Reply 20 of 26, by Living
btw, does someone found pictures of early 386 motherboards? (im talking pre 1987)
the earliest one i found both in pictures and in person was from 1988
https://www.redhill.net.au/c/c-3.php
i what it says on the top articule of the DX-25 its true, there were not many sold and kinda overlaps with the 486
Reply 21 of 26, by renejr902
the post card analyser was defect, i tried it on others isa computer. i just bought a new one on amazon with 6 red led instead of 3 led. The 3 led post card looks cheap. we have made new soldering and repaired some lines but it still dont boot. all voltage are good everwhere on the motherboard, even the isa port
Reply 22 of 26, by douglar
Living wrote on 2025-07-21, 02:38:
There were 386 computers that started showing up in the second half of 1986, but they were mostly servers and prototypes, non standard motherboards in bulky heavy cases, the kind of thing that goes to e-waste quickly as soon as its performance window is gone.
https://archive.org/details/BYTE-MAGAZINE-COM … /mode/2up?q=386
386 workstations started showing up in the second half of 1987, but they were still > $5000 and the 386 multiply bug was still prevalent.
https://archive.org/details/byte-magazine-198 … /mode/2up?q=386
Wasn't until 1988 that prices had fallen enough for mortals to afford them and by then the good Σ Σ chips were pretty common.
Although I remember trying to put a beta copy of Windows 95 on a PS/2 model 70 that was manufactured ~July 1988 and getting the "you gotta buy a new CPU" message.
Reply 23 of 26, by renejr902
douglar wrote on 2025-07-21, 12:56:
There were 386 computers that started showing up in the second half of 1986, but they were mostly servers and prototypes, non st […]
help me 🤣
Reply 24 of 26, by renejr902
new pics
Reply 25 of 26, by douglar
renejr902 wrote on 2025-07-22, 00:17:
help me 🤣
I was working on a 286 board recently that would fail at 2 or 3 or not post at all. It was vias corroded by the battery.
Double check those traces. These areas look really sketchy:
The attachment Untitled.jpg is no longer available
Re: Fixing a HEDAKA HED-986
Reply 26 of 26, by renejr902
douglar wrote on 2025-07-22, 00:27:
I was working on a 286 board recently that would fail at 2 or 3 or not post at all. It was vias corroded by the battery. […]
help me 🤣
we tested them again, they are good. We reseated all chips in correct position. i have no more idea. we checked every connection everywhere
