First post, by Azrael128
Hi everyone,
I am new here and you guys are probably my last hope.
I have this Sound Blaster Audigy 2 ZS (SB0350) which I love dearly. I used to use it with the kX drivers and do stuff that even $700+ modern hardware can't compete with. Trouble is, it seems to get it increasingly hard to get stuff like that to work.
On my previous, X570-based motherboard, I used a PCIe-to-PCI adapter/riser card based on a Pericom PI7C9X111SL bridge. It worked on some PCIe slots, not all, but heh, one was enough and I daily drove that card for the last 5 years.
I have now upgraded to an X670e-based motherboard and unfortunately, this is where it becomes horribly complicated:
- The aforementioned adapter is not detected at all, whichever slot I put it in, whichever settings I change in the BIOS. The bridge simply isn't enumerated at all, and thus neither is the sound card.
- I bought a new adapter, this time based on a PLX PEX8112 bridge. That one is detected and so is the sound card, but the sound card behavior is erratic at best: no sound with the official drivers, and with kX, the sound is very quiet and distorted, especially in the low frequencies. Recording doesn't work properly, sound coming from the p16v is at the wrong pitch, etc.
Does anyone have any solution, or can come up with an adapter or bridge that is known to work? I could buy just all the available adapters on Amazon and return whatever doesn't work, but they generally highly frown upon this.
Of course, worst case scenario, I guess I could go with an Audigy Rx, but then I would lose the p16v with kX, so I'd rather just keep my Audigy 2ZS.
Anyone had any luck with a specific combination on modern, AM5 motherboards?
Thanks in advance!
Reply 1 of 4, by shevalier
The P16V module is only available in the A2 Value and Audigy 4 in CA0108 chipset.
2ZS has the old chip, P16V just doesn't exist.
https://danielkawakami.blogspot.com/
Try this driver.
if not - RX is good choice.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 4, by Azrael128
shevalier wrote on 2025-06-25, 15:20:
The P16V module is only available in the A2 Value and Audigy 4 in CA0108 chipset. 2ZS has the old chip, P16V just doesn't exist. […]
Try this driver.
I believe you're confusing p16v with p17v. Audigy 2 series (except 2Value) have p16v, which kX supports, while A2Value/A4/Rx have p17v, which kX doesn't support. Audigy 1 and SBLive! have neither.
And I specifically want to use kX, it's the whole reason why I want to keep an emu10k-based card to begin with. The routing possibilities are just crazy, even many high end modern prosumer cards don't offer this much freedom. The exception would be something like an RME Fireface but this is a $1500+ piece of hardware. My Audigy is paid for already and cost me something like $35.
Reply 3 of 4, by shevalier
Azrael128 wrote on 2025-06-25, 16:51:
Try this driver.
Sorry, I made a mistake.
You have very specific tasks, so I can't say anything.
Unless you look for E-MU1212m PCI-e, but they are rare, expensive and have even more problems with drivers.
Reply 4 of 4, by Azrael128
Okay, so for the sake of anyone having a similar question in the future and stumbling upon this thread. I got a new adapter from Star-Tech, based on the Pericom PI7C9X118SL - and I do insist on 118, not 111 - and it seems to be working. Audio outs all work, p16v works, ASIO works, line in and mic in work, all this using kX on Windows 11. I didn't even need to change any setting in the BIOS, it just worked out of the box.
Now, I'll wait a few days to see how stable it is in the long run. But at first glance, it works where the other adapters I tried failed.
