First post, by donluca4
Hi everyone,
my lovely Thinkpad X20 has died yesterday, it suddenly fried itself.
I'm now looking for another (cheap) laptop that has to meet the following requirements:
Light: max 1.6Kg
Small: less than 29cm x 23cm (12" or smaller screen)
Thin: less then 2.5cm
CPU: Pentium III
VGA: Directx6 support with at least 4MB of VRAM
Sound: no need for DOS support, but welcome
Price: ideally well below 100€
I'll be playing mostly D3D games from 1995 to 1999.
Most "known" brands have a heavy tax on them, mainly IBM and Sony so I'm trying to avoid them because they're really pricy.
Here are the candidates so far:
1 - IBM X40 in absolutely abysmal conditions, without PSU (which I already have), Hard Disk (not an issue) and battery (again, not a problem).
Unfortunately those are known for having their USB ports fried to lack of overcurrent protection, so this one, considering the condition it is, already makes me think that I'll have to buy a PCMCIA USB card.
The other Thinkpads I've found around are way too pricy.
This one is pretty affordable due to its conditions.
Specs:
26.8 cm x 21.1 cm x 2.0-2.7 cm, 1,24 kg
12.1", 1024x768
Pentium III-M 1.4Ghz
Integrated Intel Extreme Graphics 2
Intel 855GME chipset
2- NEC Versa S800.
Fits the bill, here are the specs:
28 cm x 22.2 cm x 2.2 cm, 1.1 kg
12.1", 1024 x 768
Intel Pentium III-M 933 MHz
Ali/Trident CyberALADDiN-T chipset
Trident CyberBlade XP
Comes without a battery, PSU (normal 19V one, I already have plenty) and Hard Disk.
This one has a really nice feature: stereo speakers!
The Hard Disk is a huge pain in the butt: it uses one of those Toshiba 1.8" drives with 50pin connector.
I can use a CF-to-IDE Adapter but I'd rather put a proper SSD in it.
Maybe I'll cook up something.
If it weren't for the HD situation, I would have picked it because it's lovely!
3 - Toshiba Portege 2000
A tiny bit expensive, but maybe I can drive the price down a bit. Specs:
28.9 cm x 22.9 cm x 1.9 cm, 1.2 kg
12.1", 1024 x 768
Intel Pentium III 750 MHz
This one is complete (batteries are dead of course).
It has the same hard disk situation of the NEC, but at least this one has the drive and it is shown working.
Right now it's my favorite because it's "ready to go".
I'm looking forward suggestions to add other notebooks to the mix, so please let me know if anything crosses your mind!
Reply 1 of 28, by donluca4
Forgot to add the specs of my X20 which was perfectly fine for the games I've been running:
279mm x 227mm x 23.8-27.9mm, 1.6Kg
12,1", 800x600
Intel Pentium III 600Mhz
Intel 440ZXM AGPset chipset
ATI Rage Mobility M (4MB VRAM)
Anything in this ballpark would be fine, although I'd prefer to have 8MB of VRAM if the screen is 1024x768.
Reply 2 of 28, by marxveix
ATi with 4mb or 8mb and 1024x768 resolution gaming not very well possible,
more like 640x480, max 800x600 should be fine, 1998 and 1999 games at least.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 3 of 28, by donluca4
I've played Croc, Shipwreckers, Thief and many other games on my X20 with ATI Rage Mobility 4MB at 800x600 with no issues!
Besides, the 3 notebooks I've listed have all way more powerful GPUs than the ATI Rage Mobility, so playing at 1024x768 should not be an issue.
Reply 4 of 28, by donluca4
I've just looked at some benchmarks comparing Intel Extreme Graphics 2 vs the Trident Cyberblade XP... and the difference is massive.
I've seen that in 3DMark 2000 the X20's Rage Mobility M scores ~500 points, the Trident ~1000 points... and the Intel ~3000 points.
Triple the amount of the Trident. Wow.
I would have never guessed such a difference.
Unless someone comes up with some alternatives I think I'll reluctantly go with the IBM Thinkpad X40... not that I need insane amount of GPU power, mind you, but I want to play those old games smoothly at the panel's native resolution without hiccups.
