What do you think of my new retro PC?
First post, by eliot_new
A long time ago, from 1999 to 2000, I worked in a computer store. I learned a lot about hardware there. Back then, I built myself a new PC because of Ultima 9. It was a Celeron 500, Intel chipset BX board, Riva TNT 2 AGP, 128 MB SDRAM, 20 GB HDD. Those were two special years for me; I played a lot of games, mostly DirectX, since I didn't have the money for Voodoo graphics. Since then, I've longed to own a Voodoo card at least once in my life. I thought long and hard about whether I wanted to play all the 3dfx games, or just the very early ones that still ran under MS-DOS. I finally decided on a Canopus Pure3D 3dfx with 6 MB of memory. After I bought it last week, I realized that it might not even run in my old PC. I have an old Intel i3 Socket 1150 on an Asus H97M-Plus, 32 GB DDR3-1600, a PCI-E nVidia Quadro K4200 that I randomly got as a gift from my neighbor in 2020, and Windows 8.1. A Voodoo 1 probably wouldn't run in this i3 PC. So this week I've been thinking about how to build a retro PC around the Voodoo 1. After reading a lot online, I've decided I'm tired of ISA local bus. I only want PCI, AGP, or PCI-E. So I've bought the following components and am waiting for them to finally arrive so I can put everything together. I've included the prices so you can understand why I didn't buy a Voodoo 3, GeForce 3, nor GeForce 4:
1. Asus CUSL2-C + P3 CPU with 1 GHz Intel Coppermine: €62
2. HP Elpida chip with 256 MB SDRAM at 133 MHz: €8
3. CPU cooler: €14
4. Toshiba SH-202J DVD burner IDE: €14
5. MSI GeForce FX 5600 AGP with 128 MB: €25
6. Samsung 80 GB HDD IDE: €22
7. 2x IDE cables: €6
8. Canopus Pure3D 6 MB 3dfx V1: €168 (very expensive, but a rarity)
I planned to create three primary partitions with Parted Magic to boot three operating systems:
1. Win98 SE + DOS for 3dfx games, e.g., Tomb Raider, Quake, UT
2. WinXP for DirectX 9.0 games and for the Glide Wrapper tool, to smoothly run newer 3dfx games like Ultima 9 or newer DirectX games like Half Life 1, No One Lives Forever, etc.
3. Win2003 Standard R2 to run applications like MS Office 2003, SQL Server 2003, and MS Dynamics NAV 2009 just for fun. I also have an old HP LaserJet M1005.
I found a user on YouTube who is using a Voodoo 1 graphics card on an Asus CUSL2-C with a Coppermine CPU and is playing Resident Evil 1. Therefore, I assume the 3dfx card is running on this motherboard.
I know the FX 5600 is oversized, but a GeForce 4, GeForce 3, GeForce 2, GeForce 256, or even the Voodoo 3 are sometimes offered for €100 or more. GeForce FX cards, on the other hand, are ridiculously cheap on eBay. I'll be using the nVidia 45.23 driver; it's supposed to still support the FX 5600.
Question: Which PCI sound card would you recommend that still produces good sound in DOS mode on Win98SE?
Aureal Vortex, Creative SB 128, Creative SB Live, Creative Audigy 1, 2?
Unfortunately, there was no PCI version of Gravis Ultrasound PnP. I had this card back in 1994 when I got my first PC from my parents. It rocked during Jazz Jack Rabbit and Rise of the Tried.
Please excuse any typos. I had Google Translate translate this text into English.
DOS:P233MMX,64MB,ECS,SpeaMirageV7,3dfxV1,AWE64,ESS1868,PicoGUS,32GB
W98SE:K63/400,256MB,P5A,Verite2200AGP,3dfxV2,M3D,AWE64,ESS1938,PicoGUS,64GB
XP:P3-1G,512MB,CUSL2C,FX5600AGP,Audigy1,80GB
Reply 1 of 39, by H3nrik V!
You may be missing ISA for sound in DOS as fair as I understand. But the CUSL2-C is a great board for windows.
I actually have a rare'ish 128 but version of the FX5200, which is reasonably fast, given that it's passively cooled ..
Reply 2 of 39, by RetroPCCupboard
Sounds like it should be a good win98 machine.
As for soundcard, If budget is a concern, then I think Soundblaster live will be fine. Be careful though, as some OEM models need drivers from the OEM. I think SB0060 is easy to find drivers for. Game compatability won't be as good as you would get with an ISA card.
Reply 3 of 39, by chinny22
Ideally you would have had 2 sound cards an ISA one for dos and a PCI for windows. But what's done is done and work arounds exist.
