Reply 300 of 313, by feipoa
- l33t++
Depending on the 3rd party IC-only supplier you choose, you can specify "new, original only" for the IC's and I have had good luck with this. When asked, they will often say if the part is or isn't new/original.
When I check the IC support list on my TL866II Plus, I see no mention of the EPM3064 or the ATF1504. http://www.xgecu.com/MiniPro/TL866II_List.txt
Similarly, when I check the support list on my Wellon VP-390, it also doesn't mention mention support for the EPM3064 or the ATF 1504. http://www.weilei.com/VP-390list.htm
As such, I am guessing that you used the TL866 to programme only the ATMEGA8A, then used the FT232H to programme the ATF1504? Can we order the ATF1504 pre-programmed? I recall seeing some of these options when ordering parts from Digikey.
Indeed, the HASL PCB's might reduce interest. If I ever have time for this, I'm going with gold contacts. The bracket can be mickeymoused if you don't have a 3D printer. This project is fairly low on my priority list because I already have two of the Rio444 original units, but could use another unit for my testbed. I was hoping that by the time I'm more eager for another one of these ISA cards, that the war in Ukraine will be over and I can merely order another adaptor from Rio444.
