Reply 20 of 37, by Falcosoft
- l33t
stanwebber wrote on 2025-07-13, 13:06:i read this whole thread & i'm still confused. did the OP ever get a cf card aligned to 2048 sectors to boot in his 386 machine? […]
i'm running into this same issue right now with an early p54c pentium bios. is the limitation bios or dos related?
this CAN work with dos 7.1 & fat32 on an award kt133a bios. i partition either a sata ssd or cf card with gparted aligned to 2048 sectors and the os just boots. the only problem i ran into was dos not recognizing a logical drive in an extended partition unless it was cylinder aligned with dos tools.
now i have a fat16 1gb cf card that will not boot in my p54c pentium machine unless i partition it with dos fdisk. when previously partitioned with gparted aligned to 2048 sectors, dos had no problems recognizing the drive from a boot floppy--just no boot.
what is the magic for alignment? if rmprepusb is the answer, what is it doing differently that gparted isn't?
The moral of this whole thread is that there is no point to partition align FAT/FAT32 volumes to 2048 sectors. This approach works in case of NTFS since the metada is part of the file system but it does not work in case of FAT/FAT32 since the metadata/header is before the file system so proper alignment works differently
(from here: Re: MS-DOS with aligned partitions on CF card, is it possible?)
