First post, by moknok
I need to know the steps to follow in order to fix a stuttering sound
I followed everything in this video for pcem windows 98, he uses the soundblaster driver
https://www.youtube.com/watch?v=Rx2H3IV9SG4
to get in running but sound still skips in games and not game menus. I have tried to change emulation in video tab and everything nothing works.
what steps would fix this
| WIN98SE non OEM | PII MMX | 350Mhz | 384RAM | Voodoo3 2000 PCI | DX7 | 126GB+ | Yamaha DS-XG Sound |
Reply 1 of 5, by GloriousCow
quick guess - the video has you setting up a PII-300 and your computer probably isn't fast enough.
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 2 of 5, by feda
GloriousCow wrote on 2025-05-23, 16:17:
That's not his video, it's some other guy's.
But yeah, sound stutter is a symptom of your real CPU not being fast enough to emulate your chosen CPU.
Start with 100 mhz and work your way up until you get stutter.
Reply 4 of 5, by BulbulatorMacher
PCem will show percentage on top of the window; it shows emulation speed. Anything below 100% means that emulation cannot be done at full speed. Occasional dips could be tolerated, but consistent values much below 100% show that emulation is too demanding - you should decrease emulate CPU MHz or change CPU type. Different CPU models have different performance for a given MHz - for example, 133MHz 486 = 75MHz Pentium and ~350MHz Pentium = 233MHz Pentium II.
There is a performance table for 86Box (which is based on PCem) so you can check what type of machine your hardware can emulate at full speed: https://www.reddit.com/r/86box/comments/17gax … _what_cpus_you/
Emulation of Voodoo card is also demanding. There is a possibility that even when emulation is at 100%, the game needs faster CPU/graphics - in that case, the game could not be emulated using PCem on that computer.
Reply 5 of 5, by leileilol
It's good to start with a Socket 7/Super 7 board as that has quite a range of 5th/6th gen CPU speeds (slowest being winchip 75, fastest being K6-2 300/K6-2+ 550). Pick a game with a lot of self-modifying code (biggest demand to a dynamic recompiler) like a build engine game and dial it down until you see 100%. (Ironically some demanding games like Quake treat the dynarec well and are the best case scenario)
