Reply 6880 of 7182, by ElectroSoldier
Just bought TRS2004.
Seems like there is a bug that makes the trains drive backwards instead of forwards when you set it to drive to a particular place which is weird.
The played scenarios dont seem to have an actual end to them.
The idea on one level is to stock up fuel in the deep mine to make it work, then take coal to the power station so the lumber mill can work, so you can move the logs to the lumber mill. Once fully stocked its over.
But I cant seem to get enough fuel to keep feeding the mine. Just keeps filling the train with aviation fuel instead of diesel.
Very strange game.
Reply 6881 of 7182, by badmojo
I've been trying to play my old favourite time waster, Trials Evolution: Gold. But it seems that those fuckers Ubisoft have been messing around with that damn 'Connect' app, and now it asks me for a password every time I load the game. This is unworkable - I've tried all of the things suggested on the interwebs but nothing fixes it. I read somewhere that this is intentional for older titles, so maybe there is no fixing it. I've tried the dodgy crack on GameCopyWorld and it did actually allow the game to run without Connect, but it was super laggy.
Does anyone know if it's possible to play this game without Ubisoft Connect? There's a DVD version around I see (I bought it on Steam), but from the screenshots of the DVD case I can see that it's 'Connect Enabled', so I assume I'd still be dealing with it even if I installed it from DVD.
Why does everything have to be so hard?
Reply 6882 of 7182, by Joseph_Joestar
badmojo wrote on 2025-05-22, 07:44:
Yeah, Ubisoft DRM from that time is peak enshittification. I'm in the same boat with Splinter Cell: Conviction. For that game, I just gave up on the PC version and played it on my Xbox 360. True, it runs in 720p @ 30 FPS, but at least no internet connectivity is required.
BTW, @DosFreak mentioned an uPlay emulator here. Not sure if that works for your game though.
Reply 6883 of 7182, by badmojo
Joseph_Joestar wrote on 2025-05-22, 07:57:
Thanks but I couldn't find an emu option sadly. Out of desperation I went back and tried the GameCopyWorld nocd crack options again. There are 2 there, the first one really triggered Microsoft defender and was instantly deleted regardless of the browser I used, the second one caused the game to not run properly as mentioned previously.
Risking life and limb I turned off Defender and tried the first one (PROPHET), and it works great. I've had to put an exclusion in Defender to stop it from deleting it on sight but I've been using GameCopyWorld cracks for years without incident, so I'm sure it'll be fine. Bypassing Uplay Connect is worth the risk anyway - I've now uninstalled it and feel a great has been weight lifted 😁
Reply 6884 of 7182, by appiah4
badmojo wrote on 2025-05-22, 12:10:
You could consider running it in a VM..
Reply 6885 of 7182, by badmojo
That's a good thought but the lazyness is strong with this one 😅
Reply 6886 of 7182, by DracoNihil
Managed to get the mediocre MS-DOS port of T-MeK running again.
I don't understand why I'm so driven to these stupid games.
― Κυνικός Δράκων
Reply 6887 of 7182, by newtmonkey
The Elder Scrolls: Morrowind
I've tried playing this many times over the years, beginning with the XBOX version and then the PC version once I upgraded my PC. I thought the game was very interesting, but never got very far into it because I wasn't very disciplined at playing games back then. That's especially true for RPGs, which I played more as sandboxes simply to explore and see what I could find, and I'd usually stop playing if I got stuck or the challenge became too high... only to restart months later and do it all over again.
Since then, I've learned how enjoyable it is to figure a game out and complete it, and especially over the last few years I've been having a blast completing a bunch of console and PC RPGs. That includes Skyrim (bland, but nice graphics and music), Oblivion (surprisingly decent once you figure out how the level scaling works), and Fallout 3 (annoying), so it's time now to finally play what many RPG fans consider to be one of the top RPGs of all time: Morrowind.
I played Skyrim and Oblivion as a fighter with some minor magic abilities, so I decided to go with a pure mage for Morrowind. It seemed like it would be a nice change of pace, and I read that the magic system was quite interesting, complete with spell creation, equipment enchantment, and alchemy.
