First post, by shandavid
Sorry for the double post
Changelog:
v3.0:
-SGM-X48 is now renamed SGM-Pro, as the "48" no longer reflects the file size.
-New Sounds.
-Improved sound quality.
-Improved volume balance.
-Some minor fixes.
Download:
https://drive.google.com/drive/u/2/folders/1r … PRNggRO-OedAeH9
Demo music:
a light rain
https://www.youtube.com/watch?v=QWBA7zdQoDM
はあるよこい
https://www.youtube.com/watch?v=aIOJMuW-xyU
夢の森
https://www.youtube.com/watch?v=C_1ElMItJ0A
YS4 - Forest of Celceta
https://www.youtube.com/watch?v=429EzMHtPhU
Reply 1 of 10, by bristlehog
I quickly tried it in Reaper, namely the timpani patch, but found it to be too loud with audible overloading, and even a limiter plugin can't save the situation. Seems the volume of at least this sample should be tuned down, if I'm not missing anything.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 2 of 10, by shandavid
bristlehog wrote on 2025-07-09, 07:12:
It is recommended to use it with VirtualMIDISynth, which should have fewer problems.
Reply 3 of 10, by bristlehog
shandavid wrote on 2025-07-11, 07:35:
I don't think it is a problem of the Sforzando VST I use to play soundfont patches. I don't have any loudness problems with dozens of other soundfonts I use, apart from Crisis GM 3.51 soundfont, which is too quiet.
Reply 4 of 10, by shandavid
bristlehog wrote on 2025-07-11, 07:42:
In order to achieve the same volume balance as Roland sc8850, the waveform exceeds the maximum volume by 0.xdb, less than 1db as I remember,
The sound should not have obvious audible distortion, I hope...
Reply 5 of 10, by bristlehog
shandavid wrote on 2025-07-11, 09:24:
There is an obvious audible distortion when playing a timpani-heavy track, like this Heretic E1M9.
Reply 6 of 10, by shandavid
bristlehog wrote on 2025-07-12, 05:44:
I uploaded two videos of SGM v4.0 and Yamaha TG300 playing E1M9 midi. I can't really tell the difference... have a listen
https://drive.google.com/drive/folders/1cDLst … rl8Hc0tDlIqhJM6
Reply 7 of 10, by bristlehog
shandavid wrote on 2025-07-12, 15:41:
Both tracks have overloaded, but the SGM is distorted noticeably worse than TG300 - the latter has only intermittent distortion "clicks", while SGM has them all over the place.
Reply 8 of 10, by shandavid
bristlehog wrote on 2025-07-12, 16:18:
I think it's these notes that create the "distortion"... maybe the arranger did it on purpose
You can't get a clean drum sound this way...
Reply 9 of 10, by bristlehog
shandavid wrote on 2025-07-12, 18:51:
I don't think so, since I don't encounter any distortion with any other SF2 banks, of which I tried many while making a E1M9 cover.
Reply 10 of 10, by shandavid
bristlehog wrote on 2025-07-13, 06:20:
I just checked again, the volume gain is indeed too much, it will be fixed in v5.0
