First post, by dylanrush
Hi Vogons, I have a Toshiba Satellite Pro 405CS that I've been babying. I've recapped the whiny backlight inverter, replaced the CMOS battery, fixed the nipple mouse, upgraded the RAM to a hefty 40MB, and decked it out with a nice DOS/ win 3.1 / win 95 tri-boot install. It's my favorite laptop in my collection and one of my favorite computers.
I am using a common SD/IDE adapter which seems to only want to support cards up to 4GB. If I put in a larger SD card the whole system seems to choke up - won't find a bootable volume, etc. 4GB is okay, and would have been astronomical back in the day, but I do want to put more games on there.
Most likely, this laptop's hard drive controller doesn't support larger drives, right? I can't imagine that the adapter has this limitation.
I do have an IDE/USB adapter so maybe I'll plug my SD/IDE adapter into that and see if a modern computer can detect a 32GB SD card. I may also buy an actual 2.5 inch, 80gb hard drive from eBay for $7 to see what it can do (probably nothing)
I also have a PCMCIA/CF adapter and that seems to only go up to 2GB.
Any ideas on how I might get the computer to recognize a larger drive?
Reply 1 of 4, by MikeSG
SD cards are a serial type bus compared to the parallel type IDE & compact flash cards, so SD cards have a speed limit.
The BIOS needs to detect a FAT32 drive if you want more than 4GB (?) ... If that's not possible you're stuck to 2GB or 4GB. But you could always just add extra drives?
Reply 2 of 4, by Truffon
Hi
You could try Ontrack (different versions available on Phil's Computer Lab website)
I managed to boot my 486 (limited to 2GB hard disks in bios) on a 40GB HDD after setting it up (limited to a 2GB FAT16 partition for MS-DOS 6.22 obviously).
I never tried on a SD card though, but worth trying IMO.
It's easy and quick to set up.
Reply 3 of 4, by dylanrush
MikeSG wrote on 2025-06-26, 11:23:
Correct me if I'm wrong but I don't think a BIOS from 1995 will have any notion of FAT16 vs FAT32 or even a partition table.
But no matter what kind of file system I use, FAT32 or even if I put a 2gb fat16 partition on a 32gb card, the laptop still has trouble with any card over 4gb.
How do you suggest adding extra drives to the laptop? This is interesting, I wonder if the hard drive controller would somehow allow that. I do have a CD ROM drive, I wonder if I can tap into that somehow and swap it with a hard drive...
Reply 4 of 4, by dylanrush
Truffon wrote on 2025-06-26, 12:34:
Hi […]
Hi
cool I will check this out!
