stealthjoe wrote on 2025-06-20, 02:50:
The PSU I am using is Gigabyte P450B which is supposed to be a decent and safe one.
Ah, one of those. FWIW, these were also from the affected PSUs from the Gigabyte scandal (about their PSUs blowing up when overloaded.)
I fixed one a few years ago that I got for really cheap. Was lucky that mine was just a DOA unit from a bad 5VSB rectifying diode.
Anyways, I wouldn't call these PSUs exactly safe, but I wouldn't call them unsafe either.
What they are probably not good for is powering 5V-based PCs... though I haven't ran mine through my usual crossloads to check. It's a group-regulated design and ATX v2.2 compliant, so I suspect it won't do well with any system that pulls more from its 5V rail and its 12V rail. That's not to say I think this is the source of your issues... but certainly something to keep in mind if you use this PSU for testing retro hardware, specifically boards that power the CPU from 5V rail. In the case of P3, luckily they are not power-hungry at all (30 Watts TDP for the higher end ones, lower for lower models like yours), so I think your PSU probably just scuffs by.
H3nrik V! wrote on 2025-06-20, 04:39:
Without the heat sink? Pretty sure that would fry the core in no time..
Socket 462 CPUs - yes, absolutely.
Socket 370 CPUs - they just crash, as demonstrated by that Tom's Hardware video from way back in the days.
If worried, just put a small chipset heatsink on top with whatever scrap thermal pad or thermal compound you got - should keep the CPU temps OK for a quick <30 seconds test.
AlexZ wrote on 2025-06-20, 14:37:
Sometimes the problem is in the quality of packaging, although usually not the case with CPUs.
Yeah, it's hard to badly pack a CPU... though not impossible, certainly. 😁
Had a motherboard with CPU and RAM shipped to me once in a box with no padding whatsoever inside. Best part (or worst, depending on with how little humor you want to look at it 🤣 ) was the CPU and RAM were detached from the motherboard. So everything was all flopping around in there losely. It was too cheap to pass, though, so no regrets. The mobo was listed for parts, and as I saw from the listing, had bad caps (which is likely why it wasn't working.) Miraculously, after recapping the board and straightening pins on the CPU (socket 939 Athlon 64), everything ended up working.
I never buy hardware without warranty as people tend to mishandle it too frequently.
Yeah, but even with warranty, dealing with having to ship stuff back for some of the sellers really puts me off.
That's why most of the time, I prefer to buy the "as-is, no warranty, untested" items and assume it really won't be working... that is, if I think I might be able to fix the item. Usually it's much cheaper this way too (up to a point anyways.) In the case of semi-modern GPUs, that's rarely the case.
Now what I *don't* buy are stuff from no-effort low-ball sellers that literally pick obviously broken stuff from the dumpster and try to sell it as -just- "untested", sometimes at almost premium prices too.