Reply 5 of 28, by Cosmic
I think the X40 is a good choice. The Pentium III-M is a great CPU, it'll be fast and takes a regular 44-pin drive, so should be easy to adapt to CF or mSATA. I had a slim 44-pin to mSATA adapter in an older Thinkpad and I liked it because it was the size/shape of a regular drive. Plus there are a lot of spare parts for it since it was a common business machine, so you could always fix up the cosmetics later if you like. I have a small ThinkPad collection and they're all enjoyable in their own way! I have a T42 which is very similar to the X40 and it's a good late 9x and Win2K machine.
UMC UM8498: DX2-66 SX955 WB | 32MB FPM | GD5426 VLB | Win3.1/95
MVP3: 600MHz K6-III+ | 256MB SDRAM | MX440 AGP | 98SE/NT4
440BX: 1300MHz P!!!-S SL5XL | 384MB ECC Reg | Quadro FX500 AGP | XP SP3
Reply 6 of 28, by donluca4
Thanks for chiming in!
Yeah, the X40 is definitely the superior machine to those I listed.
I'm still a bit bummed out that my Thinkpad X20 died out of nowhere so I'm a little wary.
I'm waiting for a reply from the seller of the NEC Versa to understand if they kept the zif to ide flex cable when they removed the hard drive because I'm still tempted by it.
1.1Kg!
It's as light as my 11" Macbook Air!
And it has stereo speakers! (which are going to be crappy, sure, but at least I have stereo sound)
I'm also looking at something very slightly bigger, the Toshiba Portege M300.
Like the other Portege, it is "complete" and ready to go and there are several available.
Specs:
28.6 cm x 23.3 cm x 2.9cm, 1.6Kg
12.1", 1024x768
Intel Pentium M 753 / 1.2 GHz
This is also pretty cheap, has stereo speakers and, thank god, a normal hard drive (should the included one fail).
It's pretty chunky though, at 2.9cm thickness.
At the end of the day, though, I think that weight plays a more important factor as I move often between two houses.
Here's a comparison of the size and weight of the ones mentioned so far:
X20	27.9 x 22.7 x 2.4	1.6 Kg
X40 26.8 x 21.1 x 2.0 1.24Kg
NEC 28.0 x 22.2 x 2.2 1.1 Kg
P2000 28.9 x 22.9 x 1.9 1.2 Kg
M300 28.6 × 23.3 × 2.9 1.6 Kg
Reply 7 of 28, by donluca4
Found another one which could fit the bill: the Dell Latitude X300, which also has stereo speakers.
Specs:
27.4 cm x 23.4 cm x 2.3cm, 1.32Kg
12.1", 1024x768
Intel Pentium M 1.2 GHz
Another small and light notebook, this one also comes with the hard disk (which the seller says it's working, but failing – or at least that's what Crystal Disk reports) and PSU and is ready to go.
Decisions, decisions...
I also wish there was an edit button to update previous posts.
Reply 8 of 28, by lolo799
donluca4 wrote on 2025-05-17, 12:08:
Found another one which could fit the bill: the Dell Latitude X300, which also has stereo speakers. Specs: 27.4 cm x 23.4 cm x 2 […]
Specs:
12.1", 1024x768
I have two X300, I'm not sure they're compatible with Win98, I never tried though, they're happily running XP at the moment.
Reply 9 of 28, by donluca4
lolo799 wrote on 2025-05-17, 13:59:
Then we'll find out together, because the seller sent me a fantastic offer slashing the price almost in half and I got the X300!
I've already done some research and it should be compatible, although I'm afraid it's gonna need quite a bit of help to get it up and running.
I'll open a new thread when it gets here!
Reply 10 of 28, by lolo799
The first problem I see with installing win98 with it is that the cd/dvd drive, whether in an external enclosure or in the dock, is usb only.
Of course you can remove the hdd but you have to dismantle almost the entire laptop which isn't very convenient...
By curiosity, how much did you pay for it?
Reply 11 of 28, by DudeFace
the x300 is too new for win98 so no gpu/audio drivers, was gonna say go for another thinkpad or at least a known popular brand, portability and reliability depends on the battery which is the most important thing to consider when buying a retro laptop, known brands are likely to use the same battery type across different models so will at least increase the chance of finding a replacement.
at the moment ive got a thinkpad thats running windows 98 and it does the job pretty well, specs are
Thinkpad R40
CPU: Pentium M (Pentium 4) 2.20GHZ
RAM: 512mb
GPU: ATI mobility radeon 16mb vram (Radeon 7000)
AUDIO: Analog Devices AD1981B SoundMAX (AC97)
the 16mb vram is what holds it back but its still enough to run max payne 1&2 at a playable speed which is good enough for me, the onboard audio is good for dos games in 98,
you have soundblaster and general midi, no FM synth. also using the cadenza soundmax audio driver it will give you enviromental effects and a softsynth with a yamaha XG lite and General midi soundset which partially works with dos games, better than the standard thinkpad audio driver and its ADIsynth.
i mainly use this for playing heretic, duke3d, doom, blood, monkey island 1/2, quake II, thief 1/2, etc. probably the most demanding games are max payne 1/2.
