First post, by jakethompson1
jakethompson1
Offline
- l33t
To achieve 2-1-1-1 & 0 W/S cache together with VLB required replacing the 15 ns "CE" tag RAM with a 15 ns UMC one; see discussion at Re: Configuring two VLB cards on a 486 vesa local bus
Speedsys:
Cachechk:
CACHECHK v4 2/7/96 Copyright (c) 1995 by Ray Van Tassle. (-h for help)CMOS reports: conv_mem= 640K, ext_mem= 15,360K, Total RAM= 16,000K"UMC UMC UMC " 486 Clocked at 715.9 MHzReading from memory.MegaByte#: --------- Memory Access Block sizes (KB)-----1 2 4 8 16 32 64 128 256 512 1024 2048 4096 <-- KB0: 13 13 13 13 21 21 21 21 21 32 -- -- -- µs/KB2: 13 13 13 13 21 21 21 21 21 32 32 32 32 µs/KB3 4 5 6 7 8 9 10 11 12 13 14 15 <--- same as above.Extra tests----Wrt 27 27 27 27 27 27 27 27 27 27 27 27 27<-Write memThis machine seems to have both L1 and L2 cache. [read]L1 cache is 8KB -- 83.8 MB/s 12.5 ns/byte (240%) (162%) 34.2 clksL2 cache is 256KB -- 51.6 MB/s 20.3 ns/byte (147%) (100%) 55.5 clksMain memory speed -- 34.9 MB/s 30.1 ns/byte (100%) [read] 82.1 clksEffective RAM access time (read ) is 120ns (a RAM bank is 4 bytes wide).Effective RAM access time (write) is 102ns (a RAM bank is 4 bytes wide)."UMC UMC UMC " 486 Clocked at 715.9 MHz. Cache ENABLED.Options: -t0
dooms -timedemo demo3: 2134 gametics in 3291 realtics
Topbench:
The current system...SCORE: 237 MemTest: MemEA: Opcodes: VidMem: 3DGames: Total:69 µsec 22 µsec 24 µsec 90 µsec 22 µsec 227 µsec...most closely matches the following entry in the database:TEX's Socket 7 DOS machine [100MHz]AMD Am5x86 CloneGateway 2000 4DX-33V with Turbochip╔═══════════════════════════ Matched system detail: ═══════════════════════════╗║SCORE: 236 MemTest: MemEA: Opcodes: VidMem: 3DGames: Total: ║║ 48 µsec 25 µsec 20 µsec 139 µsec 15 µsec 247 µsec ║║CPU: AMD 5x86 P75 (Am5x86) @ 120 MHz ║║Video Adapter: VGA (VGA, Tseng ET 4000W32i, DRAM, VESA, 1MB Video Memory) ║║Submitter: High Treason (HighTreason610) ║║BIOS Info: ║║Copyright (C) 1984-95, Award Software, Inc. (02/28/95, rev. 0) ║║ ║║Description: ║║UM8498F, 256KB L2, 16 MB EDO. CPU Rated for 133, CPU Unsupported by MOBO ║║though 150MHz is attainable. ║║ ║║ ║╚══════════════════════════════════════════════════════════════════════════════╝Adjust your machine or emulator to see the results change realtime. ESC exits.
