Reply 420 of 604, by myne
Before reboot?
If yes, I'm out of ideas
I built:
Reply 421 of 604, by Nicolas 2000
After reboot, as part of dosstart.bat.
Reply 422 of 604, by Nicolas 2000
One more thing. The sb emulation also runs from config.sys or autoexec.bat during first boot, before going to win98. Is that how it should be?
Reply 423 of 604, by Joseph_Joestar
Nicolas 2000 wrote on 2025-05-30, 09:45:
Yes, that's the expected behavior.
Those lines get added automatically when Creative's DOS driver pack is installed.
My retro builds
Reply 424 of 604, by Nicolas 2000
In that case I think I do everything right. I don't want to reinstall things now, as it runs fine in W98 and all my games run from W98.
Reply 425 of 604, by Nicolas 2000
Problem solved after full clean reinstall of the pc.
Reply 426 of 604, by sharangad
Got my problem solved on an i865 mobo with an Audigy 2zs. Needed sata controllers and USB disabled. Thanks for your awesome setup guide.
I have to say the open source sbemu has better fm than creative. Official creative drivers remind me of the midi downgrade I noticed going from an awe64 to sb pci 128. In fact the wave table sets even have the same ecw extension as the pci 128.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 427 of 604, by Joseph_Joestar
sharangad wrote on 2025-06-16, 16:19:
Cheers!
Yeah, pretty much anything sounds better than the FM synth emulation on SBLive/Audigy cards. Except for the SB128, which is somehow even worse. And yeah, I'm not a fan of those ECW sets for General MIDI music either. That's why I rarely use Audigy cards in pure DOS, as you can load any soundfont of your choosing under Win9x.
My retro builds
Reply 428 of 604, by TgamesFR
Hi Joseph_Joestar,
Do you know if the MPU401 from the external gameport bracket of the Audigy 2 ZS is usable with external Midi synths on Windows 98 and DOS ?
On old topics people saying the card dropped the support for MPU401 (UART-mode) so using with MT32-pi or external GM wavetables won't work.
I'm not talking of Intelligent mode ofc, but just the possibility to use General Midi synths.
You can confirm it ?
Thanks.
Reply 429 of 604, by Joseph_Joestar
TgamesFR wrote on 2025-08-02, 09:01:
Hi Joseph_Joestar,
It's been a while since I tested that, so take this with a grain of salt. From what I recall, external MIDI devices can be used for native Windows games and applications with an Audigy 2 ZS. So something like Windows Media Player or Final Fantasy 7 should work fine, as long as you select MPU-401 as the output in Control Panel.
But DOS games will automatically use the Audigy's internal synth, and cannot access the external MIDI device at all. This seems to be a hardcoded driver limitation. Some people have apparently found ways around this using some third-party utilities, but I have never tested that myself.
My retro builds
Reply 430 of 604, by Linoleum
Joseph_Joestar wrote on 2025-08-02, 10:11:
Hi Joseph_Joestar,
Yeah just checked and you need to go in Control Panel, Multimedia, MIDI, and select SB Audigy MIDI Port.
I was under the impression that AUDIGY12.exe could route MIDI to the port, but it doesn't (would be amazing).
This is probably the black magic stuff you are referring to: MIDI gameport in pure DOS mode
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 431 of 604, by TgamesFR
Hi Joseph_Joestar,
Thanks for your answer.
Indeed it's what i've understood while reading lot of old topics on Vogons.
The part i've not understood is about thoses third-party utilities, would be great to try if it can allow Midi devices on DOS.
So far i've readed i've not saw in details about them, which ones to use and how to use them.
Do you know some names of utilities you heard off ?
I could try on my side and say if it works or not.
Reply 432 of 604, by Joseph_Joestar
TgamesFR wrote on 2025-08-02, 13:12:
I've read some reports from people who had both an Audigy and an Aureal Vortex card installed at the same time. They said that, under those specific circumstances, it was possible to use the Vortex drivers to force DOS games into using the external MIDI device. There was also someone trying to use VDMSound to achieve a similar result.