Reply 12 of 28, by donluca4
lolo799 wrote on 2025-05-17, 17:27:
There are a tons of ways around this and the X300 should support booting from USB from what I've read, so a bootable USB with DOS (you can do that with Rufus) and then copy over the contents of the Win98 CD and manually start setup.exe will do the trick.
USB CD Rom should work as well, you can slipstream the necessary drivers into the Win98 CD.
I also have a USB Floppy Drive which should work.
I've paid 50 euros included shipping.
It was listed for 65 + 20 shipping.
Reply 13 of 28, by donluca4
DudeFace wrote on 2025-05-17, 17:35:
This is not true, I have already downloaded them.
GPU: https://www.techspot.com/drivers/driver/file/ … formation/2505/
Audio: https://www.soundcard-drivers.com/drivers/129/129538.htm
Chipset: https://www.philscomputerlab.com/intel-chipset-drivers.html (scroll down, the latest one)
...and various others.
Some work might be involved to make everything work 100% but it's definitely doable.
Reply 14 of 28, by DudeFace
donluca4 wrote on 2025-05-17, 18:41:
This is not true, I have already downloaded them. […]
i missed the dell part 🤣 i thought we were talking thinkpads, in that case it should work fine for 98.
Reply 15 of 28, by donluca4
DudeFace wrote on 2025-05-17, 18:49:
Oh sorry about that!
You're absolutely right, the ATI X300.
It's been SEO hell trying to find drivers and information about the *DELL X300* due to the naming, 🤣.
We were talking about the Dell Latitude X300 because in the end I got one and lolo had two with Windows XP and he was wondering how hard it would be to get Win98 running on those.
After managing to boot the Thinkpad X20 recovery CD where I had to hex edit my way through the disc image to find the hook for the initial boot disk and modify it to inject custom USB drivers (the X20 doesn't support "normal" USB CD drives, let alone USB drives) I assure you this is going to be a piece of cake, 🤣.
@lolo799 do you know if the Dell X300 has screen expansion? Meaning that if you use a lower resolution it will stretch it to fill the screen or if it will have black borders.
Reply 16 of 28, by marxveix
donluca4 wrote on 2025-05-16, 15:25:
Dont get me wrong ATi Rage Pro architecture is ok, its from march 1997.
Reply 17 of 28, by lolo799
donluca4 wrote on 2025-05-17, 19:19:
You can choose to fill the screen or have black borders in the Intel Graphics properties screen.
The attachment 20250518_120357.jpg is no longer available
The attachment 20250518_120334.jpg is no longer available
Reply 18 of 28, by donluca4
Excellent, thanks for confirming!
I know some laptops don't have the function (in the BIOS or elsewhere) to stretch the image to fullscreen and that would have been a bit of a pain since the screen is already small at 12".
Also, I saw some horror stories about the Trident Cyberblade XP graphic cards (games with graphic corruptions or that didn't start/didn't work correctly) so I decided to go for the Intel integrated which seems to have better support and less issues, at least for Directx6 (or less) games.
Reply 19 of 28, by lolo799
After freeing some space on my XP partition and shrinking it to get some space for 98SE, here are some things you can expect:
-Installation slowing down to a crawl during the PnP detection part, forcing you to soft reboot and the install continuing again.
-first boot with the "welcome to 98" screen slowing down too, task manager showing one or more unresponsive items, again having to soft reboot.
-any boot after that, explorer.exe gets unresponsive (although it works fine in safe mode). I solved the problem by using progman.exe as the shell, you can then run explorer as an application
-video, audio, ethernet and cardbus work fine, I disabled bluetooth, wifi and infrared in the device manager as I won't use them.
Most of the drivers came from the D505 thread on vogons except the network one, the x300 uses a broadcom chip.
-directx 6.0 from 98SE won't recognize the 3d accelerated part of the Intel graphics, I upgraded to 8.0 and it works fine.
