJ45 part. BNC is sending pings with the same interval when I add an 47ohm resistor according to the ACT LED.
Any ideas what might cause this? I doubt it's the cable but I might be wrong, my experience with BNC is close to 0 🙁
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