But again, I never tested either of these methods myself, so I can only relay this info as something that I vaguely remember reading at some point.
My retro builds
Reply 433 of 604, by TgamesFR
In case someone need here 2 customs ECW soundfonts made byt John N. Engelmann (the man who reverse-engeenered the format 15 years ago).
His work on the format seems to have been forgotten, he was the first to fully reverse-engineered and build custom .ECW files for Creative Cards.
Contrary to people who think the format remains unknown and we cannot build new it's obviously false so xD.
It's to use under Pure DOS for the Audigy/Live cards :
- DEMO.ECW who is a custom soundfont
https://web.archive.org/web/20110713113927/ht … gy/ecw/demo.zip
- EMPTY.ECW who is a silent soundfont (in case one day we manage to enable the gameport under DOS, to not have both output at same time)
https://web.archive.org/web/20110830194423/ht … y/ecw/empty.zip
- ECW Format reverse-engineered :
https://web.archive.org/web/20110830194423/ht … ogy/ecw/ecw.txt
- ECW Decompiler & Sample Extractor
https://web.archive.org/web/20110830194423/ht … piler_v0_00.zip
Reply 434 of 604, by sharangad
TgamesFR wrote on 2025-08-15, 15:19:
In case someone need here 2 customs ECW soundfonts made byt John N. Engelmann (the man who reverse-engeenered the format 15 year […]
His work on the format seems to have been forgotten, he was the first to fully engineered and build custom .ECW files for Creative Cards.
It's to use under Pure for the Audigy/Live cards :
Wow!
Maybe someone will write an sf2 to ecw converter, if it's possible.
Reply 435 of 604, by TgamesFR
sharangad wrote on 2025-08-15, 15:52:
Wow!
Yes if someone is motivated enough all the format is detailled here :
.ECW file specification 1.21 (2004-3-2)
In this document, ".ECW file" or "waveset" refers to a file with an extension
of ".ECW" which stores articulation and sample data used by the MIDI
synthesizer of sound cards equipped with an ES1370, ES1371, or ES1373 chip.
These sound cards include the Ensoniq AudioPCI, the Sound Blaster! AudioPCI,
the Sound Blaster! PCI64, the Sound Blaster! PCI128, and the Sound Blaster
Live!. The file also includes some text describing the file and some mysterious
data which seems to be vestigial and completely unnecessary.
-------------------------------DISCLAIMER--------------------------------------
DISCLAIMER: THIS MATERIAL IS PROVIDED "AS IS". I verify the information
contained in this list to the best of my ability, but I cannot be held
responsible for any problems caused by use or misuse of the information.
Some file formats were not released by their creators, others are regarded
as proprietary, which means that if your programs deal with them, you might
be looking for trouble.
It is recommended that you make a backup copy of the original waveset file if
you plan to make any alterations to it, because some values may cause your PC
to crash or lock up during MIDI playback.
The .ECW file uses Intel byte order (LSB first).
This document has been authored in the style of the INTERxxy.* file list
by Ralf Brown, and uses almost the same format. Counts are given in DECIMAL,
not hexadecimal. When TYPE is "string", the count is the length of the string
in characters.
File Header
The .ECW file header stores the text that is shown when the waveset is loaded
in the configurator. It also specifies the size and quantity of the other
sections of the file. The file header is 1930 bytes long.
OFFSET Count TYPE Description
0000h 4 string File ID (always "ECLW")
0004h 4 string Spacer*
0008h 1 dword File offset where allocation chunk starts
000ch 1 dword Unknown. Always has value of 16.
0010h 80 string Copyright info for this waveset
0060h 80 string Waveset name
00b0h 256 string Filename of this waveset (ignored by the
configurator)
01b0h 80 string Description of this waveset
0200h 1280 string Information on this waveset. Usable length is
only 963 characters or so, because the
configurator will refuse to load the waveset
if characters 964 to 1280 of this string are
anything but nulls.
