I tried the driver disc, nothing changed. No DOS apps in windows on this one, then. This one will be known as Hi-10, so I don't confuse them. The other one is now Hi-9.
I'll call it good, since it doesn't crash and everything works fine is DOS mode. I just put windows on because of the sticker, this is totally a fast DOS computer. I'll probably sculpt a boot menu/config/autoexec later.
I pulled the Hi-9 back out (again agian) to put a proper CDROM back in. I left it empty when I stole the drive for the Hi-10. I grabbed a few that might look the part, but decided on this 12X, because the yellowing almost matches perfectly AND it's almost as old as the computer.
The attachment 20250616_142528.jpg is no longer available
Big issue I noticed only AFTER I had it mounted: The eject button was broken... and you know what else? This drive does NOT have an eject, BUT the tray DOES just pull out.
The attachment 20250616_143533.jpg is no longer available
Not acceptable. I checked functionality and it was good (although, my CDROM driver takes a long time to load), so it's time to replace that button:
The attachment 20250616_143314.jpg is no longer available
The attachment 20250616_145016.jpg is no longer available
The attachment 20250616_150034.jpg is no longer available
I had to open it all the way manually before it started operating normally again and now it works great! I'm just left wondering why my CDROM driver takes so much longer to load. I'll try other drivers, to see if maybe the driver is not liking the drive. Not too often I see that, but it happens sometimes with the TEAC_CDI driver I normally use.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
