First post, by gladders
Hey all,
Tales as old as time, I know, but I am baffled by how to get this to work. I've been trying to put together my own 486 build for ages, but with two kids and summer, I have had literally minutes a week to tinker, so it's stalled for months. But I have today off, and I've got everything in place.
A LuckyStar 486E with an Intel 486 DX4/100. I've got three different CF adapters. I've also tested with regular IDE drives that I know work. None of these are detected by the BIOS. Except one CF adapter - so I can't resort to spinning rust if I can't solve this problem.
Anyway, I've set it up with LBA, as you can see below. I've also installed 6.22, with no issues. I've triple-checked, and the drive is formatted with MBR.
But it won't boot. It just hangs on POST. Everything seems fine. I can access the drive no problem when I boot using the floppy drive.
Any help, please?
Reply 1 of 14, by douglar
Try running "FDISK /MBR " to rewrite the master boot record.
Make sure that you got your boot order configured correctly in the BIOS.
Maybe run F-prot to look for viruses? https://archive.org/details/fprot_dos_316f
You fdisked & formatted after selecting the geometry yes?
Reply 2 of 14, by douglar
Ahh, I reread things. Using LBA with dos 622 might be difficult. Try Normal or large, drop the partitions, and start again.
Reply 3 of 14, by MikeSG
Did you use MS-DOS 6.22 to partition the drive?
Reply 5 of 14, by gladders
douglar wrote on 2024-09-19, 12:32:
Try running "FDISK /MBR " to rewrite the master boot record. […]
Yes, I used fdisk /mbr to set the drive and formatted it all in MS-DOS 6.22.
I also tried it into Windows 11 machine for good measure to see if that made a difference, and it didn't.
Reply 6 of 14, by MikeSG
"Format /s" can also install a boot record
Otherwise the LBA factor might be conflicting somehow with MS-DOS 6.22
OnTrack Disk Manager is another option to try. Runs from a boot disk and installs a drive overlay/boot manager on the CF card: https://www.philscomputerlab.com/ontrack-disk-manager.html
Reply 7 of 14, by douglar
gladders wrote on 2024-09-19, 15:25:
It isn't clear that DOS 622 works with LBA addressing for all BIOS INT 13h handlers. In other words, there could be a bug in your BIOS disk routines.
It's probably worthwhile to try EZ Drive http://vogonsdrivers.com/getfile.php?fileid=1899 or XUB https://www.xtideuniversalbios.org/
Or you could set the drive to Standard or Large and then repartition and reformat.
Reply 8 of 14, by butjer1010
As two other guys here told You, i also think that problem is LBA!!! Try with large first (as i can see this is 8gb CF, right?), and if that won't work, try with normal. Of course, every time between trying, You need to format CF again with FDISK/MBR 😀
Reply 9 of 14, by gladders
butjer1010 wrote on 2024-09-19, 18:18:
Yeah it’s 8GB. Okay, next time I get to it I’ll try the LARGE setting with a 2GB partition. Fingers crossed…
Reply 10 of 14, by douglar
I had a 486 vlb board that worked reliably for years and yesterday started acting odd when I tried to do a new build. “Missing operating system” after partioningand formatting /s. Swapped cables, compact fash devices, controllers, added XUB. Tried 512MB devices and 2Gb devices . Win95b and win98se. Gave some very curious errors if I tried to kick off the win98se installer from the A: complaining about HPFS or NTFS. So that’s today’s project. Figure out what I started doing wrong.
Reply 11 of 14, by douglar
I did the following:
1) Put the 2GB CF in a windows 11 computer, Ran diskpart.exe, selected the CF, and did a CLEAN command
2) Attached the CF into the WinTech MV008 with MRBIOS 1.60 (OPTI4BH) and checked the Drive Config
The attachment Photo Sep 22 2024, 1 19 48 PM.png is no longer available
3) Booted from a Win95B boot disk with an XUB ROM on a NIC and the disk showed up as 91MB. Never saw that before. My bad, I grabbed a a custom version of XUB I created for testing a 100GB drive.
The attachment Photo Sep 22 2024, 1 20 11 PM.jpg is no longer available
4) Yanked the NIC with the XUB ROM, reran FDISK but it only saw 512MB. In hindsight, I could have forgotten to select "Y" when starting Fdisk to do the large partitions
5) But what actually happened was I went to the BIOS, changed the drive config to Translate = "y", rebooted, deleted the partition, recreated at 2GB, formatted /s and I was able to successfully boot from the CF:
The attachment Photo Sep 22 2024, 1 25 40 PM.jpg is no longer available
6) Took the CF back to the windows 11 computer, copied over the base files, then returned to the retro PC, booted off the CF and started the scripted Win98SE install
Reply 12 of 14, by butjer1010
gladders wrote on 2024-09-19, 23:27:
Did You managed to make it work?
Reply 13 of 14, by gladders
butjer1010 wrote on 2024-09-27, 22:28:
I did!...but I have no idea how. I was at my wit's end, plugging it in every way it could and suddenly it started behaving. I don't know what I did differently - I hadn't changed the settings, but it just fired up and behaved. It caused me so much grief I've been unwilling to tinker with it further.
Willing to go into BIOS and report on the settings as they stand though.
Reply 14 of 14, by butjer1010
gladders wrote on 2025-05-26, 22:56:
Hehe, after rain, there comes a sun 😉
Nice to hear that every thing is working as it should!