0700h 4 string Spacer*
0704h 1 dword File offset where bank map starts
0708h 1 dword Length in bytes of the bank map (always 256)
070ch 1 dword Number of bank maps (always 1)
0710h 1 dword File offset where drum kit map starts
Show last 516 lines
0714h                   1 dword  Length in bytes of the drum kit map (always
256)
0718h 1 dword Number of drum kit maps (always 1)
071ch 1 dword File offset where MIDI patch maps start
0720h 1 dword Total length in bytes of all MIDI patch maps
(always number of MIDI patch maps multiplied
by 256)
0724h 1 dword Number of MIDI patch maps
0728h 1 dword File offset where drum note maps start
072ch 1 dword Total length in bytes of all drum note maps
(always number of drum note maps multiplied by
256)
0730h 1 dword Number of drum note maps
0734h 1 dword File offset where instrument headers start
0738h 1 dword Total length in bytes of all instrument
headers (always number of instrument headers
multiplied by 23)
073ch 1 dword Number of instrument headers
0740h 1 dword File offset where patch headers start
0744h 1 dword Total length in bytes of all patch headers
(always number of patch headers multiplied by
76)
0748h 1 dword Number of patch headers
074ch 4 string Spacer*
0750h 1 dword File offset where array #1 starts
0754h 1 dword Total length in bytes of all "cubbyholes" in
array #1 (always number of "cubbyholes" in
array #1, multiplied by 2)
0758h 1 dword Number of "cubbyholes" in array #1
075ch 1 dword File offset where array #1 starts
0760h 1 dword Total length in bytes of all "cubbyholes" in
array #2 (always number of "cubbyholes" in
array #2, multiplied by 2)
0764h 1 dword Number of "cubbyholes" in array #2
0768h 1 dword File offset where array #3 starts
076ch 1 dword Total length in bytes of all "cubbyholes" in
array #3 (always number of "cubbyholes" in
array #3, multiplied by 2)
0770h 1 dword Number of "cubbyholes" in array #3
0774h 1 dword File offset where sample headers start
0778h 1 dword Total length in bytes of all sample headers
(always number of sample headers multiplied by
16)
077ch 1 dword Number of sample headers
0780h 4 string Spacer*
0784h 1 dword File offset where sample waveform area begins
0788h 1 dword Total length of sample waveform area in bytes
Bank Map
The bank map assigns one MIDI patch map to each of the 128 MIDI banks. The
bank map is 256 bytes long.
0000h 1 word MIDI patch map assigned to MIDI bank #0
0002h 1 word MIDI patch map assigned to MIDI bank #1
0004h 1 word MIDI patch map assigned to MIDI bank #2
0006h 1 word MIDI patch map assigned to MIDI bank #3
00feh 1 word MIDI patch map assigned to MIDI bank #127
Drum Kit Map
The drum kit map assigns one drum note map to each of the 128 MIDI drum kits.
Each drum kit map is 256 bytes long.
0000h 1 word Drum note map assigned to MIDI drum kit #0
0002h 1 word Drum note map assigned to MIDI drum kit #1
0004h 1 word Drum note map assigned to MIDI drum kit #2
0006h 1 word Drum note map assigned to MIDI drum kit #3
00feh 1 word Drum note map assigned to MIDI drum kit #127
MIDI Patch Maps
The MIDI patch maps assign one instrument to each of the 128 MIDI patches. Each
MIDI patch map corresponds to one or more MIDI banks. One MIDI patch map can be
used by more than one MIDI bank; in fact, all of the MIDI banks can use the
same MIDI patch map if desired (which would allow a smaller filesize and save
system RAM). The number of MIDI patch maps is set in the .ECW file header.
Each MIDI patch map is 256 bytes long.
