First post, by ratfink
- Oldbie
PC has been reliable - for a few years - until today. After a few minutes photo editing it froze and then I lost graphics, no sign of disk activity and the on/off and reset buttons did nothing, temperature indicator on the case remained on, I had to turn off at the socket. Temperature readout was normal (32-34c or therabouts).
Turned on at socket, push on button, it boots to windows but now does the same after a few minutes - no video, can't turn off, temperature reading on case stays on. Tried checking the event log but it's full of crap so tried clearing it and the PC shut off again.
Ran the memory test off the boot menu, nothing found on the first pass, second pass ran... rebooted.... it shut off before I could do anything.
Any ideas?
When it boots there's no indication it had shut down improperly, it doesn't run checkdsk or do any checks I can discern. Feels like the on/off/reset not working (but case temp led readout stays on) means something.
Ryzen 7, Asus XPRO4 motherboard, 32gb ram, GTX560Ti, PSU was renewed a few years ago, PC seldom used other than every few weeks for photo work, hasn't been used much for the last month.
Maybe I should check there's not a dislodged cable at the back. After that - change the PSU maybe?
