Socket AM2 Build Ideas
First post, by stinkydiver
Hello fellow Vogons
I recenetly picked up a few parts for an AM2 build for pretty cheap:
ASUS M2N-SLI Deluxe - Brand new in box: $15 USD
2 sticks of Corsair DDR2 XMS2 - 2048MB, 800mhz, 5-5-5-18: $11 USD
AMD Athlon 64X2 6000+ ADX6000IAA6CZ 3,0GHZ socket AM2 CPU: $22 USD
I'm considering a Noctua U12S CPU cooler to go with it, and possibly a new case that supports a ODD, or a second hand case in good condition.
What kind of "build" would these parts suit and paired with what video card? A 7900 GT? Or since the the 64x2 6000+ is from 2008 would it be better to pair with a 8000 or 9000 series?
Any recommendations on PSU requirements?
I was thinking it could be cool to do a "ultimate may 2006 build" with a AMD Athlon 64 FX-62, as this would be the best PC before the C2D came along and knocked AMD off its pedastool later that year AFAIK.
I have an Audigey 2 ZS which could possibly pair with it.
Back in the day I went from an Athlon XP to a Pentium 4 and then basiaclly got out of modern PC gaming for a good 15 years... so I missed the whole Athlon 64/C2D era
Take that there and put it in here
Reply 1 of 47, by Archer57
stinkydiver wrote on 2025-07-22, 23:38:
That's nice, just be aware that the chipset is very likely affected by bumpgate and may die at any moment. At least ensure good cooling. I'd probably replace the heatsink with something of decent size with a fan because this whole heatpipe thing which couples chipset to VRM is just silly.
IMO GF7 is quite underpowered for such system. It is also affected by bumpgate, as well as 8,9 and early 200 series.
IMO unless your goal specifically is period correct system or you want to run something especially tricky GTX750(Ti) is the easiest overpowered choice which will be cool, reliable and more than fast enough to never become a limitation on such system.
Modern PSU, unless you want to use a beefy GPU like 480/580/680/780 as low power as you can find would do. System like this should consume <200W...
AFAIK there was around 2 month period between FX-62 and C2D release, so probably not even enough to buy it back then. But yeah, building such systems is fun.
Just be aware, from practical point of view LGA775/C2D is significantly better than anything AMD all the way to ryzen. Take a look at discussions in this thread: Any love for AM2?
It is also easier to get. So if you are building system like this is is mostly for fun with hardware....
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 2 of 47, by stinkydiver
Ideally I would build a 939 system for XP gaming with AGP, but hey I don't see any 939 boards show up in my country very oftern and I just happened to grab this AM2 board because it was new and going for very cheap!
I do like to keep things period correct if possible. There is a XFX 8800 GT Alpha Dog going for around $26 USD or a ASUS EN7900GT for around $17 USD atm...
Reply 3 of 47, by Archer57
stinkydiver wrote on 2025-07-23, 01:07:
AGP is a pain. From practical point of view it does not make sense at all. Just take a look how much high end AGP cards cost...
But again... with this old stuff everything depends on what you want. I've built socketA system recently myself, with AGP obviously. Which triggered at this point half a year long hunt for decent GPUs which work and do not cost like RTX5080...
High end, hot, bumpgate affected hardware. It is either already dead or will die shortly. Especially 8800. Would not recommend unless you want specific cards regardless of functionality for some reason.
The issue with that time period is that all the GPUs are defective. You can mess with them if you want to, but if you have PCI-e anyway IMO it makes a lot of sense to just skip that period and go newer...
Reply 4 of 47, by stinkydiver
AGP is a pain you say? I agree with you re cost.. I've been looking to pick up a 9700 or 9800 pro for awhile and these are hard to come by for a resonable price. I'd love to build a socket A system paired with a 9700 or 8500, it would be far more to my preference than an AM2 PCIe build. I'll probably just end up putting these parts aside for a rainy day build with my son when he gets older 😀
But in saying that, cheap good condition pc parts are hard to pass up for collections sake
A few other options going for cheap in my hood
9600GT
https://www.gigabyte.com/Graphics-Card/GV-NX9 … 512HP-rev-20#ov
Radeon HD 3870 GPU
https://www.gigabyte.com/Graphics-Card/GV-RX387512HP
Reply 5 of 47, by The Serpent Rider
Unless you want GeForce FX/Radeon 9xxx or even GeForce 4 Ti, you don't need AGP. That being said, there are some PCIe GeForce FX cards too and Radeon X600 is basically Radeon 9600 for PCIe.
