First post, by Un Information
Un Information
Offline
I've got it working.
I've been using Phil's MS-DOS Starter Pack configuration for "Exit to DOS," but I wanted to add a boot menu for MS-DOS and Windows 98SE on start up. I've been fiddling around with it but I've had no luck, here's what I've been trying:
Autoexec.bat:
SET CONFIG=EMCSET TMP=C:\WINDOWS\TEMPSET TEMP=C:\WINDOWS\TEMPSET PROMPT=$p$gSET winbootdir=C:\WINDOWSSET PATH=C:\WINDOWS;C:\WINDOWS\COMMANDSET SOUND=C:\SB16SET BLASTER=A220 I5 D1 H5 P330 T6SET MIDI=SYNTH:1 MAP:ESET CTSYN=C:\SBLIVE\LIVEDOSC:\SB16\DIAGNOSE /SC:\SB16\MIXERSET.EXE /P /QC:\SBLIVE\LIVEDOS\SBEINIT.COMC:\SBLIVE\LIVEDOS\EK1M.EXE -B -F C:\SBLIVE\LIVEDOS\EKCFGLH C:\WINDOWS\COMMAND\MOUSE.COM /P4 /S80::IF "%CONFIG%"=="EMC" GOTO :EMC::IF "%CONFIG%"=="XMC" GOTO :XMC::IF "%CONFIG%"=="CMC" GOTO :CMC::IF "%CONFIG%"=="EM" GOTO :EM::IF "%CONFIG%"=="XM" GOTO :XM::IF "%CONFIG%"=="CM" GOTO :CM::IF "%CONFIG%"=="WIN" GOTO :WINgoto %config%:WINC:\WINDOWS\WIN.COMGoTo ENDGoTo EMC:EMC:XMC:CMCLH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:OPTICALGoTo END:EM:XM:CMGoTo END:END
Config.sys:
[COMMON];DOS=NOAUTODOS=HIGH,UMBFILES=30BUFFERS=30LASTDRIVE=HDEVICE=C:\WINDOWS\SETVER.EXE[menu]submenu=dos, MS-DOS 7.1submenu=win, Microsoft Windows 98 SE[dos]menuitem=EMC, Expanded memory + Mouse + CD-ROMmenuitem=XMC, Extended memory + Mouse + CD-ROMmenuitem=CMC, Conventional Memory only + Mouse + CD-ROMmenuitem=EM, Expanded memory + Mousemenuitem=XM, Extended memory + Mousemenuitem=CM, Conventional memory only + Mousesubmenu=win, Microsoft Windows 98 SEmenudefault=EMC,10[EMC]DOS=NOAUTODEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\EMM386.EXE I=B000-B7FF 8192 RAMDEVICEHIGH=C:\WINDOWS\COMMAND\VIDECDD.SYS /D:OPTICAL[XMC]DOS=NOAUTODEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICEHIGH=C:\WINDOWS\COMMAND\VIDECDD.SYS /D:OPTICAL[CMC]DOS=NOAUTODEVICEHIGH=C:\WINDOWS\COMMAND\VIDECDD.SYS /D:OPTICAL[EM]DOS=NOAUTODEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFFDEVICE=C:\WINDOWS\EMM386.EXE RAM[XM]DOS=NOAUTODEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF[CM]DOS=NOAUTO[WIN];DEVICE=C:\WINDOWS\HIMEM.SYS;DOS=HIGH,UMB;DEVICE=C:\WINDOWS\EMM386.EXE NOEMS
Can anyone help with what I've done wrong? Thanks.
