First post, by andre_6
Hello everyone,
Last year I got an ATI HD 2600 XT AGP for my Windows XP (32 bit) build as I was advised it would probably be the most powerful I could find for that OS, with AGP interface through my Asus K8V-X board. I remember that even at the time I had trouble installing it, as Windows XP always took the drivers as unsigned so Catalyst setup would always skip over the drivers, reporting it in the log.
I ended up having to do it through Device Manager and pointing Windows to the .inf file, in this case CX171026.inf. The drivers package I used was "14-4-xp32-64-dd-ccc-pack1", the only drivers I could find that would work in XP, albeit with these issues.
I used the PC normally, and now a year later I was using it with some different games I hadn't played before, and I immediately noticed small graphical aspects that I attributed to drivers. I remembered my previous pain with them, still I tried again to find fully compatible ones, as in installing normally through Catalyst setup. I had no such luck again, as all of them abort the installation even through .inf pointing in Device Manager, stating they "couldn't find the necessary file", not specifying anything else.
I tried then to at least return to the previous drivers I had installed, and now I can't even reinstall them through .inf pointing as before, as it keeps asking for ATIICDXX.dat, which I only found as ATIICDXX.msi. If I try to run the .msi one it states it's not a Windows Installer. Before that it also asked for ATI2EREC.dll, which I could download separately and place in the System32 folder, but the ATIICDXX.dat just won't let me go through. So now I'm at a loss with all this.
1. Does anyone know of fully working signed drivers for Win XP 32bit for this card? Maybe even a CD image somewhere?
2. If not, could you at least point me out to some high end AGP cards for Windows XP 32 bit that is fully working in this OS? I'll just get another card if it comes to that.
3. My plan was to solve this graphic card issue in order to then upgrade my AMD Sempron 2800+ to a 3700+ Athlon 64. As my board is an Asus K8V-X, according to CPU upgrade it's compatible right?
As always, thanks in advance for all your help and replies
Reply 1 of 18, by Imperious
Try the 8.3 driver https://www.guru3d.com/files-get/ati-ca ... it),4.html
I've used this with my HD3850 AGP. You may have to force install, hopefully not though. The 14.4 driver is not optimised for older hardware.
Use a display driver uninstaller first.
Reply 2 of 18, by Repo Man11
Be sure to run the installer as an administrator, and uncheck the "Protect my computer from" blah blah blah.
Reply 3 of 18, by andre_6
Imperious wrote on 2022-10-28, 00:20:
Repo Man11 wrote on 2022-10-28, 00:40:
Thanks for your help guys, no luck. I used DDU version 1.6 which uninstalled everything swiftly, and restarted. Ran the 8.3 driver as an admin and unchecked the "protect" box. It extracted, allowed me to choose the type of install, and when it came to launch the ATI Display driver setup it displayed that "setup did not find a driver compatible with your hardware..."
I also followed this tutorial to a tee with its files as well: https://www.youtube.com/watch?v=LJmflrDk6Ew
Which also used .inf pointing to install the drivers, but while the author's installed well, mine go all the way to the end also, but where it also turns black with the cursor on the top left for a second I get a window that instead of saying "drivers installed" says "Couldn't install... didn't find the specified file", but again, not stating at all what that file is...
Reply 4 of 18, by Repo Man11
I had similar issues with an HD4650 years ago - the only installer I found that worked without having to force install the driver were from the manufacturer's site.
Reply 5 of 18, by Imperious
Try this AGP hotfix driver https://drivers.softpedia.com/get/GRAPHICS-BO … 06-for-XP.shtml
Reply 6 of 18, by andre_6
Repo Man11 wrote on 2022-10-28, 01:43:
Imperious wrote on 2022-10-28, 01:55:
The drivers from AMD didn't even had the display driver option on the list of item to install, forcing installation led nowhere too...
The AGP hotfix driver was the closest one through normal installation, recognized the display driver to install but midway installing popped a window saying the .inf file wasn't found, after I tried to force install it but at the end got the same "couldn't install driver, didn't find the specified file" message
Reply 7 of 18, by Imperious
It sounds like You've got more than just display driver issues if it can't even find the files.
Reply 8 of 18, by andre_6
Solved it!