Reply 6 of 47, by Archer57
stinkydiver wrote on 2025-07-23, 03:23:
AGP is a pain you say? I agree with you re cost.. I've been looking to pick up a 9700 or 9800 pro for awhile and these are hard […]
9600GT
Radeon HD 3870 GPU
Yeah, AM2 is probably at a point where it may start to become expensive shortly. So worth getting the parts for cheap while they are available. I have some parts laying around myself, including 6400+ athlon X2 on which i had to practice replacing pins, but so far i've had no incentive to build it into actual system. I have LGA775/E8600/GTX66o build for practical purposes... AM2 just can not compete with that and feels pointless. For now.
As much as AGP is a pain it is also fun. For me anything pci-e just feels like modern hardware, i can stick random new-ish card into it and it'll work. I ended up with 7600GT in my socketA build: High-end Socket462/A build. but given i've acquired quite a few cards during this time, including 9800pro, i may just build another one with another card - while building that system i collected enough parts for at least a few of them...
Reply 7 of 47, by AlexZ
Have a look at Re: Any love for AM2? , it shows exactly what kind of performance you can expect out of AMD Athlon 64X2 6000+ ADX6000IAA6CZ.
The clear winner of AM2 is AMD Athlon 64X2 6400+ (windsor). You can easily get that by increasing the base clock a little bit to get 3.2Ghz. You shouldn't have to increase cpu voltage. Note that by default, your RAM will run as DDR2 750, not 800 even if you select DDR2 800 in BIOS. See the AM2 topic for details.
DDR2 800 at 5-5-5-18 is not that great, there are cheap modules which can do 4-4-4-12 at 800 such as ADATA Vitesta 1066. Those timings are possible with 4x 2GB sticks and 2V. Grab them while they are cheap.
As GPU you can choose:
1.) historical GeForce 2xx which offers the best compatibility,
2.) GeForce 480 which does slightly better but has major issues with Need For Speed Hot Pursuit 2 with AMD CPU. The game is practically unplayable.
3.) Newer GPU such as GeForce 660 or 750 is also possible with the same limitations as GeForce 480. GeForce 2xx and 4xx run hot and need a good semi-modern mesh case or they will die.
You may pair it with a very powerful GPU such as GeForce 780 but see benefits only in CPU light games such as Fifa titles. It will not help with Crysis or GTA4. I would not recommend GeForce 9600 GT. I tested GeForce 9800 GT, it is not bad, but GeForce 2xx does better.
Noctua U12S should cool it with ease. I will be using Scythe Ninja 5 on my AM2+.
Athlon 64X2 6400+ (windsor) covers Windows XP era very well, but Windows Vista era has mediocre coverage as some very demanding games such as Crysis or GTA 4 were released. In Windows Vista era you will need to make compromise on details. Lowering resolution will not help as games tend to be CPU bound.
I think it's a great time to get stocked on the historical AM2(+) CPUs as people consider them worthless.
AMD cannot compete with Intel E8600 as that CPU is two generations ahead in process size and has a large L2 cache. AMD only caught up with Phenom II with that.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 8 of 47, by nd22
You got the 125W version of the 6000. Maybe you can under volt that chip a little, however you will still need a good cooler, something with copper!
If you can manage to find another 2gb of RAM it would be great for late Windows XP era games such as Company of heroes and others.
As for the video card if you stick to XP and do not want to spend a lot a GTX 560TI/660TI are more than enough for any games up to 2006. Something like Radeon 4890/GTX 285 if you want to be period correct will cut it close if you want max details and quality settings at high resolutions such as 1600*1200/1920*1080. As for period correct video cards: forget it! Not even X1950 XTX can run most directx 9 games at max details and high resolution!
By the way, what monitor do you plan on using? Something with classic aspect ratio or something modern with 16/9?
Reply 9 of 47, by AlexZ
There is a small price difference between old pcie GPUs. Between GeForce GTX 560 / 660 the 660 is a much better card. GeForce GTX 285 are not that common, I have 2x GTX 260 and bought 2x GTX 275 very cheap. I have not seen a single 285 sold locally.
I would not target a specific GPU, just buy something cheap. I see Gigabyte GeForce GTX 560, 660, 760 sold locally for the same price €20. From those I would pick 760 solely based on price even if it's an overkill.
Reply 10 of 47, by Archer57
nd22 wrote on 2025-07-25, 06:02:
That's AM2, many modern coolers can be used with it. Given 125W i'd use a modern tower cooler with 120-140mm fan. The only thing to be careful with is VRM cooling (towers do not create airflow there).
AlexZ wrote on 2025-07-25, 07:19:
Yep, absolutely agree. Unless for some reason some specific requirement exists getting something mid-range as new as practical and as cheap as possible makes sense.
I only used GTX660 myself because i had a pair of this cards laying around from my experiments with SLI back when they were new. This are not a very good cards with whole 1.5GB fast + 0.5GB slow memory mess, but they do the job for systems like this.
