First post, by xtreger
I have a GA-EX58-UD3R motherboard and this link here: https://www.gigabyte.com/microsite/56/tech_090106_xfi.htm indicates that it's possible to use some utility called X-Fi MB to emulate up to EAX 4 via the onboard audio. The only problem is - the utility is nowhere to be found! It's supposed to have 3 parts of 70+70+44 mb, whereas the only x fi MB version I've found is a paltry 4 mb, here: https://sound-blaster-x-fi-mb.updatestar.com/ (this same version also on dell's website). 4 mb vs 184 mb is quite a bit.
The links originally on that website are dead and none of the motherboard models have that utility on respective download pages anymore. Neither gigabyte nor creative links work. Is there any way at all to get that utility?