0000h 1 word Instrument assigned to MIDI patch #0 when
using a MIDI bank whose entry in the bank map
is equal to 0
0002h 1 word Instrument assigned to MIDI patch #1, bank #0
0004h 1 word Instrument assigned to MIDI patch #2, bank #0
0006h 1 word Instrument assigned to MIDI patch #3, bank #0
00feh 1 word Instrument assigned to MIDI patch #4, bank #0
If there are multiple MIDI patch maps (according to the file header), then
the MIDI patch maps must follow one another immediately with no gaps between:
0100h 1 word Instrument assigned to MIDI patch #0 when
is equal to 1
01feh 1 word Instrument assigned to MIDI patch #127 when
is equal to 1
0200h 1 word Instrument assigned to MIDI patch #0 when
is equal to 2
etc.
Drum Note Maps
The drum note maps assign one instrument to each of the 128 MIDI drum notes.
Each drum note map corresponds to one or more MIDI drum kits. One drum note map
can be used by more than one drum kit; in fact, all of the drum kits can use
the same drum note map if desired (which would allow a smaller filesize and
save system RAM). The number of drum note maps is set in the .ECW file header.
Each drum note map is 256 bytes long.
0000h 1 word Instrument assigned to MIDI drum note #0 when
using a drum kit whose entry in the drum kit
map is equal to 0
0002h 1 word Instrument assigned to MIDI patch #1, drum kit
#0
0004h 1 word Instrument assigned to MIDI patch #2, drum kit
#0
0006h 1 word Instrument assigned to MIDI patch #3, drum kit
#0
00feh 1 word Instrument assigned to MIDI patch #4, drum kit
#0
If there are multiple drum kit maps (according to the file header), then
the drum kit maps must follow one another immediately with no gaps between:
0100h 1 word Instrument assigned to drum note #0 when
map is equal to 1
01feh 1 word Instrument assigned to drum note #127 when
map is equal to 1
0200h 1 word Instrument assigned to drum note #0 when
map is equal to 2
etc.
Instrument Headers
The instrument headers assign one or more patches (that is, the INTERNAL
patches used in the waveset, as opposed to MIDI patches, which are EXTERNAL) to
each of the instruments. The instrument headers also affect certain properties
of the instruments, such as tuning and pan. The number of instrument headers is
set in the .ECW file header. Each instrument header is 23 bytes long.
0000h 1 char Determines the function of the remaining 22
bytes in the current instrument header
When the byte at offset 0000h of an instrument header has a value of 2, the
rest of the header is arranged as follows:
0001h 1 char When set to a value of 0, only the first
instrument sub-header (see below) is active.
When set to 2 or 3, only the second instrument
sub-header is active. When set to 1, both
instrument sub-headers are active. Any other
value makes neither sub-header active.
0002h 1 char Seems to be the note number above which only
the second instrument sub-header is used;
otherwise, only the first instrument
sub-header is used. This is only the case when
the byte at offset 0001h is set to a value of
0.
FIRST INSTRUMENT SUB-HEADER
0003h 1 int Patch assigned to this instrument sub-header
0005h 1 char Amplitude and envelope steepness (signed)
0006h 1 char Pan (signed; 193 seems to be extreme left and
64 seems to be extreme right
0007h 1 char Coarse tune (signed; measured in semitones)
0008h 1 char Fine tune (signed; seems to be measured in
increments of 1/256 of a semitone)
0009h 1 int Amount of delay before onset of notes (seems
to be measured in miliseconds)
000bh 1 char Unknown. For tremolo strings and most if not
all drum kit percussion, has value of either
1 or 2.
000ch 1 char If, in two or more instrument sub-headers,
the byte at offset 000ch has the same value,
only one of the patches played by those
instrument sub-headers can sound
simultaneously. Examples of instruments where
this is desirable include open/closed hi-hats
and open/closed triangles.
SECOND INSTRUMENT SUB-HEADER (same as first)
000dh 1 int Patch assigned to this instrument sub-header
000fh 1 char Amplitude and envelope steepness (see above)
0010h 1 char Pan
0011h 1 char Coarse tune
0012h 1 char Fine tune
0013h 1 int Delay
0015h 1 char Unknown. For side stick and acoustic snare,
has value of 1.
