First post, by Un Information
I've tried out this software for MS-DOS: http://www.oldskool.org/pc/throttle/DOS, I've read that it disables the L1 cache once used. Is there anyway to re-enable it once it does this?
There's no option for me to re-enable it in BIOS.
Reply 1 of 8, by gerwin
Un Information wrote on 2025-07-16, 12:46:
"Command line options: ... -c = do not disable the L1 cache"
Reply 2 of 8, by Un Information
gerwin wrote on 2025-07-16, 13:01:
Does it stay disabled after using it without that command though?
Reply 3 of 8, by gerwin
Un Information wrote on 2025-07-16, 13:14:
That would be the proper way to handle it.
If you want to toggle L1 cache exclusively, you can use the tools in CacheOff.zip here:
A question about speed
Reply 4 of 8, by DaveDDS
This reminds me of "many years ago" when I made a quick-and-dirty tool to slow a MS-DOS system
(damn new processors were just too fast for some stuff) - it was "super simple/stupid", but it worked
for whatever I was trying to run at the time...
All it did was hook the BIOS 55ms timer-tick, and added a nice-big "do nothing" loop into it...
Overall system speed slowed nicely, but obviously full-speed in between the 55ms ticks. I don't
recall why I needed it, but whatever it was must have been sensitive to longer-term "to fast".
And it was super simple to implement!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 5 of 8, by theelf
When select 0 in throttle, it just enable l1 again
Reply 6 of 8, by Harry Potter
DaveDDS: when I first heard about this type of speed-sensitive software, I admit that I thought that what you just said was how slow-down programs worked. I have a few DOS programs on my computer P4 Win98SE tower that need it. I should look into CacheOff.zip but am curious about your method. Can you publish it online?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 7 of 8, by DaveDDS
Harry Potter wrote on 2025-07-16, 14:37:
It was so many years ago that I don't think I still have it (or would know where to look)
.. It was dead simple, and would be very easy to replicate... Lust take over the 55ms tick interrupt,
save-state, loop for however long you need, restore state and JMP the original interrupt handler address.
Reply 8 of 8, by Un Information
gerwin wrote on 2025-07-16, 14:07:
That would be the proper way to handle it. […]
Thanks, I'll try this.
theelf wrote on 2025-07-16, 14:36:
Yeah, I had issues with it freezing Descent and causing the MIDI music to mess up, even after the value was set to 0. Restarting seems to have stopped it.
