Reply 20 of 27, by kmeaw
analog_programmer wrote on 2024-10-23, 10:21:I've done a successful PCI slots - IRQ table modification once, but for Award BIOS version 4.51PG. Is it valid for Award BIOS ver. 4.50P(G)?
This mod is also done for 4.51PG. The 4.50PG was only used as a reference source for tables.
analog_programmer wrote on 2024-10-23, 10:21:Never heard of this AwdHack tool, but unfortunately I can't find it for download.
I have found it somewhere on RayeR's homepage.
freezecze wrote on 2024-10-23, 06:58:Also the PNP/PCI configuration page is missing 2 lines. This can be fixed with Modbin right?
No, it would require some relocations around - menu configuration pages are stored with the language tables interleaved, so I had to shuffle strings around.
I have moved the menu item which enables PCI IDE controller to the chipset page because it would not fit on a 25-line display.