Aureal Vortex is good card for Win9x era, has good dos compatibility but was all but dead during WinXP
Creative SB Live, Audigy 1, 2 are all the same family of cards. Main difference between them is newer the card the later the EAX version is supported.
(Live = EAX 2, Audigy = EAX 3, Audigy 2 = EAX 4
How much this matters will depend on your game library.
https://www.vogonswiki.com/index.php/List_of_ … ith_EAX_support.
Creative SB 128 lack any EAX, only reason to pick this over a Live/Audigy is you already have the card and want to save money.
And don't worry about the FX 5600 This actually makes alot of sense. You now have both Glide AND D3D games.
Reply 4 of 39, by Matth79
You're in a minefield for DOS sound compatibility with PCI only
Reply 5 of 39, by Archer57
Hmm, curious build. It'll likely work just fine for what you want from it. However i would have probably done it differently - either older, with ISA sound card, for DOS. Or if you are dropping ISA anyway - newer, like S462/S478, so that all the newer stuff works better. But then in newer build voodoo1 looks kind of out of place... it'll likely feel a bit like 3d decelerator compared to FX5600 + wrapper.
I mean WinXP and 2003 will run on P3+256MB RAM, but it will be quite slow.
Especially with that vintage HDD - this is something i would never have done - paying money for old HDD. IDE-SATA + SSD would be my choice, or at least IDE-SATA + modern HDD if you want HDD.
I am not sure how well all the stuff you describe will fit into 80GB, may be a bit... limiting.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 6 of 39, by RetroPCCupboard
Archer57 wrote on 2025-08-01, 03:08:
Personally, I think for Win98 an IDE HDD is fine. Though, yes, I agree I wouldn't buy one. I just happen to have kept all of the ones from my PCs over the years. Mostly they are hitachi.
SSDs are certainly better performance, quieter, and more reliable.
Reply 7 of 39, by sfryers
eliot_new wrote on 2025-07-31, 18:23:
A Coppermine P3 can be too fast for a Voodoo 1 in some circumstances, particularly with DOS glide games. If you do find games aren't running properly, setting the FSB to 66MHz (to reduce the CPU speed to 500MHz) may help.
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 8 of 39, by eliot_new
@H3nrik V:
I also wanted first the FX 5200, but then discovered that the 2nd hand price is 12€ without shipping on eBay whereas I paid 25 € incl. shipping for the FX 5600.
@chinny22:
Amazing list of games, thank you! I tend to buy an Audigy 1 now. The only games, that I will miss because of EAX 4.0:
Bioshock, Collin McRay, Doom3, Gears of war, Prey, Quake 4, The Witcher 1 => I can play them on my newer PC, I guess (with my SB Audigy 5.1 PCI-E)
@Matth79:
I plan to use DOS-Box on my newer PC for all games that will not work.
@Archer57:
I still have a Pentium D805 2.66 GHz, Fujitsu Socket 775 board, and 4 GB DDR2-667 RAM in my basement, which is disassembled into individual parts.
My first thought was, of course, to use it for the Voodoo 1.
But I read that it has problems with the P4 architecture under DOS games and Glide.
My goals:
1. To play the most popular DOS games that support Glide, like Tomb Raider 1 or early 3dfx games that ran under Win98, like Unreal 1.
=> 3dfx Canopus V1
2. To play newer games (1999-2003) like Ultima 9 under D3D
=> FX 5600
3. Newer 3dfx games that absolutely required Voodoo 3 but didn't support neither D3D nor OpenGL.
For this, I would use Glide Wrapper (I don't have any examples, Ultima 9 also had D3D, what games from 2000 require V2...V5 Glide only?)
=> FX 5600
4. To play newer OpenGL games at a decent speed (I lack any examples, but I remember that the Quake 123, Hexen 2, Heretic 2 required OpenGL)
=> FX 5600
@Windows 2003 and Windows XP:
as soon as I've built the retro PC and everything is working, I'll buy another 256 MB of SDRAM.
@Parallel ATA EIDE HDD:
I really wanted one. I want to relive the feeling from 2000, what it was like back then to build a PC manually with all the components from back then. If the Voodoo 3 weren't so expensive, I would have bought one. So, the graphics card is the only component that's out of the ordinary. Besides I can also still connect a SATA adapter with SDD and use instead the 80 GB HDD in my Playstation 2 Fat Edition.
@sfryers
Thank you very much for the hint!
