Reply 29860 of 29871, by octopus
PcBytes wrote on 2025-07-09, 20:56:
I can confirm that - I have an Aspire X-Cruiser on the way. I'm actually undecided if I should save and buy a BX2000 PLUS for it or go with something newer.
That case is awesome! Does it fit a full size atx?
Reply 29861 of 29871, by PcBytes
I think it does. I've rarely seen any of its caliber that wouldn't do full size ATX 🤣. Maybe not E-ATX but standard full ATX is defo on the table.
Reply 29862 of 29871, by NeoG_
Today I saw an LGR video on the dazzle parallel port capture device and one of the pieces of software showcased on the disc was VideoSaver Pro which gave me an idea. I tracked down the ISO file Clint uploaded to internet archive to try out the software. It had a bunch of generic video content that I promptly removed from the playlist.
I converted a bunch of YouTube videos of mid 80s to late 90s era hardware, software and game promos and TV commercials into MPEG1 using ffmpeg and loaded them into the software as a playlist. I also rolled in a bunch of Microsoft adverts included on the Win98 disc.
So now the screensaver on my retro system is random play of golden era video spots, trailers and local computer stores selling PC bundles.
Still on the lookout for more interesting commercials/promos from the era to add to the rotation. My favourite so far is the Intel MMX 1997 "Stayin' Alive" TV spot. Second favourite is the 1988 AdLib promo.
Retro Rig: SS7 AladdinV, K6-2+/600, V3 3000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, ES1868F, PicoGUS, WP32 McCake, iNFRA 6000 CD
Reply 29863 of 29871, by vutt
vutt wrote on 2025-05-24, 16:06:
Modding day. This card has annoying fan whine at full tilt in Win98SE. Card has full sensor set and Asus SmartDoctor tool to for […]
Modding day.
This card has annoying fan whine at full tilt in Win98SE. Card has full sensor set and Asus SmartDoctor tool to for setting custom fan profile, but it's WinXP+ only. So I installed WinXP just for Temp tuning.
At first I put there regular 2W resistor but it heated up ~50C. 5W ceramic one while bulky seems to be fine. 82Ω brought fan RPM down to ~4000RPM from 6000+ default speed.
Results: GPU core seems to be floating in low-mid 40-ies now under load. However hottest part is actually memory ~52C and back side mem chips are naked. Not sure where temp sensor is located.
I'm using my retro rigs in semi open bench inside shelf. So this mod might not be good for tight less ventilated cases.
Streamlined little bit my 9600XT fan speed mod look. Replaced bulky ceramic resistor. It turned out that 3W SMD resistor is cool enough for my application.
Reply 29864 of 29871, by kinetix
I made a DRAMarduino https://forum.defence-force.org/viewtopic.php?t=1699 to test some amount of 4164 and 41256, installed in some boards and spares.
Got it working with my Arduino Uno R4.
Today I enhanced the original code, with some help from Copilot.
I added: Fill, WalkingBits, Checkerboard, Retention, Inversion, AddressAliasing (this one is sloooww).
"Fill" was the basic original test, but some chips passed this test and faults with the more strict ones.
Still working on some even more stricter integrity test and maybe add a couple of modifications from other people
Latter on I will share the code
Reply 29865 of 29871, by Archer57
Fixed a broken pin on those 6400+ AM2 Athlon64 X2 i got. Would not say it is hard, it takes just a couple of minutes, but it is definitely challenging in terms of working with tiny stuff and seeing it well enough to work with it.
The attachment 20250711_201949DE.jpg is no longer available
The attachment AM2.jpg is no longer available
So i've basically stolen "reserved" pin nearby and soldered it in place of broken one. It works:
The attachment 6400+.jpg is no longer available
Also while i was testing the CPU thought i'd test pci-e x1950pro i had laying around for years. Needed a card anyway since this motherboard does not have integrated graphics and since i was investigating AGP versions recently thought - why not. It works, but... i must be cursed or ATI/AMD really makes the most buggy hardware/software in existence.
This time it was unable to detect resolutions supported by the monitor, which resulted in weirdness like native 1920x1080 being stretched into gigantic image i have to scroll around to get to things. Had to specify custom resolution just to get the desktop right and when i tried to run a game with 1024x768 it did not work correctly either, so i gave up with the card for now.
I mean i did connect it through DVI-VGA adapter and through KVM, but i've used this exact setup to tests dozens of different cards in different systems and it is the first time i've seen this issue.
ATI/AMD stuff just never works right for me for some reason...
Reply 29866 of 29871, by kinetix
I created a topic Extended DRAMArduino code with a code I expanded from the DRAMarduino project https://forum.defence-force.org/viewtopic.php?t=1699
It has been expanded with the help of Copilot and tested with an Arduino Uno R4 Wifi, but it should work with others, taking the pins into account.
I focused on this project because it's very simple, inexpensive, and just what I needed for the memory chips I wanted to test.
The tests included are Fill, Checkerboard ,Retention, Inversion, WalkingBits, MATS++, MarchC, MarchA, Address Aliasing.
Is a work in progress.
Reply 29867 of 29871, by CrFr
Fixed the screen mechanism latch (again) on my IBM PS/2 P70. This thing just keeps breaking, and every time I make sturdier replacement part. Maybe this time it will last more than two years 😀
The attachment IMGP2442_.jpg is no longer available
Reply 29868 of 29871, by dominusprog
CrFr wrote on 2025-07-12, 12:37:
Oh, wow! What a beauty 🙂.
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 29869 of 29871, by schmatzler
Due to very lucky circumstances I acquired two more Dell 2007FP monitors and I've set them up on my Windows Vista machine (that's running an GeForce 780Ti).
One of them is connected via VGA (because the blue channel is missing on DVI), the other one with a DVI to HDMI adapter and the third one with plain DVI.
This feels like the most decadent retro corner ever and I love it. The third screen is noticeably darker (I grabbed that from my soon-to-be former employer where it ran nonstop for many years) so I'll probably try to swap the CCFL's in the near future.
Reply 29870 of 29871, by gmaverick2k
replaced my gtx 960 with my gtx 970. Also, "repasted" my msi gtx 970 (never been repasted since i got it) with PTM7950 I had laying around from a cooling project on my thinkpad t480- msi afterburner showing temps hovering around 60degC in astuffy thinkcentre e72 case. installed noctua on intake of case 60mm (?), replaced xonar dx with x-fi titanium
file.php?mode=view&id=223310
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Reply 29871 of 29871, by Joseph_Joestar
If it counts, I just watched the guys from Digital Foundry analyze Doom performance on period correct hardware. 😁
Relevant video.
