First post, by mattlacey
- Newbie
I've got an NEC MultiSync EA912M that I purchased because it supports 15KHz VGA modes which is useful for Atari machines. I was also using it with my old PCs via a KVM, though I realised that was the source of my horrible video signal, VGA direct is super crisp at 1280x2024, and works well in Windows 98 and in BeOS R5 (where I can even run that res at 80Hz, above the specs in the manual).
Without the KVM though, it's a pain to switch, but since my current old PC has DVI (GeForce 2 GTS) and so does the monitor, I dug out a cable to try that out. BIOS shows fine, but neither Windows nor BeOS will run anything above 800x600 when using that cable - anything else and the monitor just says out of sync. I don't think I ever used DVI ports back in the day (straight from VGA to HDMI), I know there's different specs and some are analogue only, but based on the card's connected I assumed it'd be using digital. Is this likely just poor support from my card/ monitor, a dodgy cable (though I've tried two with the same results) or software? I assumed it was handled entirely by the card and transparent to the OS, but we know what the thing is with assumptions 😀