After everything I've tried, I cleaned everything up once again with DDU, uninstalled and removed the sound card also just in case, and cleaned temp files one more time, etc. Then I picked up a spare FX 5600 XT I have and installed it. It worked fine after the setup, so now I uninstalled its files with DDU again.
I put the XP CD into the drive just in case, re-installed the HD 2600 XT and ran the setup files that came in the tutorial shown in the YouTube link above, which consists of extracting one setup with signed drivers but installing them through .inf pointing, and then extracting another setup to manually install the Catalyst Control Center separately. It worked!
Just in case, I also ditched the drivers I was using with my SB Live 24Bit, and downloaded the CD image for it in Vogons' drivers archive.
What a relief, thank you for your help and pointers, much appreciated
Reply 9 of 18, by Studiostriver
andre_6 wrote on 2022-10-28, 21:44:
Solved it! […]
Solved it!
I just ordered MSI ATI Radeon HD 2600 PRO 512MB DDR2 AGP and want to check it on my Penitum 3 configuration. I hope i will not have similar problems like you, 🤣. 😀
Reply 10 of 18, by Archer57
Studiostriver wrote on 2025-07-03, 00:22:
Or problems like i had... Re: Radeon HD2600XT AGP, any driver version for XP 32 that's stable?
Ultimately from what i was able to figure out this issues probably are not drivers, but some kind of hardware incompatibility. Not sure what specifically is at fault, but i was not able to make the card work on any of my socketA systems. Different motherboards, different PSUs, whatever.
It, however, works just fine on S478 with 2Ghz northwood i got. With any drivers. Performance is poor though - more specifically minimal FPS is very low - a lot of stutters. Especially in older stuff, like even 3dmark 2001se. But benchmark results are nice...
Also compatibility with older games is... questionable.
Overall my opinion - the card is trouble and not worth getting. But may be you'll have better luck with yours...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,2GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 11 of 18, by Studiostriver
Archer57 wrote on 2025-07-03, 01:36:
Or problems like i had... Re: Radeon HD2600XT AGP, any driver version for XP 32 that's stable? […]
My motherboard is indeed very old, from 2000 model( Bios updated for 2001) DFI CA64-TC Socket 370 VIA 694T ATX Intel
https://theretroweb.com/motherboards/s/dfi-ca64-tc
Anyway i`m gonna test it and see how it will behave. If it sucks , well i bought it very cheap so i have no regrets, and i can sell it for similar price i guess in a future. 😀
Wish me luck.
Reply 12 of 18, by Archer57
Studiostriver wrote on 2025-07-03, 01:57:
My motherboard is indeed very old, from 2000 model( Bios updated for 2001) DFI CA64-TC Socket 370 VIA 694T ATX Intel https://th […]
Wish me luck.
Yeah, definitely good luck.
And yeah, i fell for lower price too. I have a feeling they are relatively inexpensive and common for a reason - people buy them, then resell them and the cycle continues. While even slower nvidia cards are relatively rare and expensive because they work...
If i was picking a card for P3 system nowadays it'd probably be something from FX series. They were... disappointing back then, but nowadays they have good compatibility with old games and mid range ones still cost reasonable amount of money.
Even simple FX5200, bad as it is (and dirt cheap) can be quite decent for older stuff.
Reply 13 of 18, by Studiostriver
Archer57 wrote on 2025-07-03, 02:18:
Yeah, definitely good luck. […]
Wish me luck.
I want to put FX5200 PCI model in the same computer, and for AGP i have know 6600 GT which actually runs amazing for XP, have no complains , other then one crash on 2003 benchmark, but on 2004 it runs fine. With games i tested i had no crashes and i played so far about 10+ titles.
Reply 14 of 18, by Archer57
Studiostriver wrote on 2025-07-03, 02:22:
6600GT is a great card, IMO one of the best for AGP. Also a significant overkill for such system. Do experiment with drivers a bit too, i've had interesting issues with 6600 (non-GT, much slower) i have. Some crashes in older games on latest driver, which did not happen on the same driver with newer cards (7300GT). Ultimately ended up using 175.19, which is the last driver for FX cards (and can be downloaded as such from nvidia site). Slightly better performance on both 6x and 7x cards and no crashes on 6600.