Compared with my attempts at playing the game as a fighter in the past, I had a pretty rough start as a pure mage. Everything a mage wants to do costs money, and it's difficult to make money early on without fighting... and you want to avoid fights against enemies that would actually drop coins or equipment you could sell for coins (and you also don't want to carry around too much stuff to sell, since it negatively affects your fatigue, which makes casting spells harder). Following the main quest, I arrived at Balmora, where I joined the Mage Guild and started doing the trivial tasks I was assigned. One problem here is that Mage Guild quests don't reward you with coins, but instead with potions and scrolls. These are definitely useful, but I was really lacking in funds to create spells and enchant some equipment.
However, with a bit of exploration and by fighting enemies I could reliably kill with my spells, I ended up making just enough to enchant a dagger with the "Bound Dagger" spell on hit, which basically transforms the dagger into a high-level weapon for a short period of time. It takes 18 seconds to recharge, so if you set the duration to 19 seconds, it will never run out of charges.
After some more exploration, I ran into a traveling merchant who wanted to be escorted to her destination, and promised a reward of a pair of "Boots of Blinding Speed." Due to how slow walking is in this game, I knew I had to have them, and so I did it. The funny thing about these boots is that they are sort of a joke. They do make you walk/run REALLY fast, but the "blinding" part is not just a colorful description; they cast a 100% blind spell on you when worn. My character is a Breton, so I have 50% resist magic, which means instead of going completely blind, the screen just gets somewhat dimmer. It's playable, but I wondered if 100% resist magic would actually prevent blindness completely... I did some research online and found that resistances stack, so the next step was to make myself a cheap 50% resist magic spell to cast before putting on the boots. This worked great, and is quite a game changer for a mage. It's not only easier/faster to get around, but you can easily outrun enemies, and since walking with the boots on is much faster than even running without, you really never have to worry about becoming fatigued just by running around.
My next step is to go around to other Mage Guilds and do their quests, and try to make enough money to get some new spells and play around with making some custom spells.
So far, the game is simply amazing. Each class has real strengths and weaknesses, so as long as you aren't playing as a custom class, you really have to sit there and think about how to play the game properly as your chosen class. Exploration is a joy thanks to the unique world and hand-placed content. The world itself is fascinating and feels totally alien at times, especially compared with the generic "high fantasy forests and castles" of Oblivion and generic "viking world" of Skyrim. I also really like the conversation system in Morrowind, though it has been criticized as the elder scrolls: wikipedia. It's just surprisingly enjoyable and immersive to walk into a new town, talk to the first person you see, and ask directions... and instead of marking the location on your map, the game provides you with actual working directions to follow ("head east toward the river, cross the bridge, then head south. His house is right next to the bookseller there").
Reply 6888 of 7182, by Namrok
newtmonkey wrote on 2025-05-23, 04:12:
The Elder Scrolls: Morrowind I've tried playing this many times over the years, beginning with the XBOX version and then the PC […]
A lot of people still consider Morrowind the peak of the series. I'm no Elder Scrolls super fan, but I can see why. I think I spent more time on Morrowind than any other, having only dabbled in Daggerfall, and coming to loath Oblivion's level scaling. Never even bothered with Skyrim. Perhaps that's my loss.
Sometimes I do think about giving Morrowind another try. I never did beat it, but it never occurred to me at the time to treat it like the sort of game you beat. But it's such a daunting game to try to take on again when the hours of my life feel so much more precious. Glad to hear you're enjoying it so much!
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 6889 of 7182, by appiah4
Seeing Morrowind run on my Radeon 8500 back then was a revelation, amazing graphics and atmosphere. I really enjoyed playing and getting lost in that game.
Make sure to MOD the Cliffracers out of the game before you start though 🤣
Reply 6890 of 7182, by gerry
Namrok wrote on 2025-05-23, 12:43:
.. and coming to loath Oblivion's level scaling.
