Reply 540 of 550, by myne
Which version of the installer are you using?
Dxwnd was fixed a few months ago, and a new pack compiled into the installer.
There aren't any reports of it failing, and I finished mercs Titanium with minimal issues.
I built:
Reply 541 of 550, by Deffnator
myne wrote on 2025-07-30, 16:04:
i am using the newest version that was posted here recently
Reply 542 of 550, by old school gamer man
is there a way to play the hardware 3d versions on xp? the powervr one more than anything. the matrox one too?
Reply 543 of 550, by Deffnator
old school gamer man wrote on 2025-07-30, 16:38:
those runs naturally using the mech2.org instructions, but depends if there are drivers for it, 3dfx runs fine thanks to nglide and MW2hook or the xp patch.
Reply 544 of 550, by old school gamer man
Deffnator wrote on 2025-07-31, 14:25:
even if you don't have a power vr or matrox card?
Reply 545 of 550, by Deffnator
old school gamer man wrote on 2025-07-31, 16:40:
Unfortunately there is no Matrox or PowerVR wrappers
Reply 546 of 550, by old school gamer man
Deffnator wrote on 2025-07-31, 19:19:
that sucks.
Reply 547 of 550, by Deffnator
So i decided to put my dxwnd configuration as dgvoodoo config for Been_nath and myne to investigate as others here who may know better.
I gave a better feedback at the dgvoodoo's thread, under this config not only titanium is running great though it has some issues related to memory during a mission once in a while, this may also be a problem under direct3d, but for some reason dxwnd and mercs menu aren't agreeing with each other and the menu is always stuck on top left of the screen and cant be scaled at all without issues, ot kept in windowed mode as it should be.
The attachment dxwnd.ini is no longer available
The attachment dgVoodoo.conf is no longer available
my only wish is for a WASD config based on Mech5+MWO's default settings, but i finished these games before on the og scheme years ago.
Reply 548 of 550, by myne
Need more details.
What versions? Preferably with the string copied from the installer. Eg
Ie, cdlabel, productid, productname from the product.Ini
What's the problem?
What are you trying to do that makes the defaults in the installer unsuitable?
How will others benefit?
I built:
Reply 549 of 550, by Deffnator
myne wrote on Today, 00:08:
Need more details. What versions? Preferably with the string copied from the installer. Eg Ie, cdlabel, productid, productname […]
Need more details.
What's the problem?
this is from the last mw2installer+latest dgvoodoo2 build for mercs titanium, i also gave the entire feedback at the dgvoodoo subforum thread.
here in this case is to solve out the erratic behavior of the main menu window+direct3d resolution, on which i gave up after tweaking video and main for hours on dxwnd.
Reply 550 of 550, by myne
4 questions. 2 answered.
I'm not a dentist. I don't have the patience to pull teeth.
I built:
