castrop067 wrote on 2025-06-30, 12:11:
It seems that's the only option I have left. I have a 286 and a 386 with a display, for which I found the manual, and the configuration was easier for me. Now it's just trial and error.
Thanks.
Deploying logic, 20 and 16.
0 uses 6 out of 7 segments, there are 6 use on the bottom right 7, the missing one is probably the centre crossbar
6 uses 5 segments, there are 5 on the bottom left 7
1 uses 2 segments, and 2 uses 5, breaks down a little but looks like top left might be the 1 and top right might be the 2
