First post, by aderius
Hi all,
I bought a Dell XPS 600 locally and installed Windows 2000 on it w/ SP4.
Pentium D 3.0 ghz
GeForce 6800 GTX 256mb
2gb RAM
Mobo has an nforce4 chipset (Nvidia CK804)
Corsair 512 gb SSD w/ StarTech SATA-to-IDE adapter
REMOVED
Running into two issues:
1. Device manager does not list the GPU, which is a Geforce 7800 GTX. Running hwinfo on this PC detects it fine. I found a random thread suggesting to change the computer type to "standard PC" and voila - it's now detected. As I understand it, there are some downsides to using this method. Is there any workaround? The BIOS is pretty sparse as far as options go.
2. I get intermittent "disk read error" on boot. I ran repair through W2K CD, but ultimately, turning off computer, waiting a few seconds, and turning it back on again often lets it boot into Windows just fine.
Any advice would be greatly appreciated!
Reply 1 of 4, by GemCookie
aderius wrote on 2025-06-22, 15:18:
If no driver is installed, the card naturally won't show up in the Device Manager.
Indeed, Windows 2000 can only use one CPU thread with the Standard PC HAL. Software power-off won't work either.
Have you installed chipset drivers?
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Reply 2 of 4, by aderius
I have installed the chipset drivers, yes! There are still a lot of generic listings under system devices, not sure if that's to be expected
Reply 3 of 4, by DosFreak
So called "abandonware" is not supported here.
Removed name of modified Microsoft OS used so that it can't be searched for from the op post and downloaded from a certain site.
Make your games work offline
Reply 4 of 4, by aderius
UPDATE: I just gave up. Compatibility is a headache with this system even with drivers and SP4. I found no way to have Windows recognize the existance of the video card unless I changed it to "standard PC", which in turn caused other compatibility issues. Went to XP, no issues.