Much as I like Oblivion (and fallout 3 & NV) I also thoroughly dislike level scaling
It can unbalance the game - not in combat with you but in the environment. In Fallout 3, as example, I have been high level such that high level enemies appear - and then rampage through any hapless NPCs you might have been near and hoped to trade with, talk to otherwise not bring about their demise by merely existing at a high level.
I prefer that the toughest enemies are in the toughest places
Reply 6891 of 7182, by newtmonkey
Thanks! I'm still having a blast five hours later.
Oblivion is playable (and actually quite charming) if you create a custom class and only tag skills you'll never use as your major skills. This lets you stay at a low level as long as you want, and then it's a simple matter of training one of your (unused) major skills to level up when needed/required. It's actually a pretty interesting game if you stay below level 5 and prevent the ridiculous level scaling from kicking in.
Skyrim is the ultimate experience of turning your brain off and soaking in the atmosphere, following map symbols like a deliveryman following Google Maps. It's so streamlined and dumbed down even compared with Oblivion, that it's closer to Assassin's Creed Valhalla than an RPG. Enemy scaling is not as bad as in Oblivion, but loot scaling is perhaps even worse; you never find anything really interesting, just incremental upgrades all throughout the game.
Reply 6892 of 7182, by RandomStranger
newtmonkey wrote on 2025-05-24, 06:26:
I don't remember this being the case with Oblivion, but with Skyrim NPC levels are capped aside of a handful of bosses so at a certain point generic enemies stop keeping up with the player. That's a marginally better option than what Oblivion did, but Morrowind still does it best.
Reply 6893 of 7182, by Joseph_Joestar
Didn't Oblivion eventually have common thugs and bandits wearing Daedric armor due to level scaling?
That was some hilariously bad game design. 😁
Reply 6894 of 7182, by newtmonkey
RandomStranger wrote on 2025-05-24, 06:37:
Yeah, I agree that Morrowind (so far anyway) handles it best. There is clearly some level scaling with the random encounters you face outdoors (I suddenly began encountering Nix Hounds the moment I reached level 2, and then diseased versions of the rat and insect enemies right at level 3), but it seems like interior locations such as caves don't scale.
I've read that Skyrim also sets and locks the overall level of an area the moment you step into it, which seems likely because I recall going to back to earlier areas late in the game and fighting very easy enemies. This seems like a pretty decent approach to scaling encounters in an open world game (if you absolutely have to have any scaling), but the scaled loot of Skyrim just kills it for me. A mix of random/scaled loot (currency, potions, etc.) and hand-placed equipment would have been better imo.
Joseph_Joestar wrote on 2025-05-24, 06:41:
I never got far enough in the game to see that (playing normally), but enemies do constantly level up with you, and it's awful. Really, the only way to get any fun out of that game if you don't want to use alternate leveling mods, is to just stay at level 1 as long as possible by gaming the class system. I actually played through the game a couple years back at level 1/2 (there's one mandatory quest that requires you to be at least level 2), and it was surprisingly fun.
Reply 6895 of 7182, by clueless1
Kingdom Come Deliverance II
I'm now over 60 hours in and still mostly ignoring the main quest. I've been doing a combination of side quests, activities, and general exploration, just because exploring is so fun in this world. Activities are cool too. They are triggered by conversations with NPCs, but do not appear in your list of Quests in the menu. All you get is a star on the world map that if you hover over, says "Activity". They are completely optional, and typically only give small rewards, but they are fun to do and expand the lore of the world. I've been on a group of activities that was initially triggered when the local bailiff told me he had heard about wolves encroaching closer than usual near sheepherders. That left an Activity Star on my map that lead to one of them. When I traveled there, he complained about wolves and a lost sheep and asked if I would help. Once completing the activity, he'd tell me about another sheepherder he heard of that was having similar problems, etc. Most turned out to be combats with wolves (bring the wolf ears back for proof, or bring the dead sheep's ear with its identifying tattoo), but there has been one that turned out to be bandits.
