First post, by Omarkoman
I have this motherboard:
AMI SUPER VOYAGER VLB-III
https://theretroweb.com/motherboards/s/ami-su … b-iii-s707#docs
and want to run AMD DX4-100 Mhz cpu in it.
I have setup the jumpers as per manual :
I have set the VESA speed ( see above manual) to 33Mhz as my understanding is the cpu is 3x 33Mhz and I also set the CPU type to 3x (if I set it to 2x or 2.5x PC wont post) - jumpers J19, J37, J43, J54 in top table.
The system posts however, running cpu check its reporting its running at 150Mhz 3x50Mhz
It posts fine, runs games and benchmarks ok so not sure what to do. Leave it as is (I have active cooling on it) or do I need to change anything ?
Keen to get some thoughts please. Thanks in advance.
