First post, by Omarkoman
Photo:
https://i.postimg.cc/xnkch8Tw/IMG-2308.jpg
I used the little tables on the board to setup the dx33 and then dx2-50 but its not waking up when powered on so not sure what i am doing wrong and cant find the manual as there is no model no on the board.
Btw that frequency table from 25-50mhz, how does that work? If i have dx2 66 i set it to 33? If its dx2 50 then to 25?
Thanks
Reply 2 of 4, by Omarkoman
thats its ! thank you !
strange though, I have all the jumpers correct and cant get it to boot. Not having much luck last 24 hours, this is 3rd 486 motherboard that does not boot with few different processors. Tried 4-5 diff ISA and VLB video cards and lots of different RAM chips. Strange as they were all working few weeks ago when I was doing few tests. Suddenly, they just stopped, all three of them.
I'll have to do more torubleshooting later. I guess thats what happens with old hardware.
Reply 3 of 4, by bertrammatrix
Omarkoman wrote on 2025-05-17, 03:15:
Make sure the power supply is good and pins are making good contact. I had an AT one that one of them was iffy- no post until went over the wires one by one and pushed them in a little more
Reply 4 of 4, by Omarkoman
thank you for the tip, the power supply should works ok as I worked on few other boards but lets me try another one as thats one part I did not swap during testing.