0016h 1 char Probably same function as byte at offset
0000ch
When the byte at offset 0000h of an instrument header has a value of 255, the
0001h 1 char Unknown.
0002h 1 int The number of another instrument header.
0004h 1 char When a MIDI note is played with a note number
less than or equal to the value of this byte,
the instrument header specified by the value
at offset 0002h is used. (One can think of
these bytes as IF-THEN statements: IF the
note number <= the value at offset 0004h, GOTO
instrument header #X, where X is the value
stored at offset 0002h.)
0005h 1 int The number of another instrument header.
0007h 1 char When a MIDI note is played with a note number
at offset 0005h is used.
0008h 1 int The number of another instrument header.
000ah 1 char When a MIDI note is played with a note number
at offset 0008h is used.
000bh 1 int The number of another instrument header.
000dh 1 char When a MIDI note is played with a note number
at offset 000bh is used.
0014h 1 int The number of another instrument header.
0016h 1 char When a MIDI note is played with a note number
at offset 0014h is used. (The value here MUST
be 127.)
If there are multiple instrument headers (according to the file header), then
the instrument headers must follow one another immediately with no gaps
between.
Patch Headers
The patch headers (which refers to the INTERNAL patches used in the waveset, as
opposed to MIDI patches, which are EXTERNAL) assign one "cubbyhole" in array #1
to each patch. The patch headers also affect certain properties of the patches,
such as the pitch and amplitude envelopes. The number of patch headers is set
in the .ECW file header. Each patch header is 76 bytes long.
0000h 1 char Magnitude of pitch envelope (signed). Negative
values cause pitch to fall rather than rise.
A value of 0 effectively disables pitch
envelope.
0001h 1 char MIDI controller 1 (modulation) sensitivity
0002h 1 char Scale. A value of 0 denotes a 12-tones-per-
octave (i.e. chromatic) scale. A value of 1
causes this patch to ignore the MIDI note
number, so that every key on the keyboard is
the same pitch. A value of 2 denotes a 24-
tones-per-octave (i.e. quarter tone) scale.
0003h 8 string Unknown
000bh 1 int "Cubbyhole" in array #1 assigned to this patch
000dh 1 char Changes tuning slightly
000eh 2 string Unknown
0010h 1 char Shifts the split points of the samples played
by this patch
0011h 10 string Unknown
001bh 1 char Causes pitch to change more rapidly upon
note release when pitch envelope is enabled.
May be the destination of the release phase
of the pitch envelope.
001ch 1 char Delay before pitch envelope enters attack
phase
001dh 1 char Initial pitch for pitch envelope**
001eh 1 char Attack time for pitch envelope
001fh 1 char Attack level for pitch envelope
0020h 1 char Decay time for pitch envelope
0021h 1 char Decay level for pitch envelope
0022h 1 char Sustain time for pitch envelope
0023h 1 char Sustain level for pitch envelope
0024h 1 char Release time for pitch envelope
0025h 1 char Influence of MIDI note velocity on magnitude
of pitch envelope
0026h 1 char Unknown (may be proportional to attack time
of pitch envelope)
0027h 1 char Influence of MIDI note number on pitch
envelope time (0=none; 127=huge)
0028h 1 char When set to 0, the pitch envelope enters the
release phase when a MIDI note-off command
is received. When set to 1, pitch envelope
never enters the release phase.
0029h 16 string Unknown
0039h 1 char Possibly the destination of the release phase
of the amplitude envelope.
003ah 1 string Unknown
003bh 1 char Initial amplitude for amplitude envelope**
003ch 1 char Attack time for amplitude envelope
003dh 1 char Attack level for amplitude envelope
003eh 1 char Decay time for amplitude envelope
003fh 1 char Decay level for amplitude envelope
0040h 1 char Sustain time for amplitude envelope
0041h 1 char Sustain level for amplitude envelope
0042h 1 char Release time for amplitude envelope
0043h 1 char Influence of MIDI note velocity on magnitude
of amplitude envelope.
