First post, by RobertX
In a GNU/Linux distro, I am interested in storing a variable that contains the current /home/ directory.
In that past, I would have to ask the user to input the Home directory of the user in question.
I want the procedure to be automated.
This was how I did it:
# Ask for user name
STRINGS user = ASK Please enter your user name:
#Mount User drive
mount c /home/%user%/.dosbox/
So, how can I just mount the directory by itself? Does GNU/Linux store the home directory by itself, or do I have to stick with asking for the Home directory every time?
EDIT: I think I have to explain why I mount the user directory every time I start up DOSBox. Simply, I do it because that's where I store the programs/games in, nowhere else. I like my stuff structured and organised.
Reply 1 of 6, by Ringding
Just use the -c command line switch! This is what I do: <path-to>/dosbox -c "mount c ~/temp/dosbox"
Reply 2 of 6, by wierd_w
If this is not something that changes based on who has logged in, (eg, only one user, and the home dir is always the same dir), why not just add the line in dosbox.conf?
If this changes based on who is logged in, then a bash script that uses variables, and the -c invocation as shown above, is the better way. You can pass a command line argument or system variable in with the right decoration.
Reply 3 of 6, by zirkoni
The current user is stored in the $USER variable so this should work:
dosbox -c "mount c /home/$USER/.dosbox"
Another option is to use the $HOME variable:
dosbox -c "mount c $HOME/.dosbox"
https://youtube.com/@zirkoni42
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
put this in your config file
mount c ~
or if you want that specific path
mount c ~/.dosbox
Water flows down the stream
Reply 5 of 6, by RobertX
zirkoni wrote on 2025-06-15, 14:02:
The current user is stored in the $USER variable so this should work: […]
I would use this, but the answer I seek is the one I can enter in the AUTOEXEC.BAT of the DOSBox program.
Reply 6 of 6, by RobertX
Qbix wrote on 2025-06-15, 15:58:
put this in your config file […]
mount c ~
mount c ~/.dosbox
I'll try that. Thanks!