Indeed it is a P3-1Ghz EB with FSB 133 which I can slow down to 495 Mhz. Really cool 😀
Reply 10 of 39, by AncapDude
I can confirm V1 issues with a Coppermine 1Ghz. You'll need to slow it down. For Sound, SB Live up to Audigy 2 ZS is great choice. Works well for DOS Games within 98 using SB16 Emulation Driver or use VSBHDASF in Plain DOS.
Reply 11 of 39, by H3nrik V!
Bruno128 wrote on 2025-08-14, 22:44:
The only place Voodoo 1 shines is DOS glide games. And with 1GHz CPU and 6MB video RAM most of them would have compatibility issues.
Not sure the 6MB Voodoo will cause any incompatibility issues, the extra 2 just won't get utilized IIRC.
But yes 1GHz can probably give some challenges DOS-wise
Reply 12 of 39, by AppleSauce
DOS games without an ISA sound card is going to be pretty rough.
Are you sure you can't source another motherboard with some slots?
Reply 13 of 39, by Bruno128
H3nrik V! wrote on 2025-08-16, 21:01:
It will, you need to limit memory with variables.
Not only this but also the voodoo texture corruption on fast systems (documented issue).
SBEMU compatibility reports list | Navigation thread
Reply 14 of 39, by eliot_new
Hello and good evening everybody,
once again thank you so much for your replies!
News: I bought on kleinanzeigen.de an old ATX big tower.
The seller included the already installed Gigabyte BX2000, P3-450 Slot1, 64 MB SDRAM and ATX power supply for free.
I thought I'd keep the ATX case and sell the rest.
But now I've realized what a good setup it is.
The board has two ISA slots.
The MSI FX 5600 AGP runs well on it.
I'll test the Canopus Voodoo 1 later.
I'll check the CPU and graphics requirements for all the games I want to play this weekend.
Maybe I might even sell the Asus CUSL2-C with the P3 Coppermine 1GHz and keep the Gigabyte with the P3 Katmai 450MHz.
Furthermore I also bought an AWE64 value ISA for a good price on eBay.
There's also an adapter available online to upgrade it to 28MB (SB16 ,AWE32, MT-32, GM, GS in all desired games)
What do you think about my new decisions?
What about buying a cheap GUS Pico on eBay?
Reply 15 of 39, by chinny22
I think for dos and Win98 it's better then the Asus CUSL2-C
It's probably going to be to slow for WinXP but so is any Pentium 3.
Run your games and see if the 450Mhz is fast enough, if not you can safely upgrade to a Katmai 600Mhz CPU, maybe faster depending on motherboard revision.
(I'm not familiar enough with the BX2000 to know which are compatible or not)
The memory upgrade for the AWE is good, just be aware it only works in windows. Not really a big problem for a P3 though as long as you play your dos games in windows as well which I P3 can typically do just fine.
I'm still missing GUS in my collection, only a very few games really require it (Typically Epic Megagames titles) but its a very good card that almost makes the AWE redundant.
Reply 16 of 39, by eliot_new
I figured out, that my Samsung PATA 80GB HDD only works as 32GB HDD if I set correctly the jumpers.
The BX2000 Bios does not recognize it if I set it to 80GB.
Very strange: maybe because it has an early Bios from 21-06-1999.
The already partitioned SSD 240 GB is recognized as a 20GB HDD in the Bios. I will consider whether:
(1) I will retain this board and add another @ 32 GB HDD as Slave drive
(2) buy another Slot 1 board which can recognize 80 GB or
(3) stick with my CUSL2, buy a SB Audigy 1 and sell the AWE64 and the BX2000 as well as the P3-450
I want to avoid flashing the BIOS
Reply 17 of 39, by chinny22
The BX chipset supports upto 120GB hard drive, so it'll definitely a bios limitation.
The latest bios is from 2002, It's still on their website so risk is low if you did want to update.
https://www.gigabyte.com/Motherboard/GA-BX2000/support#dl
IF you really REALLY don't want to update I would recommend against option 2. It's unlikely but always a chance you pick up a another board that hasn't been updated.
I'd just keep the Slot 1 450 as your dos/low end win9x rig with the awe
have the CUSL2 and Audigy as your high end Win9x / low end XP rig
Reply 19 of 39, by eliot_new
Bruno128 wrote on 2025-09-05, 04:52:
eliot_new wrote on 2025-09-04, 21:51:
Why?
Ok, I will do it anyway.
But I remember those days back 1994...1999 it was always a "thriller" for me:
1. boot MS-DOS
2. start AWFLASH utility
3. choose the bin file
4. cross the fingers, that everything will be fine 😒
Yesterday I installed Win98 SE. I guess, I can boot the PC from WIn 98 SE in DOS mode and run then AWFLASH....
I will report tonight what happened.
Kind regards 😀
