First post, by RichB93
- Oldbie
Thought I'd make a post on this as I picked one of these up recently and there seems to be very little, or even incorrect information online about it.
This device appears to use the Sound Canvas SC-50 sound module - the manual states 226 sounds + 8 drum sets (+ 1 SFX) which matches the SC-50. The MT-120 manual oddly omits the fact that there is full chorus, reverb, delay etc, which originally lead me to believe this had a very cut down sound module in it, but having tested it, this simply isn't the case. Everything is there.
The only difference between the SC-55 and the SC-50 is the lack of MT-32 compatibility bank (variation 127), so very little of value is lost.
Looking around inside shows the same chips as used in the SC-5x devices; the same main PCM chip, samples, etc.
The bigger brother of the MT-120, the MT-200, does have MT-32 compatibility so is therefore based on the SC-55.
I imagine both are closer to the mk II, given the date of these devices.
Rather brief post I know but just wanted to share in case anyone has a chance to pick one of these up.
