First post, by ussdarkstar
Hello, I formatted last night due to nonsense viruses and slowing down the computer, I was using windows 10, I installed windows 10 again. I use dgvoodoo actively without any problems, but after the format, even the games I set before do not work, I mean, I did everything I could think of, the driver is up to date, dx is installed, vc redist is installed, so what could be the thing that requires it not to work? What could be missing so that the program that works smoothly does not work after the format. Thank you in advance for your support.
Reply 1 of 10, by ussdarkstar
my graphics card is rtx2080
Reply 2 of 10, by mitradis
Or your antivirus is blocking the load. Defender. Or you don't have administrator rights. Or something is redirecting the load of the dll, for example if there is a direct indication in the registry (Re: Direct3D8 HAL support removed by Nvidia?). There is no reason why the wrapper could not work in new versions of Windows.
http://enbdev.com/enbseries/forum/viewtopic.p … 4ca79e3b#p48220
Reply 3 of 10, by Darkstorm
You need to put .dlls from MS/x86 folder into the game binary folder and without any configuration it should work for most older games out there. There are games that are a bit more trickier to get dgvoodoo work on them. What game are you trying to run with dgvoodoo?
Reply 4 of 10, by ussdarkstar
It doesn't matter which game it is, I already said in my post that I use it actively and I already have dgvoodoo configuration in many games, here I share the images before and after the format. as I said, I don't know how to overcome this problem.
Whatever happened after the format, whatever was missing, it doesn't work, as I said, I can't run the program that I never had a problem before the format.
Before formatting
https://resimyukle.app/i/pKqmikIU.jpg
After formatting
The dgvoodoo configuration is already in the game in short dgvoodoo is not working for some reason.
Reply 5 of 10, by feda
Delete dgVoodoo.conf. Run dgVoodooCpl.exe again, re-select output API and adapter, click OK.
Also re-run the game's own config utility if it has one. They usually store settings in the registry which was wiped in the format.
Reply 6 of 10, by ussdarkstar
I tried all of them and the result is the same, normally in the output api section I was using Best available one to work on other PCs. but in the adapter use section in the dx11 dx12 subsection, all of them, but I tried them all to no avail.
I don't think it's the game's own configuration, I use dgvoodoo in about 60 or 65 games, all of them already have the configuration and none of them work, I uninstalled it and configured it from scratch and it still didn't work, it's a very strange problem, I've been using dgvoodoo for years and this is the first time I've encountered this problem.
Reply 7 of 10, by feda
Try disabling UAC. Also add an exclusion in Defender for the four dlls.
Reply 8 of 10, by ussdarkstar
Strange thing, uninstalled and reinstalled the driver and it worked.
Reply 9 of 10, by mantis2001
ussdarkstar wrote on 2025-06-15, 15:55:
maybe your fresh installation auto installed windows update version video drivers which not support dgvoodoo2
Gigabyte GA-8I915P Duo rev 2.1 (lga775) | P4 651 | ATI x800 gto | 1024MiB ddr2 | 80G IDE | win98se/XP
Colorful C.N68g d3 v16 (AM3) | Athlon X2 245 | GF 6800 | 4GiB ddr3 | 180G SATA | XP/7/Debian
Reply 10 of 10, by Dege
For cases similar like this one: always try the _dbg version of dgVoodoo to see if it's ignited at all and also to see what error messages it dumps into the log.
For example, I remember a case where the driver did not enumerate any resolutions through DXGI, strangely enough, and that was the reason dgVoodoo did not work (resolutions were also missing from the Cpl app). Reinstalling the driver solved that case too, IIRC.
