My 2003 dream PC
First post, by Danger Manfred
I finally finished my 2003 dream rig!
The case is an Enermax Silver Wizard 2 that comes with color changing LED pillars in the front, and I had to modify the back a little bit to accomodate some additional video outputs, but I'll get to that later.
I hunted down a transparent Levicom PSU with UV reactive cables, since I wanted to go with a complete 2003 modding case look.
The motherboard is a Gigabyte GA-7NNXP, which is among the coolest you can get for socket 462: blue PCB, Nforce 2 Ultra chipset (SATA, Gigabit Ethernet, USB 2.0, FSB400, DDR400 Dual Channel), dual BIOS, 4 RAM slots, AGP Pro slot, 12V power connector for the CPU (many 462 boards use the 5V rail to power the CPU instead, good luck finding a good PSU for that today), and a daughterboard with 3 additional VRMs for a total of 6, which doesn't really add to the overclocking ability but at least keeps the VRMs nice and cool. The only negative thing about the board is that it doesn't have mounting holes for socket 462 coolers, so I have to rely on coolers that clamp onto these little "noses" on the socket instead.
The CPU is an AMD Athlon XP-M 2400+ ULV. Unlike the normal XP-M 2400+ Barton, that is binned to run with only 1.45V at 1.8 GHz, this one is binned even further and only needs 1.35V.
This is cooled by an Aerocool HT-101, which is a full copper triple heatpipe tower with an 80x25mm fan. Transparent blue plastic cage around the thing to hold the transparent blue LED fan, really looks the 2003 part.
The RAM: Corsair XMS Pro DDR 400 CL2 with activity LEDs on the top, 2x512 MB in dual channel mode
The graphics card is a bit exotic, too: a Medion Radeon 9800 XXL is basically an OEM Radeon 9800 XT produced by MSI for german discounter Aldi for their prebuilt PCs. These have slightly lower clockrates compared to regular 9800 XTs, and use 128 MB of cheaper RAM that basically doesn't overclock. So why use it? Because it has a connector leading to an addon board with TV output signals, and that one has it all: composite, component, SCART and S-Video!
I can use this to play SNES and N64 games and output them not just to a real CRT, but even to a real CRT TV! Who needs CRT shaders when you can just use a real CRT!
I had to cut out a bit of the back of the case to make room for these outputs, but it's so worth it. The screen is basically cloned to the TV at no performance hit.
The cooler has been upgraded to a Zalman VF-950 Fatal1ty Edition, which is basically a VF-900 CU that has been nickel plated and the fan runs at 3600 instead of 2400 RPM max, which makes it unnecessarily loud, but back in the day neither me nor my friends cared about noise at all, so I decided to stay true to that and just accept it.
For a sound card I used a Terratec DMX 6fire 24/96 with a really cluttered looking silver front panel that can hold a wavetable daughterboard. I'm not using this function so far, but maybe I should.
To hide the non-era-appropriate SATA SSD, I use a silver front panel with a small backlit screen showing the temperature.
No ODDs here, but a 2.5" fan controller by Revoltec.
I'm really happy with it so far, running UT2004, Etherlords 2, Freelancer and some emulated stuff!
My pile of defective hardware that I'll fix if one day my hands stop shaking
Reply 2 of 9, by pete8475
Maybe try resizing them before uploading or changing the format? I usually upload fairly low res PNG files and they work.
Reply 3 of 9, by Intel486dx33
Nice, I built my own Ultimate Terratec computer a while back.
Love those Terratec sound cards. I purchased some more.
Crystal clear audio with good Base.
My post
Ultimate Audio / Gaming build - Terratec/SB Audigy2zs
Reply 4 of 9, by Archer57
An interesting S462 build. With some quite interesting/uncommon parts too.
A few questions:
Do you overclock, or are you running it stock and simply wanted less heat? If you do, what are the results? How good BIOS options are on this board? I have socket A Gigabyte board and the bios is quite bad...
How well the SSD is working with sil3112 controller, did you have any issues, or are you using ide-sata?
Are you running RAM async at 400 with CPU at 266? Did you try running memory benchmarks to see how well it works? From my experience nforce2 can be a bit quirky and sometimes running at the same frequency as FSB (perhaps with tighter timings) can actually be faster. Though i usually compared 333 to 400...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,2GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 5 of 9, by Danger Manfred
Archer57 wrote on 2025-07-02, 00:23:
A few questions: […]
A few questions:
I'm running this at 12x200 MHz, 1.7V. I can go up to 2.6 GHz if I give it even more voltage, but I want this thing to live a while, so I don't.
The BIOS options are I would say average, slightly less than on my Asus A7N8X-E Deluxe, maybe comparable to the Abit NF7-S v2.
The SIl3112 controller didn't even detect my Gigabyte 120GB SATA SSD for whatever reason, so I decided to use an IDE2SATA adapter after all, to hide the SSD inside a mobile rack. I fully admit I went for the looks here, and the only silver one I have, that even has a small display, is IDE.
Reply 6 of 9, by Danger Manfred
Intel486dx33 wrote on 2025-07-02, 00:05:
Nice, I built my own Ultimate Terratec computer a while back. Love those Terratec sound cards. I purchased some more. Crystal c […]
My post
Your build is quite beautifull, too! I commented in the thread.
I started collecting Terratec cards, too, but mainly for DOS and Windows 98 gaming purposes.
I somehow ended up with an EWS64XL (which is great for DOS gaming due to its cool wavetable synthesizer and front module) and the EWS 88 MT (which I probably won't use after all, since I lack all the necessary skills to get into music or audio production). I already got most of the cards I was looking for, except for the Maestro 32/96. I was too late to get an affordable GUS so I make do with a PicoGUS that's still selling around 50 bucks, and my unobtainable dream is a Guillemot Maxi Sound 64 Dynamic 3D. Maybe I could find someone who trades it for one of the big ass AWE 32 cards with memory expansions or some such. On the bright side, I was lucky enough to end up with two Terratec wavetable daughterboards: the SOWT-24 Wavetable System Professional and Dream GSWAVE.
Reply 7 of 9, by Archer57
Danger Manfred wrote on 2025-07-02, 09:56:
Nice. Though it does show that ultimately this chips are limited to ~2.4Ghz without significant voltage increase. Binned or not, unlocked multiplier or not... My 3200+, having locked 11 multiplier does run at 11x220 at stock 1.65v if i really wanted to, though i do not want to overclock this old hardware and did not really do any stability testing past booting into windows and running some 3dmark.
And yeah, my experience with SIl3112 has been about the same - unusable. Either does not detect at all or detects but does not work properly, sometimes in a bad way - data corruption etc. Something to be aware of when picking a motherboard...
This motherboard is really cool though, with extra VRM components, MCP2-T etc. Regardless of any limitations. And the fact you were able to OC, set voltage, etc means it is not that bad in terms of BIOS...
Looks are fun too. Even though it was never really my thing, i usually build simple functional systems, looking at setups like this is always fun and almost makes me want to build one...
Reply 8 of 9, by Bruno128
Speaking from experience with a similar build.
Acrylic 2003 build (January 2024)
You can mod a newer Sii3112 BIOS ROM in your motherboard BIOS. It will help with drive detection and data corruption.
However, even a mild overclock makes this controller go crazy.
SBEMU compatibility reports list | Navigation thread