0044h 1 char Unknown. Seems to affect amplitude attack.
0045h 1 char Influence of MIDI note number on amplitude
envelope time.
0046h 1 char When set to 0, the amplitude envelope enters
the release phase when a MIDI note-off command
is received. When set to 1, amplitude envelope
0047h 1 string Unknown
0048h 1 char Pitch LFO (i.e. vibrato) depth. A value above
0 will add pitch modulation to a patch even
when MIDI controller 1 (modulation) is set to
0.
0049h 1 char Pitch LFO (i.e. vibrato) speed.
004ah 1 char Delay before pitch LFO (i.e. vibrato) reaches
full depth.
004bh 1 string Unknown
Array #1 "Cubbyholes"
The "cubbyholes" in array #1 assign one "cubbyhole" in array #2 to each
"cubbyhole" in array #1. The number of "cubbyholes" in array #1 is set in the
.ECW file header.
"CUBBYHOLE" #0:
0000h 1 int "Cubbyhole" in array #2 assigned to this
"cubbyhole".
If there are multiple "cubbyholes" (according to the file header), then the
"cubbyholes" must follow one another immediately with no gaps between.
"CUBBYHOLE" #1:
0002h 1 int "Cubbyhole" in array #2 assigned to this
"cubbyhole".
"CUBBYHOLE" #2:
0004h 1 int "Cubbyhole" in array #2 assigned to this
"cubbyhole".
etc.
Array #2 "Cubbyholes"
The "cubbyholes" in array #2 assign one "cubbyhole" in array #3 to each
"cubbyhole" in array #2. The number of "cubbyholes" in array #2 is set in the
.ECW file header.
"CUBBYHOLE" #0:
0000h 1 int "Cubbyhole" in array #3 assigned to this
"cubbyhole".
"CUBBYHOLE" #1:
0002h 1 int "Cubbyhole" in array #3 assigned to this
"cubbyhole".
"CUBBYHOLE" #2:
0004h 1 int "Cubbyhole" in array #3 assigned to this
"cubbyhole".
etc.
Array #3 "Cubbyholes"
The "cubbyholes" in array #2 assign one sample header to each "cubbyhole" in
array #2. The number of "cubbyholes" in array #2 is set in the .ECW file
header.
"CUBBYHOLE" #0:
0000h 1 int Sample header assigned to this "cubbyhole".
"CUBBYHOLE" #1:
0002h 1 int Sample header assigned to this "cubbyhole".
"CUBBYHOLE" #2:
0004h 1 int Sample header assigned to this "cubbyhole".
etc.
Sample Headers
The sample headers indicate where the individual samples are to be found in the
sample waveform area. They also specify how those samples are looped (if at
all), and any split points between one sample and another. The number of sample
headers is set in the .ECW file header. Each sample header is 16 bytes long.
0000h 1 char If a MIDI note is received with a MIDI note
number above this value, the next sample
header is used instead. If the MIDI note
number is still greater than the byte value at
offset 0000h of the next sample header, the
sample header after the next sample header is
used and so on until the MIDI note number is
less than or equal to the byte value at offset
0000h.
0001h 1 char Determines whether this sample is looped. May
also control other aspects of the sample. This
may be a bitmapped byte. A value of 0 disables
looping; values of 2, 3, 128, 144, 146, 148,
and 227 enable looping.
0002h 1 char Fine tune (signed; seems to be in increments
0003h 1 char Coarse tune (signed; measured in semitones)
0004h 1 dword Offset in sample waveform area where this
sample begins, multiplied by 8. Sample
waveform data can be shared by multiple sample
headers.
0008h 1 dword Offset in sample waveform area of this
sample's loop point, multiplied by 8.