Reply 11 of 47, by marxveix
If i where you, id use with your AMD AM2 build Radeon HD 3870 GPU with Catalyst 7.11 and 2x2GB(4GB) is good for WinXP 32bit. If the CPU is to good for this GPU then use lower power AM2 CPU. Auidigy 2 hold for Win9x build and here use newer XP combatible soundcard, like Sound Blaster X-Fi.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 12 of 47, by ODwilly
Any CPU cooler that lists AM3 or + for compatibility will work for Am2/+. Fm1/2/+ as well. Heck even 939 and 754. People crap on the stock AMD retention mechanism, but the fact that a stock 125watt 939 HSF I had worked flawlessly to replace the crap stock HSF on a friend's Am3+ FX 6300 impressed me.
Reply 13 of 47, by stinkydiver
I did end up getting the 9600GT as I have no PCIe video cards - can use this for testing and as a spare
In saying that, there is a GTS 250 going for $5 locally which is probably a good fit, given the comments in this thread
https://www.gigabyte.com/Graphics-Card/GV-N250ZL-1GI
Keep in mind, this build is really to play games from 2003-2005..
Reply 14 of 47, by nd22
That GTS 250 is actually very good: the 512mb of VRAM on the 9800 GTX+ limits performance a lot and makes it slower than 8800 GTX. With 1gb of VRAM that weakness is taken care of and the card can play most games up to 2006 at max settings.
Before anyone will say that you do not need more than 512mb of VRAM on games of that era please try as just an example Company of heroes 1 from 2006 at max details and come back to report on VRAM usage and game-play experience with a GTS 250 512mb/ GTS 250 1024mb.
Reply 15 of 47, by AlexZ
You would not normally use GeForce 9800 GT(X) in an AM2 system as it can benefit from GTX 480 or stronger. GeForce 9800 GT(X) is for socket 754 or perhaps also 939 with its low clocked dual cores. Due to VRAM limit you would not play a few games at maximum details, but those would probably run poorly on the slow CPUs anyway.
Reply 16 of 47, by stinkydiver
Well I got a bit of a deal on a GPU, $2.95 USD for a GeForce GTS 250. Needs a bit of a clean and some new thermal paste, but otherwise looks like its in great condition.
So at present the build is:
CPU: AMD Athlon 64 X2 6000+
Motherobard: ASUS M2N-SLI Deluxe
RAM: 2 × 2GB Corsair XMS2
Video: Gigabyte GeForce GTS 250
Total cost so far (not including shipping), around $29 USD
Now to find a cheap good quality PSU so I can test it all 😀
As I mentioned, I like to stay realatively period correct with my builds. I think I can get away with the GTS250 as the GPU core is from 2007..
Reply 17 of 47, by Archer57
nd22 wrote on 2025-07-29, 05:27:
IIRC 9800GTX+ and 9800GT do have 1GB version, even 8800GT does. Though they are a bit less common as people preferred cheaper 512MB versions.
That said GTS250 is still a better choice because it is likely to have fixed GPU.
stinkydiver wrote on 2025-08-05, 20:26:
Well I got a bit of a deal on a GPU, $2.95 USD for a GeForce GTS 250 GPU. Needs a bit of a clean and some new thermal paste, but […]
Well I got a bit of a deal on a GPU, $2.95 USD for a GeForce GTS 250 GPU. Needs a bit of a clean and some new thermal paste, but otherwise looks like its in great condition.
Nice. This should work reasonably well. And now, given the name of that motherboard, you have the obvious option to find a second card for cheap and fool around with SLI. Not that i would recommend it from practical point of view, but it can be a good fun just for a few extra $.
Also yeah, IMO GTS250 is a very good option if you want relatively period correct but do not want bumpgate. It is still G92, first used in 8800GT, but it should be fixed and by that point coolers on the cards also got better - the one you got should be vastly better than single slot "leaf blower" most 8800GT had...
Reply 18 of 47, by AlexZ
It should be about the same as the 1st configuration I tested in Re: Any love for AM2? . I have a very similar Gigabyte GeForce 9800 GT and what you see below the fan wasn't dust but corrosion and the chrome coating flaking off. I removed the heatsink, rinsed it, used nail file to clean fins where the material was flaking off and dried it with vacuum cleaner exhaust. It's certainly a good starting point.
Reply 19 of 47, by stinkydiver
Update:
I've managed to wrangle an ATX PSU, a brand new EVGA 600GQ for $29 USD, and as a bonus grabbed a brand new ASUS DVD Writer for 60 cents..
I also have a second hand Noctua NH-U12S Cooler on the way which i grabbed for $26 USD
I like my computers to run as quiet as possbile. Depnding on how loud the GTS 250 is, I wouldn't mind picking up another one for cheap to play around with SLI