Speaking of bandits, there are random encounters with them on certain roads (usually in wooded areas). There are lots of options. You could just go around them and avoid them altogether. Or if on horseback, you could sprint past them. They usually chase on foot awhile before giving up. And if you're near a village, you can actually lead them into the village by slowing your horse down just enough and guards and villagers will pummel them when they get close. It's quite fun to watch. There was one time I stopped well away from the bandits. I could see them looting a body. While I was deciding what to do, a Noble rode past me on his horse, stopped just before the bandits, dismounted and engaged them in combat. It was then that I ran forward with bow drawn and started picking them off while they fought the Noble. Unfortunately, I couldn't save him, but it made taking them down much easier. There was another encounter that was especially memorable. Typically, I take plenty of damage, especially if there are 3 or more bandits. And sometimes I die and have to reload. My dog Mutt helps and can distract them enough for me to get hits in while their backs are to me. He can even draw enough blood that they bleed out before I finish them off. Anyhow, there were two bandits. I drew my bow, got rushed by the closer one, sprinted past him as he lunged at me, got a head shot off on the further bandit, then he lunged at me with his weapon as I ran past him, I turned and he'd already collapsed, dead. The first bandit which I ran past, still was far enough away that I could bury an arrow into his torso, then switched to my war hammer, dodged his lunge at me, turned, and hit him in the back of the head. He went down in a heap. It was the first time I'd killed multiple bandits without taking any damage. It happened so fast that Mutt didn't even get a chance to help out. Combat is very satisfying.
So my plan now is, I'm just before a major event in the main questline. All I have to do is tell the blacksmith that I want to go to the wedding. And from what I understand, there will be a major advancement in the plot and a whole other section of the world map will open up. Right now, I'm just trying to finish off every interesting quest and activity and explore every corner of the available map. Then I will trigger the main quest to advance and move forward.
Here are a couple of screenshots. I was exploring the western edge of the current world map. I had passed woodcutters earlier, then came across this chest in the hills, at the bottom of a small path.
The attachment screenshot_250518_060033.jpg is no longer available
The lock was too hard to pick, but I noticed a bird nest at the top of the path, so knocked it down, and lo and behold the key was in the nest! You can see the nest on the ground behind Mutt.
The attachment screenshot_250518_060218.jpg is no longer available
There was a lot of coin in the chest, but nothing else. I later learned that the woodcutters often hide their treasures deep in the woods behind where they are working. Lucky me.
Reply 6896 of 7182, by clueless1
Here is how I've been developing Henry.
Speech is the most developed Stat. It comes in very handy in so many aspects of this game.
The attachment Stats.jpg is no longer available
I've maxed out Houndmaster because interacting with Mutt is so satisfying. And working on Survival, Horsemanship, and Craftsmanship skills above the rest.
The attachment Skills.jpg is no longer available
And you can see I've put more emphasis on Marksmanship and Heavy Weapons (maces, war hammers) than swords or anything else.
The attachment combat.jpg is no longer available
Reply 6897 of 7182, by badmojo
clueless1 wrote on 2025-05-24, 14:45:
How would you say it compares to the first game?
Reply 6898 of 7182, by RandomStranger
newtmonkey wrote on 2025-05-24, 11:30:
It's only with dungeons. It doesn't apply to the overworld. Though in the overworld there aren't too many enemies that aren't capped at a relatively low level or have a fixed level.
Reply 6899 of 7182, by clueless1
badmojo wrote on 2025-05-24, 21:48:
It's been 4 years since I played the original, so some details are fuzzy. However, from a general viewpoint, everything feels more refined. Graphics are about the same, maybe slightly better. The writing seems to be at least as good, if not better. I don't remember anything from the original that was better implemented than the sequel. However, I do recall how satisfyingly realistic it felt progressing Henry from a country bumpkin to near-nobility in the original. There is less of that raw feel in this game, but it's to be expected with most sequels because most of us playing this already played the original. I'd be curious to know how someone who only played the sequel felt about the game.