000bh 1 dword Offset in sample waveform area of this
sample's end loop point, multiplied by 8
(fractional loop lengths permitted). This is
also where the sample ends when looping is
disabled. If a sample plays beyond the end of
the file, the operating system may lock up.
If there are multiple sample headers, then the sample headers must follow one
Sample Waveform Area
The sample waveform area stores the actual sample waveform data used by the
sound card's MIDI synthesizer. The sample waveform data is stored using 16-bit,
mono, signed samples, with LSB first (Intel byte order). Theoretically, the
sample waveform area can be up to 512 megabytes in size (sample start/loop/end
loop points in the sample headers are specified using dwords, which have a
maximum value of 2^32 or 4294967296. Diving this value by 8 - the sample start/
loop/end loop points are measured in 1/8 bytes - we get 536870912 bytes, or 512
megabytes. Note that this limit is only theoretical, as the author has not
actually tested it). The size of the sample waveform area is set in the .ECW
file header.
NOTES
*A "spacer" is a series of 4 bytes of unknown purpose. The contents of a spacer
are usually 01h, 00h, 01h, 00h; however, changing the contents does not seem to
have any effect whatsoever. Only the size and placement of spacers matters;
their contents do not.
**Most if not all of the values dealing with the envelopes are unsigned and,
confined to values between 0 and 127. Using values between 128 and 255
typically generates unpredictable results.
Contact Info
E-mail: earwaxcandle at hotmail.com (change " at " to "@")
[Keywords: .ECW file format, .ECW format, waveset file format, waveset format]
Reply 436 of 604, by flsnmr
First, thank you so much for this guide! I was able to get my system running with an Audigy 2 on a VIA KM266 motherboard. I had to manually assign 1 & 5 to the low and high DMA values and then it worked.
Second, was anyone ever able to get CD audio working in pure DOS mode (restart in DOS)? This is the only thing making me consider going back to a Sound Blaster Live!, which I was also able to get working, somewhat surprisingly on this chipset. Audio quality in Windows is excellent, and this is mainly a late-9x build (Athlon XP 2200+/GF4 Ti 4400), but I would still like to play the occasional session of Quake directly from DOS with CD audio.
Reply 437 of 604, by muteKi
I've followed this guide but still ran into some issues. I'm using a 2ZS (SB0350) on Windows 98 on a Dell Dimension 4100 (1GHZ Pentium III). VXD drivers.
I notice I'm not the only one with this issue but I cannot get CD Digital volume to show up in the sound mixer. It sounds like I may need to use a Live 5.1 for this? I won't rule out picking one up and moving the Audigy to a newer machine (for XP gaming) if that's the only way to fix this.
I also do not get any audio when running in pure DOS mode. I load in all the drivers and the EMM tool, and they send messages like they are working properly, but when I run SBEGO and do a test, wave or music, I get no sound either way. Some results suggested this was a result of the outputs I was using, but I don't know what the correct one is and trial-and-error didn't get me anywhere.
Reply 438 of 604, by Joseph_Joestar
muteKi wrote on 2025-09-16, 03:52:
This seems to be a hardcoded limitation of Creative's drivers which only affects Audigy 2 ZS cards. Older models such as the regular Audigy 2 (SB0240) and Audigy 1 (SB0090) are unaffected.
Did you use AUDIGY12.EXE? It's necessary to run that file each time you boot into pure DOS in order to get working audio on the ZS. For the output, you need to use the Line Out 1 jack.
My retro builds
Reply 439 of 604, by 5a796d
My current system (sblive/a7v600-x/win98) with unfortunate does not detect the sound card in the DOS games started by Win98, despite having everything in place (Drivers, IRQ, conflicts etc.
) I know the problem is the KT600 chipset (a7v600-x) that no longer supports nmi.
I have an audigy 2 ZS, reading in the first post, reference is made to the advice to use the audigy instead of the release because the latter has compatibility problems.
Now I wonder: My Audigy 2 ZS on the KT600 and the sb16 emulation is detected?