Not sure how useful PCI FX5200 (FX5500? Do be careful getting this as there are a bunch of newly manufactured ones using GPUs from AGP FX5200 with rather low quality), I'd only bother with that if there are actual issues with something you want to run on 6600GT.
Reply 15 of 18, by Studiostriver
Archer57 wrote on 2025-07-03, 03:17:
6600GT is a great card, IMO one of the best for AGP. Also a significant overkill for such system. Do experiment with drivers a bit too, i've had interesting issues with 6600 (non-GT, much slower) is have. Some crashes in older games on latest driver, which did not happen on the same driver with newer cards (7300GT). Ultimately ended up using 175.19, which is the last driver for FX cards (and can be downloaded as such from nvidia site). Slightly better performance on both 6x and 7x cards and no crashes on 6600.
Oh yeah, there are new manufactured 5200 PCI models recently and could get cheap. Who knows how it will work , but i`m willing to try it. Worst could happen is that it would not work well and thats it. 😀
I tried so much different drivers and with some i had terrible results, with some pretty good on XP with 6600 GT. Nedless to say the only agp card on which i could run Wizardry 9 without freezing due to bad graphic card performance. This game is just directx 7, but so demanding for there old systems, and needless to say it looks beyond amazing compare to HIS 9600 256 XT model i used before.
I`m just sad it wont display 640x480 resolution at all on 98SE (i use dual boot machine), all other resolutions runs amazing! Why, i have no clue really, but i could not try too much drivers for 98x, if memory serves me well only 4 or 5. On most it runs terribly even desktop display, but on one i use know it works pretty good, except above mention problem.
Anyway i am willing to try this MSI ATI Radeon HD 2600 PRO 512MB DDR2 AGP. I know it has no support for 98x, that is why i wanted to order fx 5200 PCI to see if i can have good compabillity with both os on different cards.
Thanks for response, i really enjoy listened other peoples experiences as i`m alone in my town who is into retro computers and consoles.
Reply 16 of 18, by andre_6
Studiostriver wrote on 2025-07-03, 12:29:
Oh yeah, there are new manufactured 5200 PCI models recently and could get cheap. Who knows how it will work , but i`m willing […]
Hey, if you follow the YouTube tutorial that I pointed out earlier right from scratch to a tee I'm quite sure you won't run into any issues. Just do the drivers and Catalyst installs separately according to the tutorial's methods. There's definitely some kind of temperamental incompatibility that remains unknown, at least to me. I've since switched the sound card from the SB Live! 24-bit to an Auzentech Meridian, and everything kept going and has been running fine for years without incompatibilities. I've reassigned the SB Live! 24-bit to my Win2000 build, I find it to be a very underrated card for mid-late Win9x games up to early-mid XP era of games.
I've also resoldered the 2600XT's fan cable and relubed it, thermal paste, etc. Has been running quietly and steadily ever since. I don't know how it goes these days, but it used to be a very good and affordable card for games from the XP era only a few years back. Feels solid and very compact compared to the Nvidias. I wanted something slightly more period correct as opposed to more powerful later Win7 era hardware, as my XP build is the only original computer that I had from the era that's still in my hands. So I wanted to complement it without changing it around too much, but still give it some oomph within XP era games' demands compared to the 9600 Pro I had in this build. Pairs very well with the Athlon 64 3200+ 2.2Ghz that I've upgraded to from my original Sempron 2800+ 1.6Ghz.
Got that balance right between oomph and period correctness for XP. Definitely give it a try, I like it.
Reply 17 of 18, by Studiostriver
andre_6 wrote on 2025-07-05, 18:15:
Hey, if you follow the YouTube tutorial that I pointed out earlier right from scratch to a tee I'm quite sure you won't run into […]
Thanks. I`ll definitely try it. Cleaning the card right know, my model is passive, but its obviously havent been used for a long time. Time for alcohol 75% and new thermal paste. 😀 I will let you know if i manage to make it work, and i`ll look closely the tutorial you pointed out, thanks a lot for that.
Reply 18 of 18, by Studiostriver
Aaaaaaand it works! Pentium 3 is blazing fast with this card! Its even faster then Nvidia 6600 GT and picture is so precise and bright, love it. So far i keeping it in this computer, and its even 10 C less hot. I cleaned it, and put new thermal paste.
