First post, by Sagadali523
I just installed Operation Flashpoint Cold War Crisis for Windows 98 Second Edition a few days ago running on 86Box which they say it's more stable and accurate than PCem as many of you already knows that.
Although, old games like mine always requires the CD to stay put so I already have it inserted, and for this after installation, when I start opening up, I get this error message appeared after the splash
Not sure why is this happening when the disc was already here on the A drive perfectly. And I had search around with this error to get it fixed and nothing's good appeared. So, if you know the exact best results to solve this issue, I would appreciate it and here are the specs of the OS I am running:
Machine type: Slot 1
Machine: ASUS P/I-P65UP5 (C-PKND)
CPU: Intel Premium II OverDrive, 233 mHz
GPU: 3Dfx Voodoo3 3000
