First post, by kotel
Hi
I am looking for an BIOS which allows for overclocking for the Gigabyte GA 6BXS board. I am on the latest (F1) BIOS but I don't have any option to change the clocks of the CPU and RAM.
Anybody which owns an BIOS which could let me do some overclocking on the CPU?
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
Reply 1 of 6, by Horun
Depending on what Clock IC you have you may only have 66 and 100. And it would not be from a BIOS for that board (or most 44BX) but by changing jumpers/switches like asus p2b-f, p3b-f, etc.
just an observation
Reply 2 of 6, by kotel
And what about the multipliers? The jumper block on mine only goes up to 500mHz max while currently I have an p3 700mhz CPU inside I would like to OC to 750mhz or even 800mHz.
Ready yourself!
Reply 3 of 6, by PC Hoarder Patrol
Gigabyte issued an extended ratio table for the coppermine era, but you're still cpu locked at x7 whatever the jumper block multiplier is set to...
The attachment Gigabyte Extended Ratio Table (Intel).jpg is no longer available
Reply 4 of 6, by kotel
PC Hoarder Patrol wrote on 2025-06-08, 10:15:
Why is that? BIOS limitation or the fact these CPUs could be multiplier locked?
Ready yourself!
Reply 5 of 6, by PC Hoarder Patrol
kotel wrote on 2025-06-08, 13:25:
All Coppermine Pentium III processors have the CPU multiplier internally locked and they don't recognise external multiplier jumpers or BIOS settings. So, as it stands, your cpu will support either 700MHz (7 x 100MHz FSB) or 466MHz (7 x 66MHz FSB) on the GA-6BXS. As @Horun said initially, clock IC-driven FSB is how these processors overclock and I don't find anything to suggest the board / BIOS supports FSBs other than 66 & 100MHz.
Whilst there are BX / GX boards supporting a wider range of FSBs (I've a few Supermicro models supporting 66, 83, 100, 106, 112 & 133MHz) if you want more out of this board you could try a faster processor - Gigabyte list the fastest supported as 1GHz (10 x 100 FSB) on PCB rev. 1.6 and BIOS F1 or F2C. This may also work on earlier PCBs, but if not 800-850MHz should be fine.
Reply 6 of 6, by kotel
Welp, at least I still know an 850mHz p3 should be supported on the rev 1.5.
Thanks to everyone for helping!
Ready yourself!
