Joseph_Joestar wrote on 2025-02-28, 14:37:
I don't think it's good to generalize like that based on one problematic game. I've tried several other DirectX 8.1 titles (e.g. Unreal 2, WarCraft 3 and Morrowind) on the system mentioned above, and they all worked properly.
I did extensive testing on Athlon 64 socket 754 and cards newer than GeForce GTX 2xx don't work properly in Need for Speed Hot Pursuit 2. There is a major performance drop in FPS. This may not be noticable on newer CPU, perhaps due to instruction set optimization in NVidia driver, not available on socket 754. It doesn't matter what driver is used.
I will verify in a few months whether this problem also affects Phenom X4 which will get a better GPU. Phenom has L3 cache unlike dual core CPUs from that era like Athlon 64 X2.
For Athlon 64 socket 754 the best cards are GeForce 9800 GT or GeForce 2xx. It doesn't matter much as the CPU is too weak to benefit from 2xx. One of few games where it benefits is FIFA 2007, during game introduction with view on the whole stadium. In general, it leads to extreme variance in FPS when in CPU easy scenes it can render many FPS, but then falling sharply in CPU heavy scenes when CPU gets overloaded. 2xx will provide no benefit in CPU heavy games.
Usage of PCIe GPU in Athlon 64 socket 754 extends its usability by about 2 years over a similar Athlon XP with an AGP card. Late Windows XP era absolutely needs a fast dual core CPU for any racing or FPS game.
												Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
