First post, by apfel
I got a ASUS CUSL-2 mainboard from eBay and tried to get it running for a Win98 Setup. But no IDE Device is recognized.
I tried to connect a DVD-RW IDE Drive and a 3,5" 160GB SATA HDD with a SATA-IDE Adapter.
I reset the BIOS
The HDD+Adapter and DVD worked fine on my Windows 11 machine with a IDE to USB Adapter.
Both set to Master and both connected to a seperate IDE Port on the Mainboard.
Tried it an Primary and Secondary IDE for just the DVD Drive.
Tried the external power source from the IDE to USB Adapter and conneting the devices to the mainboard.
BIOS Setting is Auto for all Primary and Secondary IDE devices.
Is it possible the controller is damaged? Are there any other things I could check?
